1.connect throw domain to site .com/owncloud
2.if connected via 192.x.x.x/owncloud it works
3.
Tell us what should happen : connect to login page
Tell us what happens instead : error 404, page not found
Operating system: ubuntu 16.04.2
Web server: apache2
Database: mysql
PHP version: 7.0.15-0
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): nope
{"reqId":"uu9mq0klY\/ayIkdWaZue","remoteAddr":"127.0.0.1","app":"mysql.setup","message":"Specific user creation failed: An exception occurred while executing 'SELECT user FROM mysql.user WHERE user=?' with params [\"oc_root\"]:\n\nSQLSTATE[42000]: Syntax error or access violation: 1142 SELECT command denied to user 'owncloud'@'localhost' for table 'user'","level":3,"time":"2016-08-27T13:23:00+00:00","method":"POST","url":"\/owncloud\/index.php","user":"--"}
{"reqId":"uu9mq0klY\/ayIkdWaZue","remoteAddr":"127.0.0.1","app":"mysql.setup","message":"Database creation failed: An exception occurred while executing 'GRANT ALL PRIVILEGES ON `owncloud` . * TO 'owncloud'':\n\nSQLSTATE[42000]: Syntax error or access violation: 1044 Access denied for user 'owncloud'@'localhost' to database 'owncloud'","level":3,"time":"2016-08-27T13:23:00+00:00","method":"POST","url":"\/owncloud\/index.php","user":"--"}
Integrity status for oC9+
paste the results here.
