izaera
21
I finally fixed the timeout issue.
It was as “easy” as setting the “Timeout” configuration setting of Apache to a big value (3600 = one hour).
The default is 60 seconds which makes the MOVE operation impossible because it takes much more than that.
After the fix I still get the failure regarding the checksums (but now in the form of a HTTP 400 error).
I will try to debug remote.php and see if I can find out anything.
Then, I will open a new thread so that we can talk about the checksum issue there (this one is a big bloated by now).
Cheers,
Ivan
dmitry
22
Could you specify where to set what value?
And thank you for the debugging, it will definitely be helpful to others.
izaera
23
Depends on the distro, but it goes in the httpd.conf file of Apache.
This is the official documentation -> https://httpd.apache.org/docs/2.4/mod/core.html#timeout
guruz
24
Do you want to help improving the documentation?
https://doc.owncloud.com/server/admin_manual/installation/configuration_notes_and_tips.html#php-fpm
