OK. Done that.
I dumped the output of the log to the owncloud-client.log file and ran:
fgrep -e sync.checksums -e sync.networkjob.mkcol -e sync.propagator.upload owncloud-client.log
which gave me:
05-29 15:30:42:532 [ info sync.checksums ]: Computing "SHA1" checksum of "/home/ivan/OwnCloud/Documentos/Backups/data2/data2.img" in a thread
05-29 15:30:53:248 [ info sync.networkjob.mkcol ]: MKCOL of QUrl("[https://zeus/owncloud/remote.php/dav/uploads/ivan/1760773490](https://zeus/owncloud/remote.php/dav/uploads/ivan/1760773490)") FINISHED WITH STATUS "OK"
05-29 15:30:56:745 [ info sync.propagator.upload ]: Chunked upload of 10000000 bytes took 3489 ms, desired is 60000 ms, expected good chunk size is 171969045 bytes and nudged next chunk size to 90984522 bytes
05-29 15:31:13:621 [ info sync.propagator.upload ]: Chunked upload of 90984522 bytes took 16780 ms, desired is 60000 ms, expected good chunk size is 325332021 bytes and nudged next chunk size to 100000000 bytes
05-29 15:31:32:832 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 19074 ms, desired is 60000 ms, expected good chunk size is 314564328 bytes and nudged next chunk size to 100000000 bytes
05-29 15:31:52:393 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 19422 ms, desired is 60000 ms, expected good chunk size is 308928019 bytes and nudged next chunk size to 100000000 bytes
05-29 15:32:11:190 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 18653 ms, desired is 60000 ms, expected good chunk size is 321664075 bytes and nudged next chunk size to 100000000 bytes
05-29 15:32:29:973 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 18645 ms, desired is 60000 ms, expected good chunk size is 321802091 bytes and nudged next chunk size to 100000000 bytes
05-29 15:32:48:510 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 18424 ms, desired is 60000 ms, expected good chunk size is 325662179 bytes and nudged next chunk size to 100000000 bytes
05-29 15:33:07:546 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 18870 ms, desired is 60000 ms, expected good chunk size is 317965023 bytes and nudged next chunk size to 100000000 bytes
05-29 15:33:25:863 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 18179 ms, desired is 60000 ms, expected good chunk size is 330051157 bytes and nudged next chunk size to 100000000 bytes
05-29 15:33:44:669 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 18702 ms, desired is 60000 ms, expected good chunk size is 320821302 bytes and nudged next chunk size to 100000000 bytes
05-29 15:34:02:329 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 17423 ms, desired is 60000 ms, expected good chunk size is 344372381 bytes and nudged next chunk size to 100000000 bytes
05-29 15:34:23:927 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 21512 ms, desired is 60000 ms, expected good chunk size is 278914094 bytes and nudged next chunk size to 100000000 bytes
05-29 15:34:41:299 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 17118 ms, desired is 60000 ms, expected good chunk size is 350508236 bytes and nudged next chunk size to 100000000 bytes
05-29 15:34:57:808 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 16289 ms, desired is 60000 ms, expected good chunk size is 368346737 bytes and nudged next chunk size to 100000000 bytes
05-29 15:35:16:378 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 18321 ms, desired is 60000 ms, expected good chunk size is 327493040 bytes and nudged next chunk size to 100000000 bytes
05-29 15:35:35:733 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 19232 ms, desired is 60000 ms, expected good chunk size is 311980033 bytes and nudged next chunk size to 100000000 bytes
05-29 15:35:53:909 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 18057 ms, desired is 60000 ms, expected good chunk size is 332281109 bytes and nudged next chunk size to 100000000 bytes
05-29 15:36:12:833 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 18809 ms, desired is 60000 ms, expected good chunk size is 318996225 bytes and nudged next chunk size to 100000000 bytes
05-29 15:36:31:338 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 18424 ms, desired is 60000 ms, expected good chunk size is 325662179 bytes and nudged next chunk size to 100000000 bytes
05-29 15:36:48:168 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 16584 ms, desired is 60000 ms, expected good chunk size is 361794500 bytes and nudged next chunk size to 100000000 bytes
05-29 15:37:06:765 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 18534 ms, desired is 60000 ms, expected good chunk size is 323729362 bytes and nudged next chunk size to 100000000 bytes
05-29 15:37:26:225 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 19373 ms, desired is 60000 ms, expected good chunk size is 309709389 bytes and nudged next chunk size to 100000000 bytes
05-29 15:37:44:231 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 17940 ms, desired is 60000 ms, expected good chunk size is 334448160 bytes and nudged next chunk size to 100000000 bytes
05-29 15:38:02:370 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 18054 ms, desired is 60000 ms, expected good chunk size is 332336324 bytes and nudged next chunk size to 100000000 bytes
05-29 15:38:21:317 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 18829 ms, desired is 60000 ms, expected good chunk size is 318657390 bytes and nudged next chunk size to 100000000 bytes
05-29 15:38:40:055 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 18639 ms, desired is 60000 ms, expected good chunk size is 321905681 bytes and nudged next chunk size to 100000000 bytes
05-29 15:38:59:513 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 19354 ms, desired is 60000 ms, expected good chunk size is 310013433 bytes and nudged next chunk size to 100000000 bytes
05-29 15:39:17:567 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 17948 ms, desired is 60000 ms, expected good chunk size is 334299086 bytes and nudged next chunk size to 100000000 bytes
05-29 15:39:38:732 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 21092 ms, desired is 60000 ms, expected good chunk size is 284468044 bytes and nudged next chunk size to 100000000 bytes
05-29 15:39:57:172 [ info sync.propagator.upload ]: Chunked upload of 100000000 bytes took 18170 ms, desired is 60000 ms, expected good chunk size is 330214639 bytes and nudged next chunk size to 100000000 bytes
05-29 15:40:15:803 [ info sync.propagator.upload ]: Chunked upload of 99015478 bytes took 18502 ms, desired is 60000 ms, expected good chunk size is 321096566 bytes and nudged next chunk size to 100000000 bytes
05-29 15:40:15:805 [ info sync.propagator.upload ]: "/owncloud/remote.php/dav/files/ivan/Documentos/Backups/data2/data2.img" "SHA1:02c80d9fcb2c12c607594863b6134da1e3249f1f"
05-29 15:41:15:932 [ debug sync.propagator.upload ] [ OCC::PropagateUploadFileCommon::commonErrorHandling ]: "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML 2.0//EN\">\n<html><head>\n<title>504 Gateway Timeout</title>\n</head><body>\n<h1>Gateway Timeout</h1>\n<p>The gateway did not receive a timely response\nfrom the upstream server or application.</p>\n</body></html>\n"
05-29 15:42:07:208 [ info sync.checksums ]: Computing "SHA1" checksum of "/home/ivan/OwnCloud/Documentos/Backups/data2/data2.img" in a thread
05-29 15:42:17:150 [ info sync.propagator.upload ]: Resuming "Documentos/Backups/data2/data2.img" from chunk 31 ; sent = 3000000000
05-29 15:42:17:150 [ info sync.propagator.upload ]: "/owncloud/remote.php/dav/files/ivan/Documentos/Backups/data2/data2.img" "SHA1:02c80d9fcb2c12c607594863b6134da1e3249f1f"
05-29 15:42:19:518 [ debug sync.propagator.upload ] [ OCC::PropagateUploadFileCommon::commonErrorHandling ]: "<?xml version=\"1.0\" encoding=\"utf-8\"?>\n<d:error xmlns:d=\"DAV:\" xmlns:s=\"[http://sabredav.org/ns\">\n](http://sabredav.org/ns\) <s:exception>OCA\\DAV\\Connector\\Sabre\\Exception\\FileLocked</s:exception>\n <s:message>\"Documentos/Backups/data2/data2.img\" is locked</s:message>\n</d:error>\n"
05-29 15:42:35:810 [ info sync.checksums ]: Computing "SHA1" checksum of "/home/ivan/OwnCloud/Documentos/Backups/data2/data2.img" in a thread
Which seems to imply that a timeout plus a locking happened after the upload finished.
Then I have this in owncloud’s server log:
{"reqId":"74865c24-4cce-4cb8-8155-6df17d224d6e","level":4,"time":"2019-05-29T13:30:19+00:00","remoteAddr":"192.168.1.114","user":"ivan","app":"webdav","method":"MOVE","url":"\/owncloud\/remote.php\/dav\/uploads\/ivan\/935159965\/.file","message":"Exception: HTTP\/1.1 400 The computed checksum does not match the one received from the client.: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\BadRequest\",\"Message\":\"The computed checksum does not match the one received from the client.\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(172): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #623)\\n#1 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Tree.php(314): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->createFile('data2.img', Resource id #623)\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Tree.php(130): Sabre\\\\DAV\\\\Tree->copyNode(Object(OCA\\\\DAV\\\\Upload\\\\FutureFile), Object(OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory), 'data2.img')\\n#3 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Tree.php(161): Sabre\\\\DAV\\\\Tree->copy('uploads\\\/ivan\\\/93...', 'files\\\/ivan\\\/Docu...')\\n#4 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(642): Sabre\\\\DAV\\\\Tree->move('uploads\\\/ivan\\\/93...', 'files\\\/ivan\\\/Docu...')\\n#5 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpMove(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#7 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(479): Sabre\\\\Event\\\\EventEmitter->emit('method:MOVE', Array)\\n#8 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#9 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(298): Sabre\\\\DAV\\\\Server->exec()\\n#10 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#11 \\\/var\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/var\\\/www\\\/ownclo...')\\n#12 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":210}"}
{"reqId":"c9dea2d2-f9d3-4567-a94f-cd0f7af54482","level":4,"time":"2019-05-29T13:42:19+00:00","remoteAddr":"192.168.1.114","user":"ivan","app":"webdav","method":"MOVE","url":"\/owncloud\/remote.php\/dav\/uploads\/ivan\/1760773490\/.file","message":"Exception: HTTP\/1.1 423 \"Documentos\/Backups\/data2\/data2.img\" is locked: {\"Exception\":\"OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Exception\\\\FileLocked\",\"Message\":\"\\\"Documentos\\\/Backups\\\/data2\\\/data2.img\\\" is locked\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Tree.php(314): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->createFile('data2.img', Resource id #624)\\n#1 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Tree.php(130): Sabre\\\\DAV\\\\Tree->copyNode(Object(OCA\\\\DAV\\\\Upload\\\\FutureFile), Object(OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory), 'data2.img')\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Tree.php(161): Sabre\\\\DAV\\\\Tree->copy('uploads\\\/ivan\\\/17...', 'files\\\/ivan\\\/Docu...')\\n#3 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(642): Sabre\\\\DAV\\\\Tree->move('uploads\\\/ivan\\\/17...', 'files\\\/ivan\\\/Docu...')\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpMove(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(479): Sabre\\\\Event\\\\EventEmitter->emit('method:MOVE', Array)\\n#7 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(298): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#10 \\\/var\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/var\\\/www\\\/ownclo...')\\n#11 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php\",\"Line\":184}"}
Which shows the checksum mismatch (but note that it is dumped just before the upload begins, not after) and the lock error.
In Apache’s error log I have:
[Wed May 29 15:41:15.877856 2019] [proxy_fcgi:error] [pid 1425:tid 2687474496] (70007)The timeout specified has expired: [client 192.168.1.114:37952] AH01075: Error dispatching request to : (polling)
In requests log:
[29/May/2019:15:40:35 +0200] 192.168.1.114 TLSv1.3 TLS_AES_256_GCM_SHA384 "PROPFIND /owncloud/remote.php/dav/files/ivan/ HTTP/1.1" 398
[29/May/2019:15:41:09 +0200] 192.168.1.114 TLSv1.3 TLS_AES_256_GCM_SHA384 "PROPFIND /owncloud/remote.php/dav/files/ivan/ HTTP/1.1" 398
[29/May/2019:15:40:15 +0200] 192.168.1.114 TLSv1.3 TLS_AES_256_GCM_SHA384 "MOVE /owncloud/remote.php/dav/uploads/ivan/1760773490/.file HTTP/1.1" 247
[29/May/2019:15:41:28 +0200] 192.168.1.114 TLSv1.3 TLS_AES_256_GCM_SHA384 "GET /owncloud/ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1" 108
And, in access log:
192.168.1.114 - - [29/May/2019:15:41:09 +0200] "PROPFIND /owncloud/remote.php/dav/files/ivan/ HTTP/1.1" 207 398
192.168.1.114 - - [29/May/2019:15:40:15 +0200] "MOVE /owncloud/remote.php/dav/uploads/ivan/1760773490/.file HTTP/1.1" 504 247
192.168.1.114 - - [29/May/2019:15:41:28 +0200] "GET /owncloud/ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1" 200 108
192.168.1.114 - - [29/May/2019:15:41:43 +0200] "PROPFIND /owncloud/remote.php/dav/files/ivan/ HTTP/1.1" 207 398
So, looking at this, I suppose that the root cause of the errors are the timeouts, but I don’t know what the lock and checksum mismatch means…
Also, I don’t know where to tweak that timeout. I have set:
max_execution_time in php.ini
max_input_time in php.ini
upload_max_filesize and post_max_size in php.ini
upload_max_filesize and post_max_size in .user.ini
to huge values (1 hour for times, 16GB for sizes).
Any ideas?
