After fresh installation of Owncloud on shared hosting server, the Desktop App (2.6.3) tries to send all files to the server. It works with most of the files, but many (>100) files don’t go up, an error is displayed: Server answered with “510 not Extended” to "PUT https://owncloud.homepage.ch/remote.php/dav/uploads/user/…/0000000000000000.
Oddly, I can upload the file in the browser-App (same folder source) without any problem.
The files seem to be randomly selected (jpg, pdf, exe, mp3, mp4, avi, mov…), large and small size, old and newer - I could not find any pattern, which files go and which do not go to the server.
By the way: same behavior when I start the synchronisation from an other PC.
Any ideas?
Thanks for your help!
Desktop App should upload all files after new installation of owncloud on server.
Some “randomly selected” files are not uploaded, Error 510 Not Extended
- new server installation
- new desktop installation
- move all folders and files from the old owncloud folder to the new one
PHP version: 7.2
ownCloud version: 10.5.0
Client version: 2.6.3
Operating system: Windows 10 Home x64
OS language:
Installation path of client:
logs.
Client logfile: Output of
owncloud --logwindow
orowncloud --logfile log.txt
(On Windows usingcmd.exe
, you might need to firstcd
into the ownCloud directory)
(See also http://doc.owncloud.org/desktop/2.2/troubleshooting.html#client-logfile ) -
Web server error log:
Config report: config_report_20201028.txt (307.1 KB)
