8.2 Files Not Found Exception
Running owncloud on a redhat 6.6 machine. This server has been working fine for some weeks. It had an odd glitch where the ldap password needed to be reset, but then worked again fine. As of this week, with no known changes to the system, an owncloud web connection immediately gives the message “Internal Service Error” (see log including NotFoundException below). All commands seem fine using the command line interface occ as user “apache”, the user associated with the web server. For instance, occ ldap:test-config shows “The configuration is valid and the connection could be established”. Similarly, occ files:scan USER proceeds with no errors.
Operating system: Redhat 6.6
Web server: Apache 2.4.12-3
Database: MariaDB 5.5.41-12
PHP version: 5.6.5
ownCloud version (see ownCloud admin page): 8.2.7.1.1
ownCloud log):
{"reqId":"V@rYzLJkvxxvah2e3auwcQAAAAc","remoteAddr":"128.138.140.30","app":"index","message":"Exception: {\"Exception\":\"OCP\\\\Files\\\\NotFoundException\",\"Message\":\"\",\"Code\":0,\"Trace \":\"
#0 /var/www/html/owncloud/apps/files/index.php(92): OC_Helper::getStorageInfo('\\\/', false)
#1 /var/www/html/owncloud/lib/private/route/route.php(154) : runtime-created function(1): require_once('\\\/var\\\/www\\\/html\\\/o...')
#2 [internal function]: __lambda_func(Array)
#3 /var/www/html/owncloud/lib/private/route/router.php(291): call_user_func('\\\\x00lambda_58', Array)
#4 /var/www/html/owncloud/lib/base.php(853): OC\\\\Route\\\\Router->match('\\\/apps\\\/files\\\/')
#5 /var/www/html/owncloud/index.php(39): OC::handleRequest()
#6 {main}\",\"File\":\"/var/www/html/owncloud/lib/private/helper.php\",\"Line\":841}","level": 3,"time":"2016-09-27T14:38:37-06:00"}
{"reqId":"V@rYzf0pEGeiBEw4DoaYuwAAAAM","remoteAddr":"128.138.140.30","app":"index","message":"Exception: {\"Exception\":\"OCP\\\\Files\\\\NotFoundException\",\"Message\":\"\",\"Code\":0,\"Trace\":\"
#0 /var/www/html/owncloud/lib/private/files/node/node.php(221): OC\\\\Files\\\\Node\\\\Node->getFileInfo()
#1 /var/www/html/owncloud/lib/private/files/node/node.php(104): OC\\\\Files\\\\Node\\\\Node->getPermissions()
#2 /var/www/html/owncloud/lib/private/files/node/folder.php(139): OC\\\\Files\\\\Node\\\\Node->checkPermissions(4)
#3 /var/www/html/owncloud/lib/private/files/node/root.php(346): OC\\\\Files\\\\Node\\\\Folder->newFolder('\\\/files')
#4 /var/www/html/owncloud/lib/private/server.php(620): OC\\\\Files\\\\Node\\\\Root->getUserFolder('nefr2840')
#5 /var/www/html/owncloud/apps/gallery/appinfo/application.php(234): OC\\\\Server->getUserFolder('nefr2840')
#6 /var/www/html/owncloud/3rdparty/pimple/pimple/src/Pimple/Container.php(112): OCA\\\\Gallery\\\\AppInfo\\\\Application->OCA\\\\Gallery\\\\AppInfo\\\\{closure}(Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer))
#7 /var/www/html/owncloud/lib/private/appframework/utility/simplecontainer.php(104): Pimple\\\\Container->offsetGet('UserFolder')
#8 /var/www/html/owncloud\apps/gallery/appinfo/application.php(260): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('UserFolder')
#9 /var/www/html/owncloud/3rdparty/pimple/pimple/src/Pimple/Container.php(112): OCA\\\\Gallery\\\\AppInfo\\\\Application->OCA\\\\Gallery\\\\AppInfo\\\\{closure}(Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer))
#10 /var/www/html/owncloud/lib/private/appframework/utility/simplecontainer.php(104): Pimple\\\\Container->offsetGet('Environment')
#11 /var/www/html/owncloud/apps/gallery/appinfo/application.php(327): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('Environment')
#12 /var/www/html/owncloud/3rdparty/pimple/pimple/src/Pimple/Container.php(112): OCA\\\\Gallery\\\\AppInfo\\\\Application->OCA\\\\Gallery\\\\AppInfo\\\\{closure}(Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer))
#13 /var/www/html/owncloud/lib/private/appframework/utility/simplecontainer.php(104): Pimple\\\\Container->offsetGet('ConfigService')
#14 /var/www/html/owncloud/apps/gallery/appinfo/application.php(92): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('ConfigService')
#15 /var/www/html/owncloud/3rdparty/pimple/pimple/src/Pimple/Container.php(112): OCA\\\\Gallery\\\\AppInfo\\\\Application->OCA\\\\Gallery\\\\AppInfo\\\\{closure}(Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer))
#16 /var/www/html/owncloud/lib/private/appframework/utility/simplecontainer.php(104): Pimple\\\\Container->offsetGet('ConfigControlle...')
#17 /var/www/html/owncloud/lib/private/appframework/app.php(92): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('ConfigControlle...')
#18 /var/www/html/owncloud/lib/private/appframework/routing/routeactionhandler.php(45): OC\\\\AppFramework\\\\App::main('ConfigControlle...', 'get', Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer), Array)
#19 [internal function]: OC\\\\AppFramework\\\\routing\\\\RouteActionHandler->__invoke(Array)
#20 /var/www/html/owncloud/lib/private/route/router.php(291): call_user_func(Object(OC\\\\AppFramework\\\\routing\\\\RouteActionHandler), Array)
#21 /var/www/html/owncloud/lib/base.php(853): OC\\\\Route\\\\Router->match('\\\/apps\\\/gallery\\\/c...')
#22 /var/www/html/owncloud/index.php(39): OC::handleRequest()
#23 {main}\",\"File\":\"/var/www/html/owncloud/lib/private/files/node/node.php\",\"Line\":84}","level":3,"
none
Integrity status for oC9+
No status available since all web access results in internal error.
Sorry to bother people here, but this might be of use to others. I cleared the browser and the problem seems to have vanished. Why is it always the last place you look?
