- used yum package manager to upgrade 9.1 to 9.1.1
- ran command to upgrade oc 9.1 to 9.1.1
no errors in log file from core.
I am getting cURL error 77 from core in the log file. Lots of entries.
Operating system: centos 7
Web server: apache 2.4.6
Database: MariaDB 5.5.50
PHP version: 7.0.10
ownCloud version (see ownCloud admin page): 9.1.1
Updated from an older ownCloud or fresh install: updated from 9.1
The oc server houses client data in external NAS.
the cURL 77 error is filling up our logs. Quite strange.
Please post one complete log entry of that “cURL error 77”.
Here is a modified (IP, username and reqid were all changed to ‘xxxx’) log entry.
{“reqId”:“XXXXXXXXXXXXXXXXXXXX”,“remoteAddr”:“xxx.xxx.xxx.xxx”,“app”:“core”,“message”:“cURL error 77: “,“level”:3,“time”:“2016-09-21T06:05:43-04:00”,“method”:“PROPFIND”,“url”:”/owncloud/remote.php/webdav/”,“user”:“xxxxxxx”}
CURLE_SSL_CACERT_BADFILE (77)
Problem with reading the SSL CA cert (path? access rights?)
from libcurl - Error Codes
Seems you have some broken permissions or similar which can happen if the update/upgrade is not done correctly by using a wrong user (e.g. root instead of www-data) or similar.
Just a clarification, I ran the occ upgrade command as root: sudo -u apache php occ upgrade
Can you verify that:
/path/to/owncloud/resources/config/ca-bundle.crt
exists and is readable by that Apache user?
-rw-r–r–. 1 root apache 252451 Sep 19 13:04 ca-bundle.crt
Ok, then please report a new bug to:
One last question. How will this bug impact users? Thanks.
It could be a bug (as it happened after the update from 9.1.0 to 9.1.0) but its not sure. Some one at github might be able to tell you more.
