- Upgraded from 8.2.7.1 to 9.1.0.15
- Problem occurred after upgrade
- Upraded to 9.1.1RC1 problem persists
After Login the Files page should load listing all files
After Login It seems that Files will load but the url changes to apps/files/?dir=/&fileid=30 and seems to be caught in a loop. Icons for the home and plus are redrawn over and over. No navigation to admin or apps or other links can occur.
Operating system: Debian 8.5 (jessie)
Web server: nginx
Database: mysql
PHP version: 5.6.24
ownCloud version (see ownCloud admin page): Not able to view
{“reqId”:“h/VAvSWrmF6L6PW4NTKg”,“remoteAddr”:“45.56.154.12”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 503 Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] Can’t connect to local MySQL server through socket ‘\/var\/run\/mysqld\/mysqld.sock’ (2)","Exception":"Sabre\\DAV\\Exception\\ServiceUnavailable","Code":0,"Trace":"#0 [internal function]: {closure}(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#1 \/home\/ceylon\/apps\/owncloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Object(Closure), Array)\n#2 \/home\/ceylon\/apps\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(456): Sabre\\Event\\EventEmitter->emit(‘beforeMethod’, Array)\n#3 \/home\/ceylon\/apps\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#4 \/home\/ceylon\/apps\/owncloud\/remote.php(68): Sabre\\DAV\\Server->exec()\n#5 \/home\/ceylon\/apps\/owncloud\/remote.php(140): handleException(Object(Doctrine\\DBAL\\DBALException))\n#6 {main}","File":"\/home\/ceylon\/apps\/owncloud\/remote.php","Line":66}”,“level”:4,“time”:“2016-08-03T04:49:41+00:00”}
{“reqId”:“h8Mnw9hEBDa6ahBZShe+”,“remoteAddr”:“45.56.154.12”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 503 Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] Can’t connect to local MySQL server through socket ‘\/var\/run\/mysqld\/mysqld.sock’ (2)","Exception":"Sabre\\DAV\\Exception\\ServiceUnavailable","Code":0,"Trace":"#0 [internal function]: {closure}(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#1 \/home\/ceylon\/apps\/owncloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Object(Closure), Array)\n#2 \/home\/ceylon\/apps\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(456): Sabre\\Event\\EventEmitter->emit(‘beforeMethod’, Array)\n#3 \/home\/ceylon\/apps\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#4 \/home\/ceylon\/apps\/owncloud\/remote.php(68): Sabre\\DAV\\Server->exec()\n#5 \/home\/ceylon\/apps\/owncloud\/remote.php(140): handleException(Object(Doctrine\\DBAL\\DBALException))\n#6 {main}","File":"\/home\/ceylon\/apps\/owncloud\/remote.php","Line":66}”,“level”:4,“time”:“2016-08-03T04:49:43+00:00”}
{“reqId”:“ibVWn50vMMpHwXRWR6Et”,“remoteAddr”:“45.56.154.12”,“app”:“core”,“message”:“starting upgrade from 8.2.5.2 to 8.2.7.1”,“level”:0,“time”:“2016-08-03T04:59:13+00:00”,“method”:“GET”,“url”:“/core/ajax/update.php?requesttoken=djIkATBSECE%2BYTI7Nh4UFigvJgEtWyAJcVxEWwYk%3A%2FwE3G3SrYSAwZRnnbarwx3xa%2Bhvc3e”}
{“reqId”:“ibVWn50vMMpHwXRWR6Et”,“remoteAddr”:“45.56.154.12”,“app”:“PHP”,“message”:“file_put_contents(/home/ceylon/apps/owncloud-data/data/.htaccess): failed to open stream: Permission denied at /home/ceylon/apps/owncloud/lib/private/setup.php#456”,“level”:3,“time”:“2016-08-03T04:59:13+00:00”,“method”:“GET”,“url”:“/core/ajax/update.php?requesttoken=djIkATBSECE%2BYTI7Nh4UFigvJgEtWyAJcVxEWwYk%3A%2FwE3G3SrYSAwZRnnbarwx3xa%2Bhvc3e”}
{“reqId”:“kDDJe6BvFjuvvs+T0c39”,“remoteAddr”:“45.56.154.6”,“app”:“index”,“message”:“Exception: {"Exception":"OC\\NeedsUpdateException","Message":"","Code":0,"Trace":"#0 \/home\/ceylon\/apps\/owncloud\/lib\/private\/legacy\/app.php(119): OC_App::loadApp(‘files’)\n#1 \/home\/ceylon\/apps\/owncloud\/lib\/private\/legacy\/util.php(135): OC_App::loadApps(Array)\n#2 \/home\/ceylon\/apps\/owncloud\/lib\/base.php(890): OC_Util::setupFS()\n#3 \/home\/ceylon\/apps\/owncloud\/index.php(39): OC::handleRequest()\n#4 {main}","File":"\/home\/ceylon\/apps\/owncloud\/lib\/private\/legacy\/app.php","Line":147}”,“level”:3,“time”:“2016-08-03T18:34:06+00:00”,“method”:“GET”,“url”:“/index.php/core/js/oc.js?v=9b11f4bd905584e1ffbbc3f2a37db331”,“user”:“–”}
{“reqId”:“j9gi5EBCCBNksjMZkYhn”,“remoteAddr”:“45.56.154.6”,“app”:“core”,“message”:“starting upgrade from 8.2.7.1 to 9.1.0.15”,“level”:0,“time”:“2016-08-03T18:34:19+00:00”,“method”:“GET”,“url”:“/core/ajax/update.php?requesttoken=Yh4XR1cgWyEUF2NUORgYMwwSNgUEHxsnEzMVWwASBiY%3D%3A%2Fwy7oQtYVYV3W73wbVlTJg%2FAYFQioPDS9bzaCOqSOaU%3D”,“user”:“–”}
{“reqId”:“j9gi5EBCCBNksjMZkYhn”,“remoteAddr”:“45.56.154.6”,“app”:“core”,“message”:“Exception: {"Exception":"Exception","Message":"Updates between multiple major versions and downgrades are unsupported.","Code":0,"Trace":"#0 \/home\/ceylon\/apps\/owncloud\/lib\/private\/Updater.php(150): OC\\Updater->doUpgrade(‘9.1.0.15’, ‘8.2.7.1’)\n#1 \/home\/ceylon\/apps\/owncloud\/core\/ajax\/update.php(193): OC\\Updater->upgrade()\n#2 {main}","File":"\/home\/ceylon\/apps\/owncloud\/lib\/private\/Updater.php","Line":210}”,“level”:3,“time”:“2016-08-03T18:34:19+00:00”,“method”:“GET”,“url”:“/core/ajax/update.php?requesttoken=Yh4XR1cgWyEUF2NUORgYMwwSNgUEHxsnEzMVWwASBiY%3D%3A%2Fwy7oQtYVYV3W73wbVlTJg%2FAYFQioPDS9bzaCOqSOaU%3D”,“user”:“–”}
{“reqId”:“c2cH7AomT3TQ6cVPqJeW”,“remoteAddr”:“45.56.154.6”,“app”:“index”,“message”:“Exception: {"Exception":"OC\\NeedsUpdateException","Message":"","Code":0,"Trace":"#0 \/home\/ceylon\/apps\/owncloud\/lib\/private\/app.php(117): OC_App::loadApp(‘files’)\n#1 \/home\/ceylon\/apps\/owncloud\/lib\/private\/util.php(137): OC_App::loadApps(Array)\n#2 \/home\/ceylon\/apps\/owncloud\/lib\/base.php(906): OC_Util::setupFS()\n#3 \/home\/ceylon\/apps\/owncloud\/index.php(39): OC::handleRequest()\n#4 {main}","File":"\/home\/ceylon\/apps\/owncloud\/lib\/private\/app.php","Line":142}”,“level”:3,“time”:“2016-08-03T18:40:43+00:00”,“method”:“GET”,“url”:“/index.php/core/js/oc.js?v=0e6e9fae78ebb4204933aa2ea5f7fdef”,“user”:“–”}
{“reqId”:“MLG2sSytsI5KJZDTSIhK”,“remoteAddr”:“45.56.154.6”,“app”:“core”,“message”:“starting upgrade from 8.2.7.1 to 9.0.4.1”,“level”:0,“time”:“2016-08-03T18:40:51+00:00”,“method”:“GET”,“url”:“/core/ajax/update.php?requesttoken=JUZfFgkkTSI4IgMePUsbKkVxKggAE04DOgBwHSYLdy0%3D%3Ah%2F1f1UbZzl6ySd0n%2B5pYNkzepu4%2FII5XxdLxY%2F0IFg4%3D”,“user”:“–”}
{“reqId”:“MLG2sSytsI5KJZDTSIhK”,“remoteAddr”:“45.56.154.6”,“app”:“PHP”,“message”:“file_put_contents(/home/ceylon/apps/owncloud-data/data/.htaccess): failed to open stream: Permission denied at /home/ceylon/apps/owncloud/lib/private/setup.php#485”,“level”:3,“time”:“2016-08-03T18:40:51+00:00”,“method”:“GET”,“url”:“/core/ajax/update.php?requesttoken=JUZfFgkkTSI4IgMePUsbKkVxKggAE04DOgBwHSYLdy0%3D%3Ah%2F1f1UbZzl6ySd0n%2B5pYNkzepu4%2FII5XxdLxY%2F0IFg4%3D”,“user”:“–”}
{“reqId”:“MLG2sSytsI5KJZDTSIhK”,“remoteAddr”:“45.56.154.6”,“app”:“core”,“message”:“No update found at the ownCloud appstore for app 166054”,“level”:0,“time”:“2016-08-03T18:40:58+00:00”,“method”:“GET”,“url”:“/core/ajax/update.php?requesttoken=JUZfFgkkTSI4IgMePUsbKkVxKggAE04DOgBwHSYLdy0%3D%3Ah%2F1f1UbZzl6ySd0n%2B5pYNkzepu4%2FII5XxdLxY%2F0IFg4%3D”,“user”:“–”}
{“reqId”:“OBjLmWcrXqJjmOAgUYzo”,“remoteAddr”:“88.90.64.55”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 503 System in maintenance mode.","Exception":"Sabre\\DAV\\Exception\\ServiceUnavailable","Code":0,"Trace":"#0 [internal function]: OCA\\DAV\\Connector\\Sabre\\MaintenancePlugin->checkMaintenanceMode(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#1 \/home\/ceylon\/apps\/owncloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#2 \/home\/ceylon\/apps\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(446): Sabre\\Event\\EventEmitter->emit(‘beforeMethod’, Array)\n#3 \/home\/ceylon\/apps\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(248): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#4 \/home\/ceylon\/apps\/owncloud\/apps\/dav\/appinfo\/v1\/webdav.php(55): Sabre\\DAV\\Server->exec()\n#5 \/home\/ceylon\/apps\/owncloud\/remote.php(138): require_once(‘\/home\/ceylon\/ap…’)\n#6 {main}","File":"\/home\/ceylon\/apps\/owncloud\/apps\/dav\/lib\/connector\/sabre\/maintenanceplugin.php","Line":84,"User":"bwalker"}”,“level”:4,“time”:“2016-08-04T06:45:28+00:00”,“method”:“PROPFIND”,“url”:“/remote.php/webdav/”,“user”:“bwalker”}
{“reqId”:“05rQVBbIbvcHnfsWeudJ”,“remoteAddr”:“88.90.64.55”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 503 System in maintenance mode.","Exception":"Sabre\\DAV\\Exception\\ServiceUnavailable","Code":0,"Trace":"#0 [internal function]: OCA\\DAV\\Connector\\Sabre\\MaintenancePlugin->checkMaintenanceMode(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#1 \/home\/ceylon\/apps\/owncloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#2 \/home\/ceylon\/apps\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(446): Sabre\\Event\\EventEmitter->emit(‘beforeMethod’, Array)\n#3 \/home\/ceylon\/apps\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(248): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#4 \/home\/ceylon\/apps\/owncloud\/apps\/dav\/appinfo\/v1\/webdav.php(55): Sabre\\DAV\\Server->exec()\n#5 \/home\/ceylon\/apps\/owncloud\/remote.php(138): require_once(‘\/home\/ceylon\/ap…’)\n#6 {main}","File":"\/home\/ceylon\/apps\/owncloud\/apps\/dav\/lib\/connector\/sabre\/maintenanceplugin.php","Line":84,"User":"bwalker"}”,“level”:4,“time”:“2016-08-04T06:45:29+00:00”,“method”:“PROPFIND”,“url”:“/remote.php/webdav/”,“user”:“bwalker”}
{“reqId”:“yTUOXFqVJp/Bsq75XO4H”,“remoteAddr”:“88.90.64.55”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 503 System in maintenance mode.","Exception":"Sabre\\DAV\\Exception\\ServiceUnavailable","Code":0,"Trace":"#0 [internal function]: OCA\\DAV\\Connector\\Sabre\\MaintenancePlugin->checkMaintenanceMode(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#1 \/home\/ceylon\/apps\/owncloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#2 \/home\/ceylon\/apps\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(446): Sabre\\Event\\EventEmitter->emit(‘beforeMethod’, Array)\n#3 \/home\/ceylon\/apps\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(248): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#4 \/home\/ceylon\/apps\/owncloud\/apps\/dav\/appinfo\/v1\/webdav.php(55): Sabre\\DAV\\Server->exec()\n#5 \/home\/ceylon\/apps\/owncloud\/remote.php(138): require_once(‘\/home\/ceylon\/ap…’)\n#6 {main}","File":"\/home\/ceylon\/apps\/owncloud\/apps\/dav\/lib\/connector\/sabre\/maintenanceplugin.php","Line":84,"User":"bwalker"}”,“level”:4,“time”:“2016-08-04T06:46:02+00:00”,“method”:“PROPFIND”,“url”:“/remote.php/webdav/”,“user”:“bwalker”}
{“reqId”:“Wk/OdEUBb9SLjisoiZ3L”,“remoteAddr”:“45.56.154.6”,“app”:“index”,“message”:“Exception: {"Exception":"OC\\NeedsUpdateException","Message":"","Code":0,"Trace":"#0 \/home\/ceylon\/apps\/owncloud\/lib\/private\/legacy\/app.php(119): OC_App::loadApp(‘federation’)\n#1 \/home\/ceylon\/apps\/owncloud\/lib\/base.php(861): OC_App::loadApps(Array)\n#2 \/home\/ceylon\/apps\/owncloud\/index.php(39): OC::handleRequest()\n#3 {main}","File":"\/home\/ceylon\/apps\/owncloud\/lib\/private\/legacy\/app.php","Line":147}”,“level”:3,“time”:“2016-08-04T06:52:23+00:00”,“method”:“GET”,“url”:“/core/js/oc.js?v=0012d373879b00d2fc85bca2de2c6330”,“user”:“–”}
{“reqId”:“3phmbAKUEzbr0c5m3+vo”,“remoteAddr”:“45.56.154.6”,“app”:“core”,“message”:“starting upgrade from 9.0.4.1 to 9.1.0.15”,“level”:0,“time”:“2016-08-04T06:52:33+00:00”,“method”:“GET”,“url”:“/core/ajax/update.php?requesttoken=P1gqPhcJBBs9Oi0TIgsOL3cYXSQaLSQMOTNAeTh0OmM%3D%3AT0azUKbAjbzqAdCZ6bljNUbuje72r7jQasGshMIJk7w%3D”,“user”:“–”}
{“reqId”:“3phmbAKUEzbr0c5m3+vo”,“remoteAddr”:“45.56.154.6”,“app”:“PHP”,“message”:“file_put_contents(/home/ceylon/apps/owncloud-data/data/.htaccess): failed to open stream: Permission denied at /home/ceylon/apps/owncloud/lib/private/Setup.php#500”,“level”:3,“time”:“2016-08-04T06:52:33+00:00”,“method”:“GET”,“url”:“/core/ajax/update.php?requesttoken=P1gqPhcJBBs9Oi0TIgsOL3cYXSQaLSQMOTNAeTh0OmM%3D%3AT0azUKbAjbzqAdCZ6bljNUbuje72r7jQasGshMIJk7w%3D”,“user”:“–”}
{“reqId”:“9ybEvGAxfdtVsfyS7PM7”,“remoteAddr”:“45.56.154.6”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-04T08:13:21+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/”,“user”:“–”}
{“reqId”:“8nDgnwgykNfDH+/6QAjM”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:30:04+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/”,“user”:“–”}
{“reqId”:“H16DWX3cmBv1HZdM3tHg”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:30:08+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Nate”,“user”:“–”}
{“reqId”:“dmlj6Mpxgay52vcsD22D”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:30:17+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/”,“user”:“–”}
{“reqId”:“/HPiagzk217ZwTBwhL6d”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:30:19+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Rachel”,“user”:“–”}
{“reqId”:“VtAQPQ4f/6Oiz4z21in+”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:32:12+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/”,“user”:“–”}
{“reqId”:“C8BsRV423COqRHwJsvT7”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:33:14+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Rachel”,“user”:“–”}
{“reqId”:“WiN6CB0wyx1TqAE+3vjL”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:48:48+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Rachel”,“user”:“–”}
{“reqId”:“R0XiDFjPqivD+gsEH9AG”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:49:37+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/”,“user”:“–”}
{“reqId”:“GvT3x1IrVY11ExvF0FPJ”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:49:42+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Rachel”,“user”:“–”}
{“reqId”:“tCoOAg7VdTpFOsBoBhU8”,“remoteAddr”:“88.249.172.125”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:50:00+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Rachel”,“user”:“–”}
{“reqId”:“BFNWk8G7zzQuhSE3LvRk”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:50:11+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Rachel”,“user”:“–”}
{“reqId”:“aC3BITc7U1hWeTgbpJFb”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:50:56+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Rachel”,“user”:“–”}
{“reqId”:“24hJEc7jpPZ3pkBq3Bq1”,“remoteAddr”:“88.249.172.125”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:53:12+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Rachel”,“user”:“–”}
{“reqId”:“AZUsBn+t2llA6FAm50YU”,“remoteAddr”:“88.249.172.125”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:53:38+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Rachel”,“user”:“–”}
{“reqId”:“Vti8lWhxZl71CbqfYLpa”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:54:22+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/”,“user”:“–”}
{“reqId”:“9oyFowJjFYL6c2+P9Lrc”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:54:42+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Rachel”,“user”:“–”}
{“reqId”:“vbQXFCz3fYMeUI4ShRgl”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:55:05+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Rachel”,“user”:“–”}
{“reqId”:“rs2YV3QD1ZUcOE4uum6K”,“remoteAddr”:“88.249.172.125”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:57:33+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Rachel”,“user”:“–”}
{“reqId”:“EgaJ0CioW4ebYQ1XQtoE”,“remoteAddr”:“88.249.172.125”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:57:39+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/”,“user”:“–”}
{“reqId”:“OoNLil5aORAr4RqLjos4”,“remoteAddr”:“88.249.172.125”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:57:42+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Nate”,“user”:“–”}
{“reqId”:“2KhkAIQE6lRJygzLTQH4”,“remoteAddr”:“88.249.172.125”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:57:55+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Nate”,“user”:“–”}
{“reqId”:“hAtKH17M2//24+EQZa6W”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:59:10+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Nate”,“user”:“–”}
{“reqId”:“CNZuyz1vOOMRxX2dVEKf”,“remoteAddr”:“88.249.172.125”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:59:19+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Nate”,“user”:“–”}
{“reqId”:“XYFsFFdhcWZD7uwsUzAT”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T07:59:30+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Nate”,“user”:“–”}
{“reqId”:“0aHLm48TiCE87tQkjYfz”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T09:11:19+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/”,“user”:“–”}
{“reqId”:“0tU1yqlixn6zhd6sDyz3”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T09:11:24+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Nate”,“user”:“–”}
{“reqId”:“d3G1+EaD2t+lO8GJeBKk”,“remoteAddr”:“92.44.112.224”,“app”:“filesystem”,“message”:“Storage wrapper ‘sharePermissions’ was not registered via the ‘OC_Filesystem - preSetup’ hook which could cause potential problems.”,“level”:2,“time”:“2016-08-05T09:12:15+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/Nate”,“user”:“–”}
{“reqId”:“sWeehjxmONzsy9BuBLsH”,“remoteAddr”:“”,“app”:“core”,“message”:“starting upgrade from 9.1.0.15 to 9.1.1.0”,“level”:0,“time”:“2016-09-01T07:43:42+00:00”,“method”:“–”,“url”:“–”,“user”:“–”}
{“reqId”:“sWeehjxmONzsy9BuBLsH”,“remoteAddr”:“”,“app”:“PHP”,“message”:“file_put_contents(/home/ceylon/apps/owncloud-data/data/.htaccess): failed to open stream: Permission denied at /home/ceylon/apps/owncloud/lib/private/Setup.php#500”,“level”:3,“time”:“2016-09-01T07:43:42+00:00”,“method”:“–”,“url”:“–”,“user”:“–”}
data folder in a separate location than owncloud root
Integrity status for oC9+
