Was upgrading from 9.1.5 to 10.0.4 using the package installer and ran into a problem.
Repair warning: The file cache contains entries with invalid path values for the following storage numeric ids: 1 48 4
Repair warning: Please run occ files:scan --all --repair to repairall affected storages or run `occ files:scan userid --repair for each user with affected storages
So I then ran these commands:
sudo -u www-data php occ maintenance:mode --off
sudo -u www-data php occ maintenance:singleuser --on
sudo -u www-data php occ files:scan --all --repair
However after 20 minutes it was still at 0% suggesting that this process was going to take a very long time. (We do have quite a bit of data so this is not surprising)
A few quesitons that maybe you might be able to help me with ![]()
- Do storage numeric ids: 1 48 4 point to 3 files with those numeric ids?
- If yes what command do you execute to find these files?
Perhaps we don’t need them is what I am thinking…
Thank you for taking time to read this post. Any ideas or comments you have are most welcome.
Ian
