Issue
I just had to restart my server, had to restart owncloud and its database, and now I’m getting a 500 error when trying to connect to owncloud. The owncloud logs show the following error:
owncloud_1 | [Thu Jun 28 18:00:52.317889 2018] [:error] [pid 26] [client 82.4.110.98:62450] PHP Fatal error: Uncaught exception 'Doctrine\\DBAL\\DBALException' with message 'Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [1045] Access denied for user 'oc_myusername'@'172.20.0.3' (using password: YES)' in /var/www/html/lib/private/DB/Connection.php:58\nStack trace:\n#0 /var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(621): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/html/lib/private/DB/Connection.php(141): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrine in /var/www/html/lib/private/DB/Connection.php on line 58
Background
I run owncloud in a docker container, using mariadb as its database. Here’s my docker-compose.yml:
version: '2'
services:
owncloud:
image: owncloud:9.1
container_name: fullbackup_owncloud
links:
- owncloud_db
ports:
- portnumber:portnumber
volumes:
- "~/fullbackup/data:/var/www/html/data"
- "~/fullbackup/owncloud_config:/var/www/html/config"
restart: always
owncloud_db:
image: mariadb
container_name: fullbackup_db
environment:
MYSQL_ROOT_PASSWORD: apassword
restart: always
In my host’s ~/fullbackup/owncloud_config I have the following config.php:
<?php
$CONFIG = array (
'instanceid' => 'someid',
'passwordsalt' => 'somesalt',
'secret' => 'somesecret',
'trusted_domains' =>
array (
0 => 'myip',
'datadirectory' => '/var/www/html/data',
'overwrite.cli.url' => 'myip:someport',
'dbtype' => 'mysql',
'version' => '9.1.5.2',
'dbname' => 'fullbackup_database_name',
'dbhost' => 'owncloud_db',
'dbtableprefix' => 'oc_',
'dbuser' => 'oc_myusername',
'dbpassword' => 'anotherpassword',
'logtimezone' => 'UTC',
'installed' => true,
'filelocking.enabled' => false,
I’ve been able to thus run owncloud smoothly for using just docker-compose up
What I’ve tried
I’ve tried to follow the advice here:
$ docker exec -ti fullbackup owncloud_db
$ mysql_upgrade --force -u root -p
Phase 1/6: Checking and upgrading mysql database
Processing databases
mysql
mysql.column_stats OK
mysql.columns_priv OK
mysql.db OK
mysql.event OK
mysql.func OK
mysql.gtid_slave_pos OK
mysql.help_category OK
mysql.help_keyword OK
mysql.help_relation OK
mysql.help_topic OK
mysql.host OK
mysql.index_stats OK
mysql.innodb_index_stats OK
mysql.innodb_table_stats OK
mysql.plugin OK
mysql.proc OK
mysql.procs_priv OK
mysql.proxies_priv OK
mysql.roles_mapping OK
mysql.servers OK
mysql.table_stats OK
mysql.tables_priv OK
mysql.time_zone OK
mysql.time_zone_leap_second OK
mysql.time_zone_name OK
mysql.time_zone_transition OK
mysql.time_zone_transition_type OK
mysql.user OK
Phase 2/6: Fixing views
Phase 3/6: Running 'mysql_fix_privilege_tables'
Phase 4/6: Fixing table and database names
Phase 5/6: Checking and upgrading tables
information_schema
performance_schema
Phase 6/6: Running 'FLUSH PRIVILEGES'
OK
But I get the same error.
I’ve also seen the advice here:
But this won’t let me use the pre-existing db user.
Any thoughts on what I can do to fix this?
Thanks!
