I’m facing an issue with my personnal owncloud setup (using raspberry pi 2).
Everrything was working fine until a few days.
Last week I noticed some files were impossible to sync with server (sync from on computer, and failed to be sync a second one). The second PC got errors like “sync canceled” or connection lost… I updated everthing since (Firmware and OS) and did not got any such thing yet. So I considered this as solved…
But then I just found myself unable to reach the admin panel. Once I logged in as admin, if I click on admin panel on the menu, the page loads forever and my server load start rising and do not stop until server got totaly unusable or before I restart apache.
It behaves like an infinite loop or I don’t know.
I have quite a big cloud (200GB). Could this be a raison for this ?
I can browse through all my files on the web interface, the admin panel is really the only thing causing troubles…
Thanks for your help.
Tristan
I use OC 9.1.0 on raspbian.
The raspberry does not run on the SD card but on an external hard drive.
