Hi Community,
I just installed owncloud 10.0.3 by importing the .ova into VMware ESXi 6.5, but now I cannot connect to the server using the Windows desktop client; connecting through browser interface however is possible.
- Install owncloud server 10.0.3 by imporitng the appropriate .ova into ESXi
- configure owncloud server through web-interface accorind to whitepaper
3.created new user account in web interface - downloaded and installed desktop client for Windows on Windows 7
- entered serverâs address and login credentials
Logging on to owncloud server and being able to sync files
desktop client shows error message "no connection to owncloud on http://owncloud.testorganisation.intranet. server answered with â404 Not Foundâ on âPROPFIND http://owncloud.tzestorganisation.intranet/remote.php/webdav/â
owncloud appliance 10.0.3
10.0.3
fresh install
Accessing the mentioned link leads to a 404 error
"basic": {
"license key": "***REMOVED SENSITIVE VALUE***",
"date": "Thu, 01 Mar 2018 18:22:56 +0100",
"ownCloud version": "10.0.3.3",
"ownCloud version string": "10.0.3",
"ownCloud edition": "Community",
"server OS": "Linux",
"server OS version": "Linux owncl-39187853 4.9.0-ucs107-amd64 #1 SMP Debian 4.9.30-2A~4.2.0.201801110837 (2018-01-11) x86_64",
"server SAPI": "apache2handler",
"webserver version": "Apache",
"hostname": "192.168.50.235",
"user count": 2,
"user directories": 2,
"logged-in user": "owncloud"
"config": {
"data_directory": "/var/lib/univention-appcenter/apps/owncloud/data/files",
"apps_paths": [
"path": "/var/www/owncloud/apps",
"url": "/apps",
"writable": false
"path": "/var/www/owncloud/custom",
"url": "/custom",
"writable": true
"dbtype": "mysql",
"dbhost": "172.17.42.1:3306",
"dbname": "owncloud",
"dbtableprefix": "oc_",
"trusted_domains": [
"192.168.50.235"
"datadirectory": "/var/lib/univention-appcenter/apps/owncloud/data/files",
"overwrite.cli.url": "http://localhost/owncloud",
"version": "10.0.3.3",
"logtimezone": "UTC",
"installed": true,
"instanceid": "ocnmkgwc20io",
"filelocking.enabled": "false",
"loglevel": "0",
"default_language": "en",
"htaccess.RewriteBase": "/owncloud",
"log_rotate_size": 104857600,
"onlyoffice": {
"verify_peer_off": true
"integritychecker": {
"passing": true,
"enabled": true,
"result": []
"core": {
"backgroundjobs_mode": "cron",
"installedat": "1519913929.565",
"lastcron": "1519924921",
"lastupdateResult": "{\"version\":\"10.0.7\",\"versionstring\":\"ownCloud 10.0.7\",\"url\":\"https:\\/\\/download.owncloud.org\\/community\\/owncloud-10.0.7.zip\",\"web\":\"https:\\/\\/doc.owncloud.org\\/server\\/10.0\\/admin_manual\\/maintenance\\/upgrade.html\"}",
"lastupdatedat": "1519924844",
"public_files": "files_sharing/public.php",
"public_webdav": "dav/appinfo/v1/publicwebdav.php"
"apps": [
"id": "configreport",
"name": "Admin Config Report",
"description": "Generate a Config Report",
"licence": "AGPL",
"author": "owncloud.org",
"version": "0.1.1",
"namespace": "ConfigReport",
"default_enable": [
"types": [
"filesystem"
"dependencies": {
"owncloud": {
"@attributes": {
"min-version": "9.1",
"max-version": "10.0"
"shipped": "true",
"commands": {
"command": "OCA\\ConfigReport\\Command\\ConfigReport"
"settings": {
"admin": "OCA\\ConfigReport\\AdminPanel"
"info": [],
"remote": [],
"public": [],
"repair-steps": {
"install": [],
"pre-migration": [],
"post-migration": [],
"live-migration": [],
"uninstall": []
"background-jobs": [],
"two-factor-providers": [],
"groups": null,
"active": true,
"internal": true,
"level": 200,
"removable": false,
"appconfig": {
"enabled": "yes",
"installed_version": "0.1.1",
"types": "filesystem"
"id": "market",
"name": "Market",
"summary": "Integrate the ownCloud marketplace into your ownCloud",
"description": "Easily manage ownCloud apps from within your ownCloud web interface. It connects your ownCloud with your marketplace account and lets you browse, install and update any apps from inside your ownCloud instance.\n\nPlease note: Since ownCloud X (10.0) every instance gets shipped with this app included. You do not need to install it separately. To use this application click on \"Files\" in the top left corner and click on \"Market\" (cart icon) (Administrator privileges required)",
"licence": "AGPL",
"author": "Thomas MĂŒller, Felix Heidecke, Thomas Börger, Philipp Schaffrath",
"version": "0.2.2",
"default_enable": "",
"category": "tools",
"screenshot": "https://raw.githubusercontent.com/owncloud/screenshots/master/market/ownCloud-market-app.jpg",
"dependencies": {
"owncloud": {
"@attributes": {
"min-version": "10.0",
"background-jobs": {
"job": "OCA\\Market\\CheckUpdateBackgroundJob"
"commands": [
"OCA\\Market\\Command\\InstallApp",
"OCA\\Market\\Command\\UnInstallApp",
"OCA\\Market\\Command\\ListApps",
"OCA\\Market\\Command\\UpgradeApp"
"navigation": {
"@attributes": {
"role": "admin"
"route": "market.page.index",
"order": "100"
"info": [],
"remote": [],
"public": [],
"types": [],
"repair-steps": {
"install": [],
"uninstall": []
"groups": null,
"active": true,
"internal": false,
"level": 100,
"removable": true,
"preview": "/owncloud/apps/market/img/market.svg",
"previewAsIcon": true,
"appconfig": {
"enabled": "yes",
"installed_version": "0.2.2",
"market": "0.2.3",
"types": "",
"user_ldap": "0.10.0"
"id": "templateeditor",
"name": "Mail Template Editor",
"description": "This application enables ownCloud to send custom emails to users. By default, ownCloud can send password reset emails, shared file and share link emails, activity stream notifications and more. By configuring an email server, admins can enable these emails to be sent. By providing an email address on their Personal page, users can receive these emails. By default, all of these emails will contain ownCloud email templates. The template editor allows admins to change email templates for emails sent by the system. While it is possible to manually change email templates within ownCloud, this app makes it far simpler by updating this via the ownCloud admin panel. More information is available in the Mail Template Editor documentation.",
"licence": "AGPL",
"author": "Jörn Dreyer",
"version": "0.1",
"dependencies": {
"owncloud": {
"@attributes": {
"shipped": "true",
"settings": {
"admin": "OCA\\TemplateEditor\\AdminPanel"
"info": [],
"remote": [],
"public": [],
"types": [],
"repair-steps": {
"install": [],
"uninstall": []
"commands": [],
"groups": null,
"active": true,
"internal": false,
"level": 100,
"removable": true,
"preview": "/owncloud/apps/templateeditor/img/app.svg",
"appconfig": {
"enabled": "yes",
"installed_version": "0.1",
"types": ""
"id": "user_ldap",
"name": "LDAP user and group backend",
"description": "This application enables administrators to connect ownCloud to an LDAP-based user directory for authentication and provisioning users, groups and user attributes. Admins can configure this application to connect to one or more LDAP directories or Active Directories via an LDAP interface. Attributes such as user quota, email, avatar pictures, group memberships and more can be pulled into ownCloud from a directory with the appropriate queries and filters.\n\nA user logs into ownCloud with their LDAP or AD credentials, and is granted access based on an authentication request handled by the LDAP or AD server. ownCloud does not store LDAP or AD passwords, rather these credentials are used to authenticate a user and then ownCloud uses a session for the user ID. More information is available in the LDAP User and Group Backend documentation.\n\n",
"licence": "AGPL",
"author": "Dominik Schmidt and Arthur Schiwon",
"version": "0.9.1",
"types": [
"authentication"
"documentation": {
"admin": "https://doc.owncloud.org/server/10.0/go.php?to=admin-ldap"
"category": "integration",
"screenshot": "https://raw.githubusercontent.com/owncloud/screenshots/0527af6b981603f3410982c2ed70051b7cf991c3/user_ldap/user_ldap.png",
"dependencies": {
"lib": "ldap",
"owncloud": {
"@attributes": {
"min-version": "10.0.1",
"max-version": "10.0.99"
"namespace": "User_LDAP",
"job": "OCA\\User_LDAP\\Jobs\\UpdateGroups"
"settings": {
"admin": "OCA\\User_LDAP\\AdminPanel"
"info": [],
"remote": [],
"public": [],
"repair-steps": {
"install": [],
"uninstall": []
"commands": [],
"groups": null,
"active": true,
"internal": false,
"level": 100,
"removable": true,
"preview": "/owncloud/apps/user_ldap/img/app.svg",
"appconfig": {
"enabled": "yes",
"installed_version": "0.9.1",
"s01has_memberof_filter_support": "",
"s01home_folder_naming_rule": "",
"s01last_jpegPhoto_lookup": "0",
"s01ldap_agent_password": "***REMOVED SENSITIVE VALUE***",
"s01ldap_attributes_for_group_search": "",
"s01ldap_attributes_for_user_search": "",
"s01ldap_backup_host": "",
"s01ldap_backup_port": "",
"s01ldap_base": "dc=testorganisation,dc=intranet",
"s01ldap_base_groups": "dc=testorganisation,dc=intranet",
"s01ldap_base_users": "dc=testorganisation,dc=intranet",
"s01ldap_cache_ttl": "600",
"s01ldap_configuration_active": "1",
"s01ldap_display_name": "displayName",
"s01ldap_dn": "cn=owncl-39187853,cn=memberserver,cn=computers,dc=testorganisation,dc=intranet",
"s01ldap_dynamic_group_member_url": "",
"s01ldap_email_attr": "mailPrimaryAddress",
"s01ldap_experienced_admin": "0",
"s01ldap_expert_username_attr": "uid",
"s01ldap_expert_uuid_group_attr": "gidNumber",
"s01ldap_expert_uuid_user_attr": "uid",
"s01ldap_group_display_name": "cn",
"s01ldap_group_filter": "(&(objectclass=posixGroup)(ownCloudEnabled=1))",
"s01ldap_group_filter_mode": "0",
"s01ldap_group_member_assoc_attribute": "memberUid",
"s01ldap_groupfilter_groups": "",
"s01ldap_groupfilter_objectclass": "",
"s01ldap_host": "owncloud.testorganisation.intranet",
"s01ldap_login_filter": "(&(objectclass=person)(ownCloudEnabled=1)(|(uid=%uid)(mailPrimaryAddress=%uid)))",
"s01ldap_login_filter_mode": "0",
"s01ldap_loginfilter_attributes": "",
"s01ldap_loginfilter_email": "0",
"s01ldap_loginfilter_username": "1",
"s01ldap_nested_groups": "0",
"s01ldap_override_main_server": "",
"s01ldap_paging_size": "500",
"s01ldap_port": "7389",
"s01ldap_quota_attr": "ownCloudQuota",
"s01ldap_quota_def": "",
"s01ldap_tls": "0",
"s01ldap_turn_off_cert_check": "0",
"s01ldap_user_display_name_2": "",
"s01ldap_user_filter_mode": "0",
"s01ldap_userfilter_groups": "",
"s01ldap_userfilter_objectclass": "",
"s01ldap_userlist_filter": "(&(objectclass=person)(ownCloudEnabled=1))",
"s01use_memberof_to_detect_membership": "0",
"types": "authentication"
"id": "files_sharing",
"name": "Share Files",
"description": "This application enables users to share files within ownCloud. If enabled, the admin can choose which groups can share files. The applicable users can then share files and folders with other users and groups within ownCloud. In addition, if the admin enables the share link feature, an external link can be used to share files with other users outside of ownCloud. Admins can also enforce passwords, expirations dates, and enable server to server sharing via share links, as well as sharing from mobile devices. Turning the feature off removes shared files and folders on the server for all share recipients, and also on the sync clients and mobile apps. More information is available in the ownCloud Documentation.\n\n",
"licence": "AGPL",
"author": "Michael Gapczynski, Bjoern Schiessle",
"version": "0.10.1",
"types": [
"filesystem"
"use-migrations": "true",
"dependencies": {
"owncloud": {
"@attributes": {
"min-version": "10.0.2.4",
"public": {
"files": "public.php"
"namespace": "Files_Sharing",
"OCA\\Files_Sharing\\DeleteOrphanedSharesJob",
"OCA\\Files_Sharing\\ExpireSharesJob"
"commands": {
"command": "OCA\\Files_Sharing\\Command\\CleanupRemoteStorages"
"info": [],
"remote": [],
"repair-steps": {
"install": [],
"uninstall": []
"groups": null,
"active": true,
"internal": true,
"level": 200,
"removable": false,
"preview": "/owncloud/apps/files_sharing/img/app.svg",
"appconfig": {
"enabled": "yes",
"installed_version": "0.10.1",
"id": "comments",
"name": "Comments",
"description": "Files app plugin to add comments to files",
"licence": "AGPL",
"author": "Arthur Schiwon, Vincent Petry",
"version": "0.3.0",
"dependencies": {
"owncloud": {
"@attributes": {
"types": [
"logging",
"dav"
"sabre": {
"plugins": {
"plugin": "OCA\\Comments\\Dav\\CommentsPlugin"
"collections": {
"collection": "OCA\\Comments\\Dav\\RootCollection"
"info": [],
"remote": [],
"public": [],
"repair-steps": {
"install": [],
"uninstall": []
"commands": [],
"groups": null,
"active": true,
"internal": false,
"level": 100,
"removable": true,
"appconfig": {
"enabled": "yes",
"installed_version": "0.3.0",
"types": "logging,dav"
"id": "firstrunwizard",
"name": "First run wizard",
"description": "This application enables a pop-up window when a user first logs into ownCloud. This window welcomes new users to ownCloud, and contains links to the standard ownCloud desktop client, Android app, and the iOS app. The window also shows a link for accessing ownCloud via WebDAV. At any time, the first run wizard button can be opened again via the link on the personal page. The First run wizard can be customized to meet specific design goals, or to change links and messages. Create an appropriate theme following the Theming documentation, and changes to the look and feel of this Wizard are simple. More information is available in the First run wizard documentation, as well as the theming documentation.",
"licence": "AGPL",
"author": "Frank Karlitschek, Jan-Christoph Borchardt",
"dependencies": {
"owncloud": {
"@attributes": {
"version": "1.1",
"shipped": "true",
"ocsid": "166055",
"info": [],
"remote": [],
"public": [],
"types": [],
"repair-steps": {
"install": [],
"uninstall": []
"commands": [],
"groups": null,
"active": true,
"internal": false,
"level": 100,
"removable": true,
"preview": "/owncloud/apps/firstrunwizard/img/app.svg",
"appconfig": {
"enabled": "yes",
"installed_version": "1.1",
"ocsid": "166055",
"types": ""
"id": "files_trashbin",
"name": "Deleted files",
"description": "This application enables users to restore files that were deleted from the system. It displays a list of deleted files in the web interface, and has options to restore those deleted files back to their ownCloud file directories or remove them permanently from the system. Restoring a file also restores related file versions, if the versions application is enabled. When a file is deleted from a share, it can be restored in the same manner, though it is no longer shared. By default, these files remain in the trash bin for 30 days. To prevent a user from running out of disk space, the ownCloud Deleted files app will not utilize more than 50% of the currently available free quota for deleted files. If the deleted files exceed this limit, ownCloud deletes the oldest files until it gets below this limit. More information is available in the Deleted Files documentation.\n\n",
"licence": "AGPL",
"author": "Bjoern Schiessle",
"version": "0.9.1",
"types": [
"filesystem"
"namespace": "Files_Trashbin",
"dependencies": {
"owncloud": {
"@attributes": {
"documentation": {
"user": "https://doc.owncloud.org/server/10.0/go.php?to=user-trashbin"
"job": "OCA\\Files_Trashbin\\BackgroundJob\\ExpireTrash"
"commands": [
"OCA\\Files_Trashbin\\Command\\CleanUp",
"OCA\\Files_Trashbin\\Command\\ExpireTrash"
"info": [],
"remote": [],
"public": [],
"repair-steps": {
"install": [],
"uninstall": []
"groups": null,
"active": true,
"internal": true,
"level": 200,
"removable": false,
"preview": "/owncloud/apps/files_trashbin/img/app.svg",
"appconfig": {
"enabled": "yes",
"id": "files_antivirus",
"name": "Antivirus App for files",
"description": "This application inspects files that are uploaded to ownCloud for viruses before they are written to the ownCloud storage. If a file is identified as a virus, it is either logged or not uploaded to the server. The application relies on the underlying ClamAV virus scanning engine, which the admin points ownCloud to when configuring the application. For this app to be effective, the ClamAV virus definitions should be kept up to date. Also note that enabling this app will impact system performance as additional processing is required for every upload. More information is available in the Antivirus documentation.",
"bugs": "https://github.com/owncloud/files_antivirus/issues",
"repository": {
"@attributes": {
"type": "git"
"@value": "http://github.com/owncloud/files_antivirus.git"
"licence": "AGPL",
"author": "Manuel Delgado, Bart Visscher, thinksilicon.de, Victor Dubiniuk",
"version": "0.10.1.0",
"types": [
"filesystem"
"dependencies": {
"owncloud": {
"@attributes": {
"min-version": "10.0.3",
"ocsid": "157439",
"settings": {
"admin": "OCA\\Files_Antivirus\\AdminPanel"
"info": [],
"remote": [],
"public": [],
"repair-steps": {
"install": [],
"uninstall": []
"commands": [],
"groups": null,
"active": false,
"internal": false,
"level": 100,
"removable": true,
"preview": "/owncloud/apps/files_antivirus/img/app.svg",
"id": "federation",
"name": "Federation",
"description": "ownCloud Federation allows you to connect with other trusted ownClouds to exchange the user directory. For example this will be used to auto-complete external users for federated sharing.",
"licence": "AGPL",
"version": "0.1.0",
"namespace": "Federation",
"category": "other",
"dependencies": {
"owncloud": {
"@attributes": {
"types": [
"authentication"
"job": "OCA\\Federation\\SyncJob"
"commands": {
"command": "OCA\\Federation\\Command\\SyncFederationAddressBooks"
"settings": {
"admin": "OCA\\Federation\\Panels\\Admin"
"info": [],
"remote": [],
"public": [],
"repair-steps": {
"install": [],
"uninstall": []
"groups": null,
"active": true,
"internal": true,
"level": 200,
"removable": false,
"preview": "/owncloud/apps/federation/img/app.svg",
"appconfig": {
"enabled": "yes",
"installed_version": "0.1.0",
"id": "theme-example",
"name": "Example ownCloud Theme",
"description": "This App provides the example ownCloud theme.",
"licence": "AGPL",
"author": "Philipp Schaffrath",
"version": "1.0.0",
"types": [
"theme"
"dependencies": {
"owncloud": {
"@attributes": {
"namespace": "Theme",
"info": [],
"remote": [],
"public": [],
"repair-steps": {
"install": [],
"uninstall": []
"commands": [],
"groups": null,
"active": false,
"internal": false,
"level": 100,
"removable": true
"id": "systemtags",
"name": "Collaborative tags",
"description": "Collaborative tagging functionality which shares tags among users. Great for teams. (If you are a provider with a multi-tenancy installation, it is advised to deactivate this app as tags are shared.)",
"licence": "AGPL",
"author": "Vincent Petry",
"version": "0.3.0",
"dependencies": {
"owncloud": {
"@attributes": {
"namespace": "SystemTags",
"types": [
"logging"
"info": [],
"remote": [],
"public": [],
"repair-steps": {
"install": [],
"uninstall": []
"commands": [],
"groups": null,
"active": true,
"internal": false,
"level": 100,
"removable": true,
"appconfig": {
"enabled": "yes",
"types": "logging"
"id": "user_external",
"name": "External user support",
"description": "Use external user authentication methods like IMAP, SMB and FTP",
"licence": "AGPL",
"author": "Robin Appelman",
"documentation": {
"admin": "https://doc.owncloud.org/server/9.0/admin_manual/configuration_user/user_auth_ftp_smb_imap.html"
"website": "https://github.com/owncloud/apps/tree/master/user_external",
"bugs": "https://github.com/owncloud/apps/issues",
"repository": {
"@attributes": {
"type": "git"
"@value": "https://github.com/owncloud/apps.git"
"dependencies": {
"owncloud": {
"@attributes": {
"version": "0.4",
"shipped": "true",
"types": [
"authentication",
"prelogin"
"ocsid": "166060",
"info": [],
"remote": [],
"public": [],
"repair-steps": {
"install": [],
"uninstall": []
"commands": [],
"groups": null,
"active": false,
"internal": false,
"level": 100,
"removable": true,
"preview": "/owncloud/apps/user_external/img/app.svg",
"id": "files_videoplayer",
"name": "Video player",
"description": "A responsive video player using a skinned version of Video.js\n\nBased on this app: https://apps.owncloud.com/content/show.php/Video+Js?content=159670\n\nVideo.js: http://videojs.com/\n\nSkin: https://github.com/cabin/videojs-sublime-skin",
"version": "0.9.8",
"licence": "MIT",
"author": "Björn Korella",
"documentation": {
"user": "https://github.com/owncloud/files_videoplayer/blob/master/README.md",
"admin": "https://github.com/owncloud/files_videoplayer/blob/master/README.md",
"developer": "https://github.com/owncloud/files_videoplayer/blob/master/README.md"
"website": "https://github.com/owncloud/files_videoplayer",
"bugs": "https://github.com/owncloud/files_videoplayer/issues",
"repository": {
"@attributes": {
"type": "git"
"@value": "https://github.com/owncloud/files_videoplayer.git"
"dependencies": {
"owncloud": {
"@attributes": {
"info": [],
"remote": [],
"public": [],
"types": [],
"repair-steps": {
"install": [],
"uninstall": []
"commands": [],
"groups": null,
"active": true,
"internal": false,
"level": 100,
"removable": true,
"preview": "/owncloud/apps/files_videoplayer/img/app.svg",
"appconfig": {
"enabled": "yes",
"installed_version": "0.9.8",
"types": ""
**List of activated apps:**
don't use externale storage
no
no
### Client configuration
**Browser:**
Logging on through browser works with error
**Operating system:**
Windows 7 x64, SP1
### Logs
