Hello!
Here are the relevant errors. Running occ files:scan
seems to somehow fix the situation.
[message] => unable to rename, file does not exists : files/Mindfield/Support
[message] => Exception: An exception occurred while executing ‘UPDATE oc_filecache
SET mtime
= GREATEST(mtime
, ?), etag
= ?, size
= CASE WHEN size
> ‘-1’ THEN size
+ ? ELSE size
END WHERE (storage
= ?) AND (path_hash
IN (‘d41d8cd98f00b204e9800998ecf8427e’, ‘45b963397aa40d4a0063e0d85e4fe7a1’, ‘a93cc0c87af512473ea30be49b5e6ad5’, ‘a4afb7f6d765b67fc9ccd1ee6b9ca833’, ‘e15e32259ceff4834f427a34079abd61’, ‘a840fac3f34a9a489caa17303b720e79’, ‘52b84614e1749c01c6efc51befbbe8d2’, ‘fe5136cc62555274aceefa6f5ee7bde6’))’ with params [1580300256, “603395c305a54”, 7783327, 3]:
[message] => Caused by: {“Exception”:“Doctrine\DBAL\Driver\PDOException”,“Message”:“SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction”,“Code”:“40001”,“Trace”:"#0 /var/www/html/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(1073): Doctrine\DBAL\Driver\PDOStatement->execute()\n#1 /var/www/html/lib/private/DB/Connection.php(207): Doctrine\DBAL\Connection->executeUpdate(‘UPDATE oc_file...', Array, Array)\n#2 /var/www/html/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php(210): OC\\DB\\Connection->executeUpdate('UPDATE
oc_file…’, Array, Array)\n#3 /var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php(141): Doctrine\DBAL\Query\QueryBuilder->execute()\n#4 /var/www/html/lib/private/Files/Cache/Propagator.php(101): OC\DB\QueryBuilder\QueryBuilder->execute()\n#5 /var/www/html/lib/private/Files/Cache/HomePropagator.php(47): OC\Files\Cache\Propagator->propagateChange(‘files/Mindfield…’, 1580300256, 7783327)\n#6 /var/www/html/apps/files_sharing/lib/SharedPropagator.php(42): OC\Files\Cache\HomePropagator->propagateChange(‘files/Mindfield…’, 1580300256, 7783327)\n#7 /var/www/html/lib/private/Files/Cache/Updater.php(138): OCA\Files_Sharing\SharedPropagator->propagateChange(‘Produktion/Supp…’, 1580300256, 7783327)\n#8 /var/www/html/apps/dav/lib/Connector/Sabre/File.php(102): OC\Files\Cache\Updater->update(‘Produktion/Supp…’, 1580300256)\n#9 /var/www/html/apps/dav/lib/Connector/Sabre/File.php(279): OCA\DAV\Connector\Sabre\File->handleMetadataUpdate(Object(OCA\Files_Trashbin\Storage), ‘Produktion/Supp…’)\n#10 /var/www/html/apps/dav/lib/Connector/Sabre/Directory.php(172): OCA\DAV\Connector\Sabre\File->put(Resource id #20)\n#11 /var/www/html/lib/composer/sabre/dav/lib/DAV/Server.php(1098): OCA\DAV\Connector\Sabre\Directory->createFile(‘Tanzendes M\xC3\xA4dc…’, Resource id #20)\n#12 /var/www/html/lib/composer/sabre/dav/lib/DAV/CorePlugin.php(504): Sabre\DAV\Server->createFile(‘files/monika.be…’, Resource id #20, NULL)\n#13 /var/www/html/lib/composer/sabre/event/lib/WildcardEmitterTrait.php(89): Sabre\DAV\CorePlugin->httpPut(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#14 /var/www/html/lib/composer/sabre/dav/lib/DAV/Server.php(472): Sabre\DAV\Server->emit(‘method:PUT’, Array)\n#15 /var/www/html/lib/composer/sabre/dav/lib/DAV/Server.php(253): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#16 /var/www/html/apps/dav/lib/Server.php(330): Sabre\DAV\Server->start()\n#17 /var/www/html/apps/dav/appinfo/v2/remote.php(31): OCA\DAV\Server->exec()\n#18 /var/www/html/remote.php(165): require_once(’/var/www/html/a…’)\n#19 {main}",“File”:"/var/www/html/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php",“Line”:131}
[message] => Caused by: {“Exception”:“PDOException”,“Message”:“SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction”,“Code”:“40001”,“Trace”:"#0 /var/www/html/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php(129): PDOStatement->execute(NULL)\n#1 /var/www/html/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(1073): Doctrine\DBAL\Driver\PDOStatement->execute()\n#2 /var/www/html/lib/private/DB/Connection.php(207): Doctrine\DBAL\Connection->executeUpdate(‘UPDATE oc_file...', Array, Array)\n#3 /var/www/html/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php(210): OC\\DB\\Connection->executeUpdate('UPDATE
oc_file…’, Array, Array)\n#4 /var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php(141): Doctrine\DBAL\Query\QueryBuilder->execute()\n#5 /var/www/html/lib/private/Files/Cache/Propagator.php(101): OC\DB\QueryBuilder\QueryBuilder->execute()\n#6 /var/www/html/lib/private/Files/Cache/HomePropagator.php(47): OC\Files\Cache\Propagator->propagateChange(‘files/Mindfield…’, 1580300256, 7783327)\n#7 /var/www/html/apps/files_sharing/lib/SharedPropagator.php(42): OC\Files\Cache\HomePropagator->propagateChange(‘files/Mindfield…’, 1580300256, 7783327)\n#8 /var/www/html/lib/private/Files/Cache/Updater.php(138): OCA\Files_Sharing\SharedPropagator->propagateChange(‘Produktion/Supp…’, 1580300256, 7783327)\n#9 /var/www/html/apps/dav/lib/Connector/Sabre/File.php(102): OC\Files\Cache\Updater->update(‘Produktion/Supp…’, 1580300256)\n#10 /var/www/html/apps/dav/lib/Connector/Sabre/File.php(279): OCA\DAV\Connector\Sabre\File->handleMetadataUpdate(Object(OCA\Files_Trashbin\Storage), ‘Produktion/Supp…’)\n#11 /var/www/html/apps/dav/lib/Connector/Sabre/Directory.php(172): OCA\DAV\Connector\Sabre\File->put(Resource id #20)\n#12 /var/www/html/lib/composer/sabre/dav/lib/DAV/Server.php(1098): OCA\DAV\Connector\Sabre\Directory->createFile(‘Tanzendes M\xC3\xA4dc…’, Resource id #20)\n#13 /var/www/html/lib/composer/sabre/dav/lib/DAV/CorePlugin.php(504): Sabre\DAV\Server->createFile(‘files/monika.be…’, Resource id #20, NULL)\n#14 /var/www/html/lib/composer/sabre/event/lib/WildcardEmitterTrait.php(89): Sabre\DAV\CorePlugin->httpPut(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#15 /var/www/html/lib/composer/sabre/dav/lib/DAV/Server.php(472): Sabre\DAV\Server->emit(‘method:PUT’, Array)\n#16 /var/www/html/lib/composer/sabre/dav/lib/DAV/Server.php(253): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#17 /var/www/html/apps/dav/lib/Server.php(330): Sabre\DAV\Server->start()\n#18 /var/www/html/apps/dav/appinfo/v2/remote.php(31): OCA\DAV\Server->exec()\n#19 /var/www/html/remote.php(165): require_once(’/var/www/html/a…’)\n#20 {main}",“File”:"/var/www/html/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php",“Line”:129}
[message] => Exception: {“Exception”:“Doctrine\DBAL\Exception\UniqueConstraintViolationException”,“Message”:“An exception occurred while executing ‘UPDATE oc_filecache
SET storage
= ?, path
= ?, path_hash
= ? WHERE fileid
= ?’ with params [3, “files_versions/Mindfield/Produktion/Support/Gebrauchsanweisungen/eSense Skin Response & Temperature/Deutsch/eSense_Skin_Response_Handbuch_DE.pdf.v1544758761”, “ce2f1488e6f1eb94b4aeff747bc714dd”, “361795”]:\n\nSQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ‘3-ce2f1488e6f1eb94b4aeff747bc714dd’ for key ‘fs_storage_path_hash’”,“Code”:0,“Trace”:"#0 /var/www/html/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php(172): Doctrine\DBAL\Driver\AbstractMySQLDriver->convertException(‘An exception oc…’, Object(Doctrine\DBAL\Driver\PDOException))\n#1 /var/www/html/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php(151): Doctrine\DBAL\DBALException::wrapException(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Driver\PDOException), ‘An exception oc…’)\n#2 /var/www/html/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Statement.php(165): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Driver\PDOException), ‘UPDATE `oc_file…’, Array)\n#3 /var/www/html/lib/private/Files/Cache/Cache.php(591): Doctrine\DBAL\Statement->execute(Array)\n#4 /var/www/html/lib/private/Files/Cache/Cache.php(535): OC\Files\Cache\Cache->moveFromCache(Object(OC\Files\Cache\HomeCache), ‘files_versions/…’, ‘files_versions/…’)\n#5 /var/www/html/lib/private/Files/Cache/Updater.php(195): OC\Files\Cache\Cache->move(‘files_versions/…’, ‘files_versions/…’)\n#6 /var/www/html/lib/private/Files/View.php(345): OC\Files\Cache\Updater->renameFromStorage(Object(OCA\Files_Trashbin\Storage), ‘files_versions/…’, ‘files_versions/…’)\n#7 /var/www/html/lib/private/Files/View.php(886): OC\Files\View->renameUpdate(Object(OCA\Files_Trashbin\Storage), Object(OCA\Files_Trashbin\Storage), ‘files_versions/…’, ‘files_versions/…’)\n#8 /var/www/html/lib/public/Events/EventEmitterTrait.php(50): OC\Files\View->OC\Files\{closure}(*** sensitive parameters replaced )\n#9 /var/www/html/lib/private/Files/View.php(919): OC\Files\View->emittingCall(Object(Closure), Array, ‘file’, ‘rename’)\n#10 /var/www/html/apps/files_versions/lib/Storage.php(297): OC\Files\View->rename(’/nikohk83/files…’, ‘/nikohk83/files…’)\n#11 /var/www/html/apps/files_versions/lib/Hooks.php(102): OCA\Files_Versions\Storage::renameOrCopy(‘Mindfield/Suppo…’, ‘Mindfield/Produ…’, ‘rename’)\n#12 /var/www/html/lib/private/legacy/hook.php(103): OCA\Files_Versions\Hooks::rename_hook(Array)\n#13 /var/www/html/lib/private/Files/View.php(904): OC_Hook::emit(‘OC_Filesystem’, ‘post_rename’, Array)\n#14 /var/www/html/lib/public/Events/EventEmitterTrait.php(50): OC\Files\View->OC\Files\{closure}( sensitive parameters replaced ***)\n#15 /var/www/html/lib/private/Files/View.php(919): OC\Files\View->emittingCall(Object(Closure), Array, ‘file’, ‘rename’)\n#16 /var/www/html/apps/dav/lib/Connector/Sabre/Directory.php(481): OC\Files\View->rename(’/Mindfield/Supp…’, ‘/Mindfield/Prod…’)\n#17 /var/www/html/lib/composer/sabre/dav/lib/DAV/Tree.php(160): OCA\DAV\Connector\Sabre\Directory->moveInto(‘Support’, ‘files/monika.be…’, Object(OCA\DAV\Connector\Sabre\Directory))\n#18 /var/www/html/lib/composer/sabre/dav/lib/DAV/CorePlugin.php(612): Sabre\DAV\Tree->move(‘files/monika.be…’, ‘files/monika.be…’)\n#19 /var/www/html/lib/composer/sabre/event/lib/WildcardEmitterTrait.php(89): Sabre\DAV\CorePlugin->httpMove(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#20 /var/www/html/lib/composer/sabre/dav/lib/DAV/Server.php(472): Sabre\DAV\Server->emit(‘method:MOVE’, Array)\n#21 /var/www/html/lib/composer/sabre/dav/lib/DAV/Server.php(253): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#22 /var/www/html/apps/dav/lib/Server.php(330): Sabre\DAV\Server->start()\n#23 /var/www/html/apps/dav/appinfo/v2/remote.php(31): OCA\DAV\Server->exec()\n#24 /var/www/html/remote.php(165): require_once(’/var/www/html/a…’)\n#25 {main}",“File”:"/var/www/html/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php",“Line”:59}
[message] => Caused by: {“Exception”:“PDOException”,“Message”:“SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ‘3-ce2f1488e6f1eb94b4aeff747bc714dd’ for key ‘fs_storage_path_hash’”,“Code”:“23000”,“Trace”:"#0 /var/www/html/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php(129): PDOStatement->execute(Array)\n#1 /var/www/html/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Statement.php(155): Doctrine\DBAL\Driver\PDOStatement->execute(Array)\n#2 /var/www/html/lib/private/Files/Cache/Cache.php(591): Doctrine\DBAL\Statement->execute(Array)\n#3 /var/www/html/lib/private/Files/Cache/Cache.php(535): OC\Files\Cache\Cache->moveFromCache(Object(OC\Files\Cache\HomeCache), ‘files_versions/…’, ‘files_versions/…’)\n#4 /var/www/html/lib/private/Files/Cache/Updater.php(195): OC\Files\Cache\Cache->move(‘files_versions/…’, ‘files_versions/…’)\n#5 /var/www/html/lib/private/Files/View.php(345): OC\Files\Cache\Updater->renameFromStorage(Object(OCA\Files_Trashbin\Storage), ‘files_versions/…’, ‘files_versions/…’)\n#6 /var/www/html/lib/private/Files/View.php(886): OC\Files\View->renameUpdate(Object(OCA\Files_Trashbin\Storage), Object(OCA\Files_Trashbin\Storage), ‘files_versions/…’, ‘files_versions/…’)\n#7 /var/www/html/lib/public/Events/EventEmitterTrait.php(50): OC\Files\View->OC\Files\{closure}(*** sensitive parameters replaced )\n#8 /var/www/html/lib/private/Files/View.php(919): OC\Files\View->emittingCall(Object(Closure), Array, ‘file’, ‘rename’)\n#9 /var/www/html/apps/files_versions/lib/Storage.php(297): OC\Files\View->rename(’/nikohk83/files…’, ‘/nikohk83/files…’)\n#10 /var/www/html/apps/files_versions/lib/Hooks.php(102): OCA\Files_Versions\Storage::renameOrCopy(‘Mindfield/Suppo…’, ‘Mindfield/Produ…’, ‘rename’)\n#11 /var/www/html/lib/private/legacy/hook.php(103): OCA\Files_Versions\Hooks::rename_hook(Array)\n#12 /var/www/html/lib/private/Files/View.php(904): OC_Hook::emit(‘OC_Filesystem’, ‘post_rename’, Array)\n#13 /var/www/html/lib/public/Events/EventEmitterTrait.php(50): OC\Files\View->OC\Files\{closure}( sensitive parameters replaced ***)\n#14 /var/www/html/lib/private/Files/View.php(919): OC\Files\View->emittingCall(Object(Closure), Array, ‘file’, ‘rename’)\n#15 /var/www/html/apps/dav/lib/Connector/Sabre/Directory.php(481): OC\Files\View->rename(’/Mindfield/Supp…’, ‘/Mindfield/Prod…’)\n#16 /var/www/html/lib/composer/sabre/dav/lib/DAV/Tree.php(160): OCA\DAV\Connector\Sabre\Directory->moveInto(‘Support’, ‘files/monika.be…’, Object(OCA\DAV\Connector\Sabre\Directory))\n#17 /var/www/html/lib/composer/sabre/dav/lib/DAV/CorePlugin.php(612): Sabre\DAV\Tree->move(‘files/monika.be…’, ‘files/monika.be…’)\n#18 /var/www/html/lib/composer/sabre/event/lib/WildcardEmitterTrait.php(89): Sabre\DAV\CorePlugin->httpMove(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#19 /var/www/html/lib/composer/sabre/dav/lib/DAV/Server.php(472): Sabre\DAV\Server->emit(‘method:MOVE’, Array)\n#20 /var/www/html/lib/composer/sabre/dav/lib/DAV/Server.php(253): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#21 /var/www/html/apps/dav/lib/Server.php(330): Sabre\DAV\Server->start()\n#22 /var/www/html/apps/dav/appinfo/v2/remote.php(31): OCA\DAV\Server->exec()\n#23 /var/www/html/remote.php(165): require_once(’/var/www/html/a…’)\n#24 {main}",“File”:"/var/www/html/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php",“Line”:129}
[message] => Exception: {“Exception”:“OCP\Files\NotFoundException”,“Message”:"/Mindfield/Support not found while trying to get owner",“Code”:0,“Trace”:"#0 /var/www/html/lib/private/Files/Filesystem.php(1072): OC\Files\View->getOwner(’/Mindfield/Supp…’)\n#1 /var/www/html/apps/files_versions/lib/Storage.php(94): OC\Files\Filesystem::getOwner(’/Mindfield/Supp…’)\n#2 /var/www/html/apps/files_versions/lib/Storage.php(124): OCA\Files_Versions\Storage::getUidAndFilename(’/Mindfield/Supp…’)\n#3 /var/www/html/apps/files_versions/lib/Hooks.php(149): OCA\Files_Versions\Storage::setSourcePathAndUser(’/Mindfield/Supp…’)\n#4 /var/www/html/lib/private/legacy/hook.php(103): OCA\Files_Versions\Hooks::pre_renameOrCopy_hook(Array)\n#5 /var/www/html/lib/private/Files/View.php(838): OC_Hook::emit(‘OC_Filesystem’, ‘rename’, Array)\n#6 /var/www/html/lib/public/Events/EventEmitterTrait.php(50): OC\Files\View->OC\Files\{closure}(*** sensitive parameters replaced ***)\n#7 /var/www/html/lib/private/Files/View.php(919): OC\Files\View->emittingCall(Object(Closure), Array, ‘file’, ‘rename’)\n#8 /var/www/html/apps/dav/lib/Connector/Sabre/Directory.php(481): OC\Files\View->rename(’/Mindfield/Supp…’, ‘/Mindfield/Prod…’)\n#9 /var/www/html/lib/composer/sabre/dav/lib/DAV/Tree.php(160): OCA\DAV\Connector\Sabre\Directory->moveInto(‘Support’, ‘files/monika.be…’, Object(OCA\DAV\Connector\Sabre\Directory))\n#10 /var/www/html/lib/composer/sabre/dav/lib/DAV/CorePlugin.php(612): Sabre\DAV\Tree->move(‘files/monika.be…’, ‘files/monika.be…’)\n#11 /var/www/html/lib/composer/sabre/event/lib/WildcardEmitterTrait.php(89): Sabre\DAV\CorePlugin->httpMove(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#12 /var/www/html/lib/composer/sabre/dav/lib/DAV/Server.php(472): Sabre\DAV\Server->emit(‘method:MOVE’, Array)\n#13 /var/www/html/lib/composer/sabre/dav/lib/DAV/Server.php(253): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#14 /var/www/html/apps/dav/lib/Server.php(330): Sabre\DAV\Server->start()\n#15 /var/www/html/apps/dav/appinfo/v2/remote.php(31): OCA\DAV\Server->exec()\n#16 /var/www/html/remote.php(165): require_once(’/var/www/html/a…’)\n#17 {main}",“File”:"/var/www/html/lib/private/Files/View.php",“Line”:1776}
