- import self signed certificate
- adding an External Storage, its type is Amazon S3 and SSL enabled
- red indicator appeared
Green indicator should appear. External Storage should be available.
Red indicator should appear. External Storage was not available.
RedHat 7.4
Apache 2.4.6
sqlite3
PHP 7.2
10.1.1
Fresh install
ownCloud official website
<?php $CONFIG = array ( 'instanceid' => 'ocg80lby52ja', 'passwordsalt' => 'KV9+yqi8Q4XvHvuLBE2En7lifSxvAK', 'secret' => 'GEOjbfNFAys/9EecLSz4rXnH0gg/a1+w0K2Si3XrS4SaCL/E', 'trusted_domains' => array ( 0 => 'xxx.xxx.xxx.xxx', 1 => 'xxx.xxx.xxx.xxx', ), 'datadirectory' => '/var/www/html/owncloud/data', 'overwrite.cli.url' => 'http://xxx.xxx.xxx.xxx/owncloud', 'dbtype' => 'sqlite3', 'version' => '10.1.1.1', 'logtimezone' => 'UTC', 'installed' => true, 'loglevel' => 0, 'enable_certificate_management' => true, ); **List of activated apps:** ``` Enabled: - comments: 0.3.0 - configreport: 0.1.2 - dav: 0.4.0 - federatedfilesharing: 0.3.1 - federation: 0.1.0 - files: 1.5.2 - files_external: 0.7.1 - files_sharing: 0.11.0 - files_trashbin: 0.9.1 - files_versions: 1.3.0 - files_videoplayer: 0.9.9 - firstrunwizard: 1.1.1 - market: 0.3.0 - notifications: 0.4.1 - provisioning_api: 0.5.0 - systemtags: 0.3.0 - updatenotification: 0.2.1 Disabled: - encryption - external - user_external ``` **Are you using external storage, if yes which one:** local/smb/sftp/... Amazon S3 **Are you using encryption:** yes/no no **Browser:** Chrome **Operating system:** Windows 2016 ### Logs #### Web server error log ``` the External Storage turns out to be red indicator. ``` #### ownCloud log (data/owncloud.log) ``` 3958df1f6849fa65fd703d7579777ce79c3b5229e8f8e942a1c7c6a8058 with token id 16 found, validating"} {"reqId":"XMFeXOT51Y26DkGMbVzZHAAAAAo","level":3,"time":"2019-04-25T07:14:36+00:00","remoteAddr":"100.115.50.16","user":"admin","app":"files_external","method":"PUT","url":"\/owncloud\/index.php\/apps\/files_external\/globalstorages\/16","message":"Exception: {\"Exception\":\"Aws\\\\Common\\\\Exception\\\\TransferException\",\"Message\":\"[curl] 60: [url] https:\\\/\\\/owncloud-hepeng.obs-70.huawei.com\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/aws-sdk-php\\\/Guzzle\\\/Service\\\/Client.php(136): Aws\\\\Common\\\\Client\\\\AbstractClient->send(Object(Guzzle\\\\Http\\\\Message\\\\Request))\\n#1 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/aws-sdk-php\\\/Guzzle\\\/Service\\\/Command\\\/AbstractCommand.php(153): Guzzle\\\\Service\\\\Client->execute(Object(Aws\\\\S3\\\\Command\\\\S3Command))\\n#2 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/aws-sdk-php\\\/Aws\\\/S3\\\/S3Client.php(665): Guzzle\\\\Service\\\\Command\\\\AbstractCommand->exe ``` #### Browser log ``` statusMessage: "Aws\Common\Exception\TransferException: [curl] 60: [url] https://owncloud-hepeng.obs-70.huawei.com" ```
