Admin Section "Sharing" not visible in chrome
  1. Install fresh OC 10.0.7 with Docker
  2. Add User to Group “Admin” und log in
  3. Sharing Section in Admin Panel is not visible in Chrome
See Admin Section “Sharing”
Admin Section “Sharing” not visible, but accessible via https://yourwoncloud.tld/settings/admin?sectionid=sharing
Admin Section is visible if logged in with Firefox
Operating system: official Docker image
Web server: official Docker image
Database: mysql 5.7
PHP version: official Docker image
ownCloud version: 10.0.7.2
Where did you install ownCloud from: official Docker image
sharing App is enabled
Browser: Chrome Version 65.0.3325.181 (Official Build) (64-bit)
Operating system: mac OS 10.13.4
no errors
It seems that the Adblocker Chrome Extension uBlock Origin is responsible for that.
Maybe some sort of “Warning - whitelist this domain in your adblocker” might be nice.
From what i know you can post feature requests like this to the github issue trackers of ownCloud.
