Advice on Migrating Away from OpenSUSE Linux Packages
Thanks for getting in touch with the ownCloud community!
Central is the place for general topics around ownCloud: Questions, suggestions and community-based support.
Bug reports against any ownCloud component should be reported in the Github issue trackers.
More information about reporting issues can be found in the Contribution Guidelines
at core/.github/CONTRIBUTING.md at master · owncloud/core · GitHub
Please be patient and try to describe your topic as detailed as possible to
enable others to understand your request. With that you will get prompt responses.
Please always add information about the version of any involved software, the
operating system and database you’re using with regards to your enquiry.
It is advisable to test with the latest stable versions of all components before
reaching out to others.
x package installed ownCloud server to one of the remaining supported options?
TL;DR: what steps should be taken to migrate from a current openSUSE Linux package installed ownCloud server to one of the remaining supported options?
I’ve only just become aware of the announcement in June 2025 that openSUSE packages support has been dropped. In that announcement, it says that such installations should migrate to a supported method, but there is no specific advice given. Can anyone point me to the specific steps that should be taken to achieve this?
Operating system: Ubuntu 20.04
Web server: Apache
Database: MySQL (8.0.43)
PHP version: 7.4.3
ownCloud version: 10.15.2-1+12.1
Updated from an older ownCloud or fresh install: upgraded
Where did you install ownCloud from: Linux Packages
This would be no different than any other migration to a new ownCloud installation. While you are setting up your new ownCloud instance, you should probably replace that obsolete Ubuntu LTS with an OS that is still in support.
To migrate from an openSUSE ownCloud installation, back up your database, config.php, and data/ folder. Set up a supported server (Ubuntu, Debian, or Docker), install ownCloud, restore your data, update configuration, and test everything before going live.
