so I just upgraded my machine running oC 9.0.4-1.1 from Ubuntu 14.04 to Ubuntu 16.04. During the installation, the oC repo was removed from Ubuntu, and I added the new one as per the documentation. oC now runs ok on the machine.
The only issue now is:
apt autoremove
wants to remove the package owncloud-files (yikes!).
The status of the package looks ok (and, again, oC is running ok!):
# apt show owncloud-files
Package: owncloud-files
Version: 9.0.4-1.1
Status: install ok installed
Priority: optional
Section: devel
Maintainer: Juergen Weigert <jw@owncloud.com>
Installed-Size: 93,6 MB
Suggests: owncloud-deps
Conflicts: owncloud (<= 8.99.99), owncloud-config-apache (<= 8.99.99), owncloud-server (<= 8.99.99)
Replaces: owncloud (<= 8.99.99), owncloud-config-apache (<= 8.99.99), owncloud-server (<= 8.99.99)
Download-Size: unbekannt
APT-Manual-Installed: no
APT-Sources: /var/lib/dpkg/status
Description: ownCloud - Server
I probably missed something during the upgrade; but what?
Only owncloud-files is installed; no other package from the oC repos.
Thanks for any hint you may have!
