Alfresco WebDav External storage
  1. As Admin allow users to connect to WebDav server
  2. Add Alfresco 5.x as WebDav server to your personal account as external WebDav-server
  3. Access the External storage (Alfresco) from you personal account, Error No files here! Upload or synchronize.
Folders and files should be displayed.
No folders or files are displayed
Operating system: Ubuntu 16.04.3
Web server: Apache/2.4.18 (Ubuntu)
Database: MySQL 5.0.12
PHP version: 7.0.8-0
ownCloud version (see ownCloud admin page): Owncloud 9.1
Error PHP Undefined offset: 1 at /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Xml/Element/Response.php#237 2016-10-11T13:05:49+00:00
Error PHP Undefined index: {DAV:}status at /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Xml/Element/Response.php#236 2016-10-11T13:05:49+00:00
Integrity status for oC9+
There is a similar error with 1&1 webspace:
If you use a different webdav provider, open a new issue and run the litmus test mentioned in the other topic.
And make sure that you run ownCloud version 9.1.1 and not 9.1.0.
