Checking the "Allow sharing on user-mounted external storages" checkbox does not save (although it says Saved). I refresh the screen and then it is unchecked again.
Info:
installed true
maintenance false
needsDbUpgrade false
version 10.0.3.3
versionstring 10.0.3
edition Community
productname ownCloud
Log:
{"reqId":"L6vdMHOrDuO1V2ZDVhy3","level":0,"time":"2017-09-25T17:45:04+00:00","remoteAddr":"","user":"--","app":"cron","method":"--","url":"--","message":"Started background job of class : OCA\Files\BackgroundJob\CleanupFileLocks with arguments : "}
{"reqId":"L6vdMHOrDuO1V2ZDVhy3","level":0,"time":"2017-09-25T17:45:04+00:00","remoteAddr":"","user":"--","app":"cron","method":"--","url":"--","message":"Finished background job, the job took : 0 seconds, this job is an instance of class : OCA\Files\BackgroundJob\CleanupFileLocks with arguments : "}
{"reqId":"L6vdMHOrDuO1V2ZDVhy3","level":0,"time":"2017-09-25T17:45:05+00:00","remoteAddr":"","user":"--","app":"cron","method":"--","url":"--","message":"Started background job of class : OCA\Files_Sharing\DeleteOrphanedSharesJob with arguments : "}
{"reqId":"L6vdMHOrDuO1V2ZDVhy3","level":0,"time":"2017-09-25T17:45:05+00:00","remoteAddr":"","user":"--","app":"DeleteOrphanedSharesJob","method":"--","url":"--","message":"0 orphaned share(s) deleted"}
{"reqId":"L6vdMHOrDuO1V2ZDVhy3","level":0,"time":"2017-09-25T17:45:05+00:00","remoteAddr":"","user":"--","app":"cron","method":"--","url":"--","message":"Finished background job, the job took : 0 seconds, this job is an instance of class : OCA\Files_Sharing\DeleteOrphanedSharesJob with arguments : "}
{"reqId":"L6vdMHOrDuO1V2ZDVhy3","level":0,"time":"2017-09-25T17:45:05+00:00","remoteAddr":"","user":"--","app":"cron","method":"--","url":"--","message":"Started background job of class : OC\Authentication\Token\DefaultTokenCleanupJob with arguments : "}
{"reqId":"L6vdMHOrDuO1V2ZDVhy3","level":1,"time":"2017-09-25T17:45:05+00:00","remoteAddr":"","user":"--","app":"cron","method":"--","url":"--","message":"Invalidating tokens older than 2017-09-24T17:45:05+00:00"}
{"reqId":"L6vdMHOrDuO1V2ZDVhy3","level":0,"time":"2017-09-25T17:45:05+00:00","remoteAddr":"","user":"--","app":"cron","method":"--","url":"--","message":"Finished background job, the job took : 0 seconds, this job is an instance of class : OC\Authentication\Token\DefaultTokenCleanupJob with arguments : "}
{"reqId":"91O7MkGu4u3J7umQ2kKL","level":3,"time":"2017-09-25T17:48:10+00:00","remoteAddr":"78.131.72.90","user":"gkovacsp","app":"PHP","method":"PROPFIND","url":"\/owncloud\/remote.php\/webdav\/%5Bpi%5D%20home","message":"Undefined index: size at \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php#421"}
{"reqId":"91O7MkGu4u3J7umQ2kKL","level":3,"time":"2017-09-25T17:48:11+00:00","remoteAddr":"78.131.72.90","user":"gkovacsp","app":"PHP","method":"PROPFIND","url":"\/owncloud\/remote.php\/webdav\/%5Bpi%5D%20home","message":"Undefined index: size at \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php#421"}
{"reqId":"91O7MkGu4u3J7umQ2kKL","level":3,"time":"2017-09-25T17:48:12+00:00","remoteAddr":"78.131.72.90","user":"gkovacsp","app":"PHP","method":"PROPFIND","url":"\/owncloud\/remote.php\/webdav\/%5Bpi%5D%20home","message":"Undefined index: size at \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php#421"}
{"reqId":"2MJQVH6dCJxlGqMlFOTk","level":3,"time":"2017-09-25T17:48:13+00:00","remoteAddr":"78.131.72.90","user":"gkovacsp","app":"PHP","method":"GET","url":"\/owncloud\/index.php\/apps\/files\/ajax\/getstoragestats.php?dir=%2F%5Bpi%5D%20home","message":"Undefined index: size at \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php#421"}
{"reqId":"2MJQVH6dCJxlGqMlFOTk","level":3,"time":"2017-09-25T17:48:14+00:00","remoteAddr":"78.131.72.90","user":"gkovacsp","app":"PHP","method":"GET","url":"\/owncloud\/index.php\/apps\/files\/ajax\/getstoragestats.php?dir=%2F%5Bpi%5D%20home","message":"Undefined index: size at \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php#421"}
{"reqId":"eACDFTBNbBRSHhx3dfHt","level":0,"time":"2017-09-25T17:48:33+00:00","remoteAddr":"78.131.72.90","user":"gkovacsp","app":"core","method":"GET","url":"\/owncloud\/index.php\/core\/preview.png?file=%2F%5Bpi%5D+home%2Fwp.txt&c=5cc931d273693522f79dec3146397072&x=64&y=64&forceIcon=0","message":"Generating preview for \"\/[pi] home\/wp.txt\" with \"OC\Preview\TXT\""}
{"reqId":"P5G1ykpc3OYPyt5X8OeT","level":0,"time":"2017-09-25T17:48:34+00:00","remoteAddr":"78.131.72.90","user":"gkovacsp","app":"core","method":"GET","url":"\/owncloud\/index.php\/core\/preview.png?file=%2F%5Bpi%5D+home%2Frpi-kpg.conf&c=a11b3f1fc042f307b6027e3145cad66a&x=64&y=64&forceIcon=0","message":"Generating preview for \"\/[pi] home\/rpi-kpg.conf\" with \"OC\Preview\TXT\""}
{"reqId":"v3NPhfVlfBAJVS7ewOiz","level":0,"time":"2017-09-25T17:48:34+00:00","remoteAddr":"78.131.72.90","user":"gkovacsp","app":"core","method":"GET","url":"\/owncloud\/index.php\/core\/preview.png?file=%2F%5Bpi%5D+home%2Fsubtitles.txt&c=9ea4cb0f2fdb8484b119746d4fb7a0dd&x=64&y=64&forceIcon=0","message":"Generating preview for \"\/[pi] home\/subtitles.txt\" with \"OC\Preview\TXT\""}
