i put my ip addr in /var/www/html/owncloud/config/config.php
‘trusted_domains’ =>
array (
0 => ‘192.168.1.9’,
1 => ‘192.168.1.20’,
2 => ‘xxx.xx.xx.xxx’, "this is ip of my vpn or external ip when at home
but when i try to connect is says
You are accessing the server from an untrusted domain.
Please contact your administrator. If you are an administrator of this instance, configure the “trusted_domains” setting in config/config.php. An example configuration is provided in config/config.sample.php or at the documentation.
hi tom thanks for your help. i appreciate
so from the outside i am timing out .
i have open port 80 on my router which is the port lighttpd is running.
from inside i can use the url but not from the outside any thing i can show to troubleshoot
i think you’re probably not the only one having networking issues while running software like ownCloud.
Personally i would search around here at the forums or having a look for some network related tutorials and troubleshooting guides to see if you can get your network setup to work as expected.
this is solved now . even-though i had port forwarding correct my isp had closed port 80 .
After they reopened it i am able to connect from the outside
