- Download Installation package owncloud-10.3.1.zip
- Extract ZIP archive
- Upload files to webserver
- Open URL in web browser
- Setup admin credentials and database
- Complete installation. No error messages so far, everything seems OK.
- Log in using previously defined admin credentials
I expect kind of a Owncloud dashboard or backend to be displayed where I can manage users and settings.
Owncloud dashboard or backend appears for a few seconds. The following message is displayed on top of the page:
«Failed to request notifications. Please try to refresh the page manually.
Problem beim Laden der Seite, Seite wird in 5 Sekunden nochmals geladen»
After a few seconds the page is refreshed automatically and I am being logged out. After logging in again, the same procedure happens.
Operating system: Linux
Web server: Linux
Database: Maria-DB MySQLi
PHP version: 7.3
ownCloud version: 10.3.1
Where did you install ownCloud from: from my PC
Signing status (ownCloud 9.0 and above): I do not know since I am not able to login
<?php $CONFIG = array ( 'instanceid' => 'oc4ev9q438pe', 'passwordsalt' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx', 'secret' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx', 'trusted_domains' => array ( 0 => 'owncloud.mydomain.ch', ), 'datadirectory' => '/home/sites/2b/7/7c2cb5703d/owncloud/data', 'overwrite.cli.url' => 'https://owncloud.mydomain.ch', 'dbtype' => 'mysql', 'version' => '10.3.1.1', 'dbname' => 'xxxxxxxx', 'dbhost' => 'shareddb-g.hosting.stackcp.net', 'dbtableprefix' => 'oc_', 'mysql.utf8mb4' => true, 'dbuser' => 'xxxxxxx', 'dbpassword' => 'xxxxxxxxx', 'logtimezone' => 'UTC', 'apps_paths' => array ( 0 => array ( 'path' => '/home/sites/2b/7/7c2cb5703d/owncloud/apps', 'url' => '/apps', 'writable' => false, ), 1 => array ( 'path' => '/home/sites/2b/7/7c2cb5703d/owncloud/apps-external', 'url' => '/apps-external', 'writable' => true, ), ), 'installed' => true, ); **List of activated apps:** None, since I have not been able to login so far. **Are you using external storage, if yes which one:** no **Are you using encryption:** yes **Are you using an external user-backend, if yes which one:** no ### Client configuration **Browser:** Firefox 71 **Operating system:** Windows 10 Home ### Logs #### Web server error log ``` It does not contain anything related to Owncloud. ``` #### ownCloud log (data/owncloud.log) ``` The file owncloud.log is empty. ```
