Technical information
them.
Results
- core
- INVALID_HASH
- lib/private/legacy/defaults.php
- INVALID_HASH
Raw output
Array
[core] => Array
[INVALID_HASH] => Array
[lib/private/legacy/defaults.php] => Array
[expected] => 2f1c537e63212d4e3c1c0c49537c023bcd8902bb4a71e5bbdb32e58e07aa56673caf14021dee9570e4ae021bb1109fb397b420d32a77e49c165db53a07e5ccfc
[current] => 350e702f2c069fc2155ce6b02a99c1f1270ca3ec3a7b5e64089ef553cf7e1493f8e9cdab63e5a0cd9d1bc93ca358a64acc03a7534050daf1f4f36d4121e331c6
Whats inside the the defaults located in /var/www/owncloud/lib/private/legacy:
<?php * @copyright Copyright (c) 2017, ownCloud GmbH * @license AGPL-3.0 * * This code is free software: you can redistribute it and/or modify * it under the terms of the GNU Affero General Public License, version 3, * as published by the Free Software Foundation. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU Affero General Public License for more details. * * You should have received a copy of the GNU Affero General Public License, version 3, * along with this program. If not, see * */ class OC_Defaults { private $theme; private $l; private $defaultEntity; private $defaultName; private $defaultTitle; private $defaultBaseUrl; private $defaultSyncClientUrl; private $defaultiOSClientUrl; private $defaultiTunesAppId; private $defaultAndroidClientUrl; private $defaultDocBaseUrl; private $defaultDocVersion; private $defaultSlogan; private $defaultLogoClaim; private $defaultMailHeaderColor; function __construct() { $this->l = \OC::$server->getL10N('lib'); $version = \OCP\Util::getVersion(); $this->defaultEntity = 'Azura Cloud'; /* e.g. company name, used for footers and copyright notices */ $this->defaultName = 'Azura Cloud'; /* short name, used when referring to the software */ $this->defaultTitle = 'Azura Private Cloud'; /* can be a longer name, for titles */ $this->defaultBaseUrl = 'https://owncloud.org'; $this->defaultSyncClientUrl = 'https://owncloud.org/install/#install-clients'; $this->defaultiOSClientUrl = 'https://itunes.apple.com/us/app/owncloud/id543672169?mt=8'; $this->defaultiTunesAppId = '543672169'; $this->defaultAndroidClientUrl = 'https://play.google.com/store/apps/details?id=com.owncloud.android'; $this->defaultDocBaseUrl = 'https://doc.owncloud.org'; $this->defaultDocVersion = $version[0] . '.' . $version[1]; // used to generate doc links $this->defaultSlogan = $this->l->t('web services under your control'); $this->defaultLogoClaim = ''; $this->defaultMailHeaderColor = '#1d2d44'; /* header color of mail notifications */ $themePath = OC_Util::getTheme()->getDirectory(); $defaultsPath = OC::$SERVERROOT . '/' . $themePath . '/defaults.php'; if (file_exists($defaultsPath)) { // prevent defaults.php from printing output ob_start(); require_once $defaultsPath; ob_end_clean(); if (class_exists('OC_Theme')) { $this->theme = new OC_Theme(); } } } /** * @param string $method */ private function themeExist($method) { if (isset($this->theme) && method_exists($this->theme, $method)) { return true; } return false; } /** * Returns the base URL * @return string URL */ public function getBaseUrl() { if ($this->themeExist('getBaseUrl')) { return $this->theme->getBaseUrl(); } else { return $this->defaultBaseUrl; } } /** * Returns the URL where the sync clients are listed * @return string URL */ public function getSyncClientUrl() { if ($this->themeExist('getSyncClientUrl')) { return $this->theme->getSyncClientUrl(); } else { return $this->defaultSyncClientUrl; } } /** * Returns the URL to the App Store for the iOS Client * @return string URL */ public function getiOSClientUrl() { if ($this->themeExist('getiOSClientUrl')) { return $this->theme->getiOSClientUrl(); } else { return $this->defaultiOSClientUrl; } } /** * Returns the AppId for the App Store for the iOS Client * @return string AppId */ public function getiTunesAppId() { if ($this->themeExist('getiTunesAppId')) { return $this->theme->getiTunesAppId(); } else { return $this->defaultiTunesAppId; } } /** * Returns the URL to Google Play for the Android Client * @return string URL */ public function getAndroidClientUrl() { if ($this->themeExist('getAndroidClientUrl')) { return $this->theme->getAndroidClientUrl(); } else { return $this->defaultAndroidClientUrl; } } /** * Returns the documentation URL * @return string URL */ public function getDocBaseUrl() { if ($this->themeExist('getDocBaseUrl')) { return $this->theme->getDocBaseUrl(); } else { return $this->defaultDocBaseUrl; } } /** * Returns the title * @return string title */ public function getTitle() { if ($this->themeExist('getTitle')) { return $this->theme->getTitle(); } else { return $this->defaultTitle; } } /** * Returns the short name of the software * @return string title */ public function getName() { if ($this->themeExist('getName')) { return $this->theme->getName(); } else { return $this->defaultName; } } /** * Returns the short name of the software containing HTML strings * @return string title */ public function getHTMLName() { if ($this->themeExist('getHTMLName')) { return $this->theme->getHTMLName(); } else { return $this->defaultName; } } /** * Returns entity (e.g. company name) - used for footer, copyright * @return string entity name */ public function getEntity() { if ($this->themeExist('getEntity')) { return $this->theme->getEntity(); } else { return $this->defaultEntity; } } /** * Returns slogan * @return string slogan */ public function getSlogan() { if ($this->themeExist('getSlogan')) { return $this->theme->getSlogan(); } else { return $this->defaultSlogan; } } /** * Returns logo claim * @return string logo claim */ public function getLogoClaim() { if ($this->themeExist('getLogoClaim')) { return $this->theme->getLogoClaim(); } else { return $this->defaultLogoClaim; } } /** * Returns short version of the footer * @return string short footer */ public function getShortFooter() { if ($this->themeExist('getShortFooter')) { $footer = $this->theme->getShortFooter(); } else { $footer = '' .$this->getEntity() . ''. ' – ' . $this->getSlogan(); } return $footer; } /** * Returns long version of the footer * @return string long footer */ public function getLongFooter() { if ($this->themeExist('getLongFooter')) { $footer = $this->theme->getLongFooter(); } else { $footer = $this->getShortFooter(); } return $footer; } /** * @param string $key */ public function buildDocLinkToKey($key) { if ($this->themeExist('buildDocLinkToKey')) { return $this->theme->buildDocLinkToKey($key); } return $this->getDocBaseUrl() . '/server/' . $this->defaultDocVersion . '/go.php?to=' . $key; } /** * Returns mail header color * @return string */ public function getMailHeaderColor() { if ($this->themeExist('getMailHeaderColor')) { return $this->theme->getMailHeaderColor(); } else { return $this->defaultMailHeaderColor; } } }
