Amazon S3 problem with upload large file
  1. Upload file more than 512Mb
File upload
“message”:“Allowed memory size of 536870912 bytes exhausted (tried to allocate 637706272 bytes) at /opt/bitnami/apps/owncloud/htdocs/lib/composer/guzzle/stream/Guzzle/Stream/Stream…php#71”
Operating system: Bitnami
Web server: Apache 2.4
Database: MySql
PHP version: 7.1
ownCloud version: (see ownCloud admin page) 10.2.0
Where did you install ownCloud from: Bitnami image
$CONFIG = array (
‘passwordsalt’ => ‘xxxx’,
‘secret’ => ‘xxxx’,
‘trusted_domains’ =>
array (
0 => ‘127.0.0.1’,
1 => ‘xxx.xxx.xxx.xxx’,
3 => ‘xxxx.com’,
‘datadirectory’ => ‘/opt/bitnami/apps/owncloud/data’,
‘overwrite.cli.url’ => ‘ht ps://localhost’,
‘overwriteprotocol’ => ‘h tps’,
‘dbtype’ => ‘mysql’,
‘version’ => ‘10.2.0.5’,
‘dbname’ => ‘bitnami_owncloud’,
‘dbhost’ => ‘localhost:/opt/bitnami/mysql/tmp/mysql.sock’,
‘dbtableprefix’ => ‘oc_’,
‘mysql.utf8mb4’ => true,
‘dbuser’ => ‘bn_owncloud’,
‘dbpassword’ => ‘xxxxxxx’,
‘logtimezone’ => ‘UTC’,
‘apps_paths’ =>
array (
0 =>
array (
‘path’ => ‘/opt/bitnami/apps/owncloud/htdocs/apps’,
‘url’ => ‘/apps’,
‘writable’ => false,
1 =>
array (
‘path’ => ‘/opt/bitnami/apps/owncloud/htdocs/apps-external’,
‘url’ => ‘/apps-external’,
‘writable’ => true,
‘installed’ => true,
‘instanceid’ => ‘xxxxxx’,
‘openssl’ =>
array (
‘config’ => ‘/opt/bitnami/common/openssl/openssl.cnf’,
‘mail_domain’ => ‘xxxxxx.com’,
‘mail_from_address’ => ‘post’,
‘mail_smtpmode’ => ‘smtp’,
‘mail_smtpauthtype’ => ‘PLAIN’,
‘mail_smtpauth’ => 1,
‘mail_smtphost’ => ‘xxxxx’,
‘mail_smtpsecure’ => ‘ssl’,
‘mail_smtpport’ => ‘465’,
‘mail_smtpname’ => ‘xxxxxx’,
‘mail_smtppassword’ => ‘xxxxxx’,
‘memcache.locking’ => ‘\OC\Memcache\Redis’,
‘filelocking.enabled’ => ‘true’,
‘redis’ =>
array (
‘host’ => ‘localhost’,
‘port’ => 6379,
‘log_type’ => ‘owncloud’,
‘logfile’ => ‘owncloud.log’,
‘loglevel’ => ‘3’,
‘logdateformat’ => ‘F d, Y H:i:s’,
‘files_external_allow_local’ => ‘true’,
‘files_external_allow_create_new_local’ => ‘true’,
‘admin’ -> ‘Generate Config Report’ -> ‘Download ownCloud config report’
**List of activated apps:**
**Are you using external storage, if yes which one: AmazonS3
**Are you using encryption:** yes
**Are you using an external user-backend, if yes which one:No
SELECT * FROM oc_appconfig WHERE appid = ‘user_ldap’;
### Client configuration
**Browser:** Chrome
**Operating system:** Windows
### Logs
#### Web server error log
{"reqId":"X9DKfONRu0k6zknZc7O1","level":3,"time":"July 03, 2019 19:40:49","remoteAddr":"xxxx.xxxx.xxxx.xxxx","user":"andrea","app":"PHP","method":"MOVE","url":"\/remote.php\/dav\/uploads\/andrea\/web-file-upload-1870f8f3b2bc014f30d4fe0192d8b4aa-1562182576842\/.file","message":"Allowed memory size of 536870912 bytes exhausted (tried to allocate 637706272 bytes) at \/opt\/bitnami\/apps\/owncloud\/htdocs\/lib\/composer\/guzzle\/stream\/Guzzle\/Stream\/Stream.php#71"}
#### Browser log
c) …
Hi
have you tried the steps described here?
https://doc.owncloud.com/server/10.1/admin_manual/configuration/files/big_file_upload_configuration.html
I did the following search: Google Search and found quite a lot of resources which could help like e.g.:
https://www.airpair.com/php/fatal-error-allowed-memory-size
