Android, iOS clients issues - owncloud 10.0.4
Hi all,
actually, after upgrade from 9.0 to 10.0.4 I cannot connect android an IOS clients to server, also I cannot understand very well the log, it seems a table in my db is missing.
  1. Install android client
  2. Try to login
User get Logged In and can access Files
User can’t login, “wrong server configuration” message
Operating system: Ubuntu Server 16.04 LTS
Web server: Apache2
Database: mariaDB
PHP version: PHP7
ownCloud version: (see ownCloud admin page) 10.0.0.4
Updated from an older ownCloud or fresh install: Updated from Older version to latest
Where did you install ownCloud from: from source files
**List of activated apps:**
Enabled:
  - audioplayer: 2.2.1
  - calendar: 1.5.4
  - comments: 0.3.0
  - configreport: 0.1.1
  - contacts: 1.5.3
  - dav: 0.3.1
  - encryption: 1.3.1
  - external: 1.2
  - federatedfilesharing: 0.3.1
  - federation: 0.1.0
  - files: 1.5.1
  - files_antivirus: 0.10.1.0
  - files_clipboard: 0.6.2
  - files_external: 0.7.1
  - files_external_ftp: 0.2.0
  - files_sharing: 0.10.1
  - files_trashbin: 0.9.1
  - files_versions: 1.3.0
  - files_videoplayer: 0.9.8
  - firstrunwizard: 1.1
  - market: 0.2.2
  - notifications: 0.3.1
  - onlyoffice: 1.1.6
  - ownbackup: 17.7.0
  - passman: 2.1.4
  - phonetrack: 0.0.8
  - provisioning_api: 0.5.0
  - systemtags: 0.3.0
  - templateeditor: 0.1
  - theme-example: 1.0.0
  - updatenotification: 0.2.1
  - user_external: 0.4
**Are you using external storage, if yes which one:** local/smb/sftp/... NO
**Are you using encryption:** NO
**Are you using an external user-backend, if yes which one:**
SELECT * FROM oc_appconfig WHERE appid = ‘user_ldap’;
### Client configuration
**Browser:** Firefox
**Operating system:** Windows 10 PRO
### Logs
#### Web server error log
