- Create a set of directories which names can be numbered, “0”, “1”, “2”, …, for example in a SFTP external storage
- Log into owncloud and go to the SFTP external storage to check the directory in which the new sub-directories with their numeric names were created.
The new sub-directories should be visible there in such a directory
All the sub-directories with the exception of the sub-directory, “0”, are visible there. Only the sub-directory, “0”, is hidden despite having the same rights as the other sub-directories. Even, the number of sub-directories shown there does not include the sub-directory, “0”. Besides, all the contents of the SFTP are visible with the exception of any directory named as “0”.
Operating system: CentOS 3.10.0-862.14.4.el7.x86_64
Web server: Apache/2.4.6 (CentOS)
Database: sqlite x86_64 3.7.17
PHP version: PHP 7.1.23 (cli) (built: Oct 10 2018 12:11:12) ( NTS )
ownCloud version: 10.0.10.4 (Community Version)
Where did you install ownCloud from: The official repository
Signing status (ownCloud 9.0 and above): No errors have been found.
"system": {
"updatechecker": false,
"trusted_domains": [
"localhost",
"x.x.x.x"
"datadirectory": "\/var\/www\/html\/owncloud\/data",
"overwrite.cli.url": "http:\/\/localhost",
"dbtype": "sqlite3",
"version": "10.0.10.4",
"logtimezone": "UTC",
"installed": true,
"instanceid": "oct85fy63bib",
"ldapIgnoreNamingRules": false
Enabled:
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.4.0
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_clipboard: 0.7.1
- files_external: 0.7.1
- files_pdfviewer: 0.9.0
- files_sharing: 0.11.0
- files_texteditor: 2.2.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- gallery: 16.1.0
- market: 0.2.5
- notifications: 0.3.5
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- updatenotification: 0.2.1
- user_ldap: 0.11.0
Disabled: - encryption
- external
- user_external
Are you using external storage, if yes which one: sftp
Are you using encryption: no
Browser: Chrome and Microsoft Edge
Operating system: Centos 7 and Windows 10
