Apache mod_unique_id not working?
Compare phpinfo() UNIQUE_ID with reqId in owncloud.log
The documentation says that they should be the same
reqId in my owncloud.log has a different value for each line
Operating system: Ubuntu 18.04 LTS
Web server: Apache2
Database: mariadb
PHP version: 7.2.24
ownCloud version: 10.3.2.2
Where did you install ownCloud from: I downloaded it from the official website
"config": {
        "trusted_domains": [
            "localhost",
        "overwrite.cli.url": "http:\/\/localhost\/",
        "dbtype": "mysql",
        "version": "10.3.2.2",
        "dbname": "owncloud",
        "dbhost": "localhost",
        "dbtableprefix": "oc_",
        "logtimezone": "UTC",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/apps-external",
                "writable": true
        "installed": true,
        "instanceid": "oczzbvjoamtc",
        "filelocking.enabled": true,
        "redis": {
            "host": "localhost",
            "port": 6379,
            "timeout": 0,
            "password": "***REMOVED SENSITIVE VALUE***"
        "mail_smtpmode": "php",
        "skeletondirectory": "",
        "integrity.ignore.missing.app.signature": [
Admin config report
Deleted files
Share files
Update notifications
Versions
Media viewer
Notifications
A customized theme (very simple)
Are you using encryption: No
{"reqId":"XjMonwE@5x-yDGEhJDpdswAAAAI","level":2,"time":"2020-01-30T19:03:59+00:00","remoteAddr":"37.70.42.112","user":"--","app":"core","method":"GET","url":"\/","message":"Trusted domain error. \"37.70.42.112\" tried to access using \"*********:80\" as host."}
{"reqId":"XjNADeou5-i80hMmjNJ@ngAAAAA","level":2,"time":"2020-01-30T20:43:57+00:00","remoteAddr":"170.82.7.250","user":"--","app":"core","method":"GET","url":"\/","message":"Trusted domain error. \"170.82.7.250\" tried to access using \"*********:80\" as host."}
{"reqId":"XjNAWqaCiuDHCpRvBr7@qQAAAA4","level":2,"time":"2020-01-30T20:45:14+00:00","remoteAddr":"51.254.59.114","user":"--","app":"core","method":"GET","url":"\/","message":"Trusted domain error. \"51.254.59.114\" tried to access using \"*********\" as host."}
{"reqId":"XjNa6BIk3HRShQtZbLewQgAAAAg","level":2,"time":"2020-01-30T22:38:32+00:00","remoteAddr":"170.84.105.114","user":"--","app":"core","method":"GET","url":"\/","message":"Trusted domain error. \"170.84.105.114\" tried to access using \"*********\" as host."}
{"reqId":"XjNdL25cW77mZmCSsQ5g@gAAAAI","level":2,"time":"2020-01-30T22:48:15+00:00","remoteAddr":"78.187.30.238","user":"--","app":"core","method":"GET","url":"\/","message":"Trusted domain error. \"78.187.30.238\" tried to access using \"*********:80\" as host."}
The log lines you posted are all different requests from different IP addresses. So I don’t understand why it’s a problem for you that these requests have different reqIDs?
What is actually not working for you?
Perhaps you just need to add your domain to the trusted domains in the config.php?
Thanks for your answer!
I thought that all reqIDs should be the same (following https://doc.owncloud.com/server/10.3/admin_manual/installation/manual_installation.html#apache-mod_unique_id-configuration). But as I have no idea what exactly mod_unique_id is, maybe I misunderstood?
