I’m trying to add a certificate as per the instructions here: https://doc.owncloud.com/server/admin_manual/appliance/configuration/certificates.html
- I try to execute the first command: ucr set apache2/ssl/certificate="/etc/[MYPATH]"
But I get and error:
Command ‘ucr’ not found, did you mean:
command ‘ur’ from deb libur-perl
command ‘ucfr’ from deb ucf
command ‘acr’ from deb acr
command ‘ccr’ from deb codecrypt
command ‘ucc’ from deb exult-studio
command ‘ucf’ from deb ucf
Try: sudo apt install
Operating system: Ubuntu v18.04
Web server: 2.4.29
Database: MySQL 5.0.12
PHP version: 7.2.10
ownCloud version: 10
Updated from an older ownCloud or fresh install: 9
Where did you install ownCloud from: [http://download.owncloud.org/download/repositories/production/Ubuntu_18.04/ ]
```Says: "No errors have been found."
<?php
$CONFIG = array (
'updatechecker' => false,
'instanceid' => 'HIDDEN',
'passwordsalt' => 'HIDDEN',
'secret' => 'HIDDEN',
'trusted_domains' =>
array (
0 => 'localhost',
1 => 'HIDDEN',
'datadirectory' => '/mnt/hgfs/HIDDEN',
'overwrite.cli.url' => 'http://localhost/owncloud',
'dbtype' => 'mysql',
'version' => '10.0.10.4',
'dbname' => 'HIDDEN',
'dbhost' => 'localhost',
'dbtableprefix' => 'oc_',
'dbuser' => 'HIDDEN',
'dbpassword' => 'HIDDEN',
'files_external_allow_create_new_local' => 'true',
'logtimezone' => 'Europe/London',
'installed' => true,
'mail_from_address' => 'info',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'HIDDEN',
'mail_smtpauthtype' => 'LOGIN',
'mail_smtphost' => 'HIDDEN',
'mail_smtpport' => '25',
'mail_smtpauth' => 1,
'appstore.experimental.enabled' => true,
'mail_smtpname' => 'HIDDEN',
'mail_smtppassword' => 'HIDDEN',
'log_type' => 'owncloud',
'logfile' => '/var/log/owncloud.log',
'loglevel' => 3,
'syslog_tag' => 'ownCloud',
'logdateformat' => 'F d, Y H:i:s',
'log_query' => true,
'debug' => false,
'maintenance' => false,
‘admin’ -> ‘Generate Config Report’ -> ‘Download ownCloud config report’
**List of activated apps:**
Calendar
Text Editor
PDF Viewer
Gallery
Activity
Audio Player
Password Policy
Market
Mail Template Editor
Camera RAW Previews
Media Viewer
Yes, Local
Yes
No
### Client configuration
**Browser:**
Safari12.1.2
**Operating system:**
Mac OS 10.14.6
### Logs
#### Web server error log
#### Browser log
c) …
