- Install owncloud on debian 7
- Install php-apc
- Edit the config to use APC for caching
APC is used for caching.
It seems like APC isn’t used.
I don’t know how the use of APC is implemented in the code. But I got the following error log each time the cron job is running.
I successfully install the php-apc package and enable it.
I actually use owncloud in a chrooted environnement.
{"reqId":"Ilx8paadA2ju0fOmlwFB","remoteAddr":"","app":"cli","message":"Memcache \\OC\\Memcache\\APC not available for local cache","level":1,"time":"2016-10-21T14:00:01+00:00","method":"--","url":"--"}
{"reqId":"Ilx8paadA2ju0fOmlwFB","remoteAddr":"","app":"cli","message":"Memcache \\OC\\Memcache\\APC not available for distributed cache","level":1,"time":"2016-10-21T14:00:01+00:00","method":"--","url":"--"}
Operating system: Debian 7
Web server: Apache 2.2.22
Database: MySQL server 5.5.41
PHP version: PHP 5.4.38 (yeah I know I should move to 5.5 but the server runs other services that I haven’t upgrade to use 5.5)
ownCloud version: 9.0.0
Where did you install ownCloud from: git stable branch
Signing status (ownCloud 9.0 and above): Sorry I disable integrity checker.
Enabled:
- activity: 2.2.3
- calendar: 1.2.2
- comments: 0.2
- contacts: 1.3.1.0
- dav: 0.1.5
- federatedfilesharing: 0.1.0
- federation: 0.0.4
- files: 1.4.4
- files_pdfviewer: 0.8
- files_sharing: 0.9.1
- files_texteditor: 2.1
- files_trashbin: 0.8.0
- files_videoplayer: 0.9.8
- gallery: 14.5.0
- notifications: 0.2.3
- provisioning_api: 0.4.1
- systemtags: 0.2
- templateeditor: 0.1
- updatenotification: 0.1.0
Disabled:
- encryption
- external
- files_external
- files_versions
- firstrunwizard
- user_external
- user_ldap
"system": {
"instanceid": "ocl4w3y4pz2m",
"trusted_domains": [
"example.com"
"datadirectory": "\/htdocs\/data",
"overwrite.cli.url": "https:\/\/example.com",
"share_folder": "\/Shared",
"default_language": "fr",
"dbtype": "mysql",
"version": "9.0.0.19",
"dbname": "example_owncloud",
"dbhost": "127.0.0.1",
"dbtableprefix": "oc_",
"logtimezone": "UTC",
"overwriteprotocol": "https",
"installed": true,
"mail_smtpmode": "smtp",
"mail_domain": "example.com",
"theme": "",
"loglevel": 0,
"maintenance": false,
"trashbin_retention_obligation": "auto",
"forcessl": true,
"proxy": "172.18.8.24:3128",
"appcodechecker": true,
"appstoreenabled": true,
"appstoreurl": "https:\/\/apps.owncloud.com\/",
"mail_from_address": "admin",
"integrity.check.disabled": true,
"mail_smtphost": "127.0.0.1",
"mail_smtpport": "25",
"memcache.local": "\\OC\\Memcache\\APC"
Are you using encryption: no
Browser: Firefox 45.4.0
Operating system: Debian 8
Nothing particular
{"reqId":"Ilx8paadA2ju0fOmlwFB","remoteAddr":"","app":"cron","message":"Run job with ID 63885","level":0,"time":"2016-10-21T14:00:02+00:00","method":"--","url":"--"}
Nothing particular here
I am talking about APC, not APCu because for now I cannot upgrade to php 5.5.
Can someone help fixing this error ?
Thanks in advance.
