APCu not available for local and distributed cache
Hello, I got trouble with APCu. It says Memcache \OC\Memcache\APCu not available for distribute/local cache, but APCu is running (Version 4.0.10)
normaly this should work
Memcache \OC\Memcache\APCu not available for local cache
Memcache \OC\Memcache\APCu not available for distributed cache
Operating system: CentOS 7
Web server: Apache 2.4.6
Database: MariaDB 10.1.16
PHP version: 5.5.21
Updated from an older ownCloud or fresh install: no
{"reqId":"XX","remoteAddr":"","app":"no app in context","message":"Invalidating tokens older than 2016-07-28T01:45:02+00:00","level":1,"time":"2016-07-28T08:45:02+02:00","method":"--","url":"--","user":"--"}
{"reqId":"XX","remoteAddr":"","app":"cli","message":"Memcache \\OC\\Memcache\\APCu not available for local cache","level":1,"time":"2016-07-28T09:00:01+02:00","method":"--","url":"--","user":"--"}
{"reqId":"XX","remoteAddr":"","app":"cli","message":"Memcache \\OC\\Memcache\\APCu not available for distributed cache","level":1,"time":"2016-07-28T09:00:01+02:00","method":"--","url":"--","user":"--"}
{"reqId":"XX","remoteAddr":"","app":"no app in context","message":"Invalidating tokens older than 2016-07-28T02:00:01+00:00","level":1,"time":"2016-07-28T09:00:01+02:00","method":"--","url":"--","user":"--"}
{"reqId":"XX","remoteAddr":"","app":"cli","message":"Memcache \\OC\\Memcache\\APCu not available for local cache","level":1,"time":"2016-07-28T09:15:01+02:00","method":"--","url":"--","user":"--"}
{"reqId":"XX","remoteAddr":"","app":"cli","message":"Memcache \\OC\\Memcache\\APCu not available for distributed cache","level":1,"time":"2016-07-28T09:15:01+02:00","method":"--","url":"--","user":"--"}
{"reqId":"XX","remoteAddr":"","app":"no app in context","message":"Invalidating tokens older than 2016-07-28T02:15:01+00:00","level":1,"time":"2016-07-28T09:15:01+02:00","method":"--","url":"--","user":"--"}
{"reqId":"XX","remoteAddr":"","app":"cli","message":"Memcache \\OC\\Memcache\\APCu not available for local cache","level":1,"time":"2016-07-28T09:30:01+02:00","method":"--","url":"--","user":"--"}
{"reqId":"XX","remoteAddr":"","app":"cli","message":"Memcache \\OC\\Memcache\\APCu not available for distributed cache","level":1,"time":"2016-07-28T09:30:01+02:00","method":"--","url":"--","user":"--"}
{"reqId":"XX","remoteAddr":"","app":"no app in context","message":"Invalidating tokens older than 2016-07-28T02:30:02+00:00","level":1,"time":"2016-07-28T09:30:02+02:00","method":"--","url":"--","user":"--"}
{"reqId":"XX","remoteAddr":"","app":"cli","message":"Memcache \\OC\\Memcache\\APCu not available for local cache","level":1,"time":"2016-07-28T09:45:01+02:00","method":"--","url":"--","user":"--"}
{"reqId":"XX","remoteAddr":"","app":"cli","message":"Memcache \\OC\\Memcache\\APCu not available for distributed cache","level":1,"time":"2016-07-28T09:45:01+02:00","method":"--","url":"--","user":"--"}
{"reqId":"XX","remoteAddr":"","app":"no app in context","message":"Invalidating tokens older than 2016-07-28T02:45:01+00:00","level":1,"time":"2016-07-28T09:45:01+02:00","method":"--","url":"--","user":"--"}
  • SELinux enforced
Integrity status for oC9+
you need to configure the following php.ini config options to prevent that these messages appears:
https://github.com/owncloud/documentation/issues/2546
Okay, I’ll try this. Thanks!
By the way, can you tell me something about this line?
Please try to not mix different issues / questions in one thread for the reasons described here:
Errors are still there … :confused:
Then you probably have choosen the wrong php.ini. There are two, one for your webserver and one for the command line / cli.
Thanks, this worked fine :slight_smile:
