[root@localhost ~]# pecl install apcu
downloading apcu-5.1.12.tgz …
Starting to download apcu-5.1.12.tgz (105,890 bytes)
…done: 105,890 bytes
39 source files, building
running: phpize
Configuring for:
PHP Api Version: 20151012
Zend Module Api No: 20151012
Zend Extension Api No: 320151012
Enable internal debugging in APCu [no] : y
building in /var/tmp/pear-build-rootPjEhxK/apcu-5.1.12
running: /var/tmp/apcu/configure --with-php-config=/usr/bin/php-config --enable-apcu-debug=y
checking for grep that handles long lines and -e… /usr/bin/grep
checking for egrep… /usr/bin/grep -E
checking for a sed that does not truncate output… /usr/bin/sed
checking for cc… no
checking for gcc… no
configure: error: in /var/tmp/pear-build-rootPjEhxK/apcu-5.1.12': configure: error: no acceptable C compiler found in $PATH Seeconfig.log’ for more details
ERROR: `/var/tmp/apcu/configure --with-php-config=/usr/bin/php-config --enable-apcu-debug=y’ failed
no errors
errors above
CentOS 7
Web server: apache
Database: mariadb
PHP version: 7.00
ownCloud version:10. (see ownCloud admin page)
Where did you install ownCloud from:10.0.9
Signing status (ownCloud 9.0 and above):10.0.9.5
Sorry if this looks like a noob problem, I am a noob in Centos.
