App does not recognize when WiFi has been restored
With Photo auto-upload on WiFi only enabled, photos taken while not on WiFi coverage do not automatically upload after returning to WiFi coverage.
The app should detect the presence of/switch to WiFi, and trigger the upload queue automatically.
  1. Install OC client and enable Auto-Upload photos on Wifi only. Test and validate this works on WiFi.
  2. Leave/Disable WiFi coverage and take a new photo. Within 15 minutes it will appear in the upload queue as expected, with the “Waiting for WiFi” status.
  3. Return to WiFi coverage. Items in the upload queue will remain in “Waiting for WiFi status” for at least 24 hours. The “Retry failed” option will trigger the uploads, which complete successfully. The app will then usually crash.
Can this problem be reproduced with the official owncloud server?
(url: https://demo.owncloud.org, user: test, password: test)
Yes. Validated auto-upload on wifi. No auto-upload to demo server 20+ minutes after returning to WiFi. App crashed while browsing upload queue.
Edit: Auto-upload to demo server triggered after app auto-restart from crash.
Environment data
Android version:
8.1.0 Dec 5 2018
Device model:
Nexus 6P
Stock or customized system:
Stock
ownCloud app version:
2.10.0 release 6d34130f8
ownCloud server version:
10.1.1
No entries in Apache error log. (expected since this is a client issue)
No new entries generated in OC server log for the duration of the test (expected since this is a client issue)
personally i would report such issues directly to a bugtracker instead of a user support forums. AFAIK the following bugtracker is used for the Android app: https://github.com/owncloud/android/issues
Maybe you can also already find some related bugreports there?
Thank you. It appears there is an open issue for this, #2460. I will update that.
Thanks!
