Apparently symlinks are not supported
Hi
We know that it is not allowed to create symlinks on a webdav (owncloud) mounted folder. We would like to do this:
ln -s /mnt/webdav/user/dirA/dirA1 /mnt/webdav/user/dirB/dirB1
Where /mnt/webdav/user is be the webdav mount.
Any ideas?
Hi ICNMG.
I don’t understand the purpose of your idea. What is the use case for symlinking a user’s directory to another this user’s directory?
Maybe the logical issue is on the concept?
Hi cortho,
The idea would be saving disk space so files exist inside a single folder.
I still don’t quite understand your use case:
  • Are you running a terminal server where multiple users are logged in simultaneously?
  • And all of these users have a webdav client running.
  • Because some users share a large data folder you were hoping to symlink the data as to not duplicate it?
