After upgrading our Mac Mini (2018) OS X from Mojave to Catalina, We are unable to access owncloud from client or from the browser. We are able to login to the Univention portal. We do have access to the Virtual Box Appliance’s command line.
Go to (address)/owncloud
Check owncloud client app’s settings
Login window to Owncloud appears
List of synced folders show in the settings window
Service Unavailable page shows on browser
No connection message in the settings window
Operating system: OSX Catalina (15.5)
Virtual box appliance setup (Apache)
Virtual box appliance setup (MySQL)
10.2.1-1
From older ownCloud
Virtual box Appliance from:
Unable to login to Web UI
Unable to retrieve by the suggestions below, occ command not found
Let’s Encrypt
No
yes
Are you using an external user-backend, if yes which one:
No
Firefox, Chrome, Safari, Internet explorer
Windows 10 pro x64, OSX Catalina (15.5)
None
File too large, here is the most recent entry:
{“reqId”:“TyNGAD6MhC4vbu69uQqA”,“level”:3,“time”:“2020-06-23T05:38:34+00:00”,“remoteAddr”:"",“user”:"–",“app”:“no app in context”,“method”:"–",“url”:"–",“message”:“Caused by: {“Exception”:“PDOException”,“Message”:“SQLSTATE[HY000]: General error: 2006 MySQL server has gone away”,“Code”:“HY000”,“Trace”:”#0 \/var\/www\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOStatement.php(105): PDOStatement->execute(Array)\n#1 \/var\/www\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php(849): Doctrine\\DBAL\\Driver\\PDOStatement->execute(Array)\n#2 \/var\/www\/owncloud\/lib\/private\/DB\/Connection.php(187): Doctrine\\DBAL\\Connection->executeQuery(‘SELECT appid,…’, Array, Array, NULL)\n#3 \/var\/www\/owncloud\/lib\/private\/AllConfig.php(389): OC\\DB\\Connection->executeQuery(‘SELECT appid,…’, Array)\n#4 \/var\/www\/owncloud\/lib\/private\/AllConfig.php(271): OC\\AllConfig->getUserValues(’’)\n#5 \/var\/www\/owncloud\/lib\/private\/legacy\/util.php(233): OC\\AllConfig->getUserValue(’’, ‘owncloud’, ‘isGuest’, false)\n#6 \/var\/www\/owncloud\/lib\/private\/Files\/Filesystem.php(352): OC_Util::setupFS()\n#7 \/var\/www\/owncloud\/lib\/private\/Files\/View.php(1176): OC\\Files\\Filesystem::resolvePath(’\/files_encrypti…’)\n#8 \/var\/www\/owncloud\/lib\/private\/Files\/View.php(540): OC\\Files\\View->basicOperation(‘file_exists’, ‘\/files_encrypti…’)\n#9 \/var\/www\/owncloud\/lib\/private\/Encryption\/Keys\/Storage.php(234): OC\\Files\\View->file_exists(’\/files_encrypti…’)\n#10 \/var\/www\/owncloud\/lib\/private\/Encryption\/Keys\/Storage.php(112): OC\\Encryption\\Keys\\Storage->getKey(’\/files_encrypti…’)\n#11 \/var\/www\/owncloud\/apps\/encryption\/lib\/KeyManager.php(553): OC\\Encryption\\Keys\\Storage->getSystemUserKey(‘pubShare_46e656…’, ‘OC_DEFAULT_MODU…’)\n#12 \/var\/www\/owncloud\/apps\/encryption\/lib\/KeyManager.php(144): OCA\\Encryption\\KeyManager->getPublicShareKey()\n#13 \/var\/www\/owncloud\/apps\/encryption\/lib\/Users\/Setup.php(83): OCA\\Encryption\\KeyManager->validateShareKey()\n#14 \/var\/www\/owncloud\/apps\/encryption\/lib\/AppInfo\/Application.php(71): OCA\\Encryption\\Users\\Setup->setupSystem()\n#15 \/var\/www\/owncloud\/apps\/encryption\/appinfo\/app.php(30): OCA\\Encryption\\AppInfo\\Application->__construct(Array, true)\n#16 \/var\/www\/owncloud\/lib\/private\/legacy\/app.php(239): require_once(’\/var\/www\/ownclo…’)\n#17 \/var\/www\/owncloud\/lib\/private\/legacy\/app.php(190): OC_App::requireAppFile(‘encryption’)\n#18 \/var\/www\/owncloud\/lib\/private\/legacy\/app.php(124): OC_App::loadApp(‘encryption’)\n#19 \/var\/www\/owncloud\/lib\/private\/Console\/Application.php(99): OC_App::loadApps()\n#20 \/var\/www\/owncloud\/console.php(105): OC\\Console\\Application->loadCommands(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#21 \/var\/www\/owncloud\/occ(11): require_once(’\/var\/www\/ownclo…’)\n#22 {main}",“File”:"\/var\/www\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOStatement.php",“Line”:105}"}
None
Please let us know if you need additional information
