APPS Update problem
I updated, when I restart I receive the warning that there are apps to update, I gave the command: sudo -u www-data ./occ upgrade but I receive this:
2024-12-03T23:37:54+00:00 Set log level to debug
2024-12-03T23:37:54+00:00 Turned on maintenance mode
2024-12-03T23:37:54+00:00 Repair step: Upgrade app code from the marketplace
2024-12-03T23:37:54+00:00 Repair warning: You have incompatible or missing apps enabled that could not be found or updated via the marketplace.
2024-12-03T23:37:54+00:00 Repair warning: Please install or update the following apps manually or disable them with:
occ app:disable gallery
occ app:disable music
2024-12-03T23:37:54+00:00 Repair warning: For manually updating, see https://doc.owncloud.com/server/10.13/go.php?to=admin-marketplace-apps
2024-12-03T23:37:54+00:00 OC\RepairException: Upgrade is not possible
2024-12-03T23:37:54+00:00 Update failed
2024-12-03T23:37:54+00:00 Maintenance mode is kept active
2024-12-03T23:37:54+00:00 Reset log level
Could you help me?
Have you disabled the apps as suggested?
This is strange, as both apps should be upgradable via marketplace.
However, disable them and start over with upgrading.
fortunately I just needed to disable the apps and I was able to update, thank you
