I’m currently looking at migrating our existing OwnCloud deployment to OCIS (deployed on kubernetes provided by k3s), and having some difficulty getting the authentication/login working. We use Active Directory as the LDAP backend, and use Apereo CAS as the OIDC provider. I believe I’ve correctly configured everything, but I still get the error:
Not logged in
This could be because of a routine safety log out, or because your account is either inactive or not yet authorized for use. Please try logging in after a while or seek help from your Administrator.
It’s not clear to me why this is happening, can anyone give any suggestions?
I can’t seem to post or upload the values file, so here’s the subsection on oidc and ldap:
# External user management
externalUserManagement:
# -- Enables external user management (and disables internal user management).
# Needs an external OpenID Connect Identity Provider and an external LDAP server.
enabled: true
# -- UUID of the inital admin user.
# If the given value matches a user's value from `features.externalUserManagement.oidc.userIDClaim`, the admin role will be assigned.
# Consider that the UUID can be encoded in some LDAP deployment configurations like in .ldif files. These need to be decoded beforehand.
# Note: Enabling `roleAssignment` will disable `adminUUID`.
# This is James' Prod User
adminUUID: "b091cb4fe8c78449bdd9ba973d7e6af2"
# OpenID Connect Identity provider related settings.
oidc:
# -- Issuer URI of the OpenID Connect Identity Provider.
# If the IDP doesn't have valid / trusted SSL certificates, certificate validation can be disabled with the `insecure.oidcIdpInsecure` option.
issuerURI: https://auth-mfa.datacentral.org.au/cas/oidc
# -- Link to the OIDC provider's user accessible session management. This will be shown to the user on the personal account page.
# When using Keycloak with the a realm named "ocis" this could point to eg. https://keycloak.owncloud.test/realms/ocis/account/
sessionManagementLink: https://accounts.datacentral.org.au
# -- Link to the OIDC provider's user accessible account editing page. This will be shown to the user on the personal account page.
editAccountLink: https://accounts.datacentral.org.au
# -- Specify the client ID which the web frontend will use
webClientID: ofpuU9v7nPHY0ENpdEWZBndUVqtDbcJuNiYH
# -- Claim to take an unique user identifier from. It will be used to look up the user on the LDAP server.
userIDClaim: sub
# -- Attribute mapping of for the userIDClaim.
# Set to `userid` if the claim specified in `...oidc.userIDClaim` holds the value of the ldap user attribute specified in `...ldap.user.schema.id`.
# Set to `mail` if the claim specified in `...oidc.userIDClaim` holds the value of the ldap user attribute specified in `...ldap.user.schema.mail`.
# Set to `username` if the claim specified in `...oidc.userIDClaim` holds the value of the ldap user attribute specified in `...ldap.user.schema.userName`.
userIDClaimAttributeMapping: username
# -- OIDC Acces Token Verify Method
# Set to "jwt" or "none"
accessTokenVerifyMethod: "none"
# -- Configure OIDC role assignment. If activated, oCIS will read the role assigment from the OIDC token, see
# xref:{s-path}/proxy.adoc#automatic-role-assignments[Automatic Role Assignments]
roleAssignment:
enabled: false
# -- The name of the OIDC claim holding the role assignment
claim: roles
# -- Configure the mapping for the role assignment
mapping:
- role_name: admin
claim_value: ocisAdmin
- role_name: spaceadmin
claim_value: ocisSpaceAdmin
- role_name: user
claim_value: ocisUser
- role_name: guest
claim_value: ocisGuest
# LDAP related settings.
ldap:
# -- Writeable configures if oCIS is allowed to write to the LDAP server, to eg. create or edit users.
writeable: false
# -- If the LDAP server is set to writable in general, some user attributes can be restricted to read only in the UI.
# Note: This only disables editing in the UI. The readonly permissions need to be enforced in the LDAP server itself.
readOnlyAttributes:
# - user.onPremisesSamAccountName # username
# - user.displayName # display name
# - user.mail # mail
# - user.passwordProfile # password
# - user.appRoleAssignments # role
# - user.accountEnabled # login allowed
# - drive.quota # quota
# -- URI to connect to the LDAP secure server.
uri: ldap://10.80.11.2:3268
# -- Set only to false, if the certificate of your LDAP secure service is not trusted.
# If set to false, you need to put the CA cert of the LDAP secure server into the secret referenced by "ldapCaRef"
certTrusted: true
# -- Disables SSL certificate checking for connections to the LDAP server.
# -- For self signed certificates, consider to put the CA cert of the LDAP secure server into the secret referenced by "ldapCaRef"
# Not recommended for production installations.
insecure: true
# -- DN of the user to use to bind to the LDAP server.
# The password for the user needs to be set in the secret referenced by `secretRefs.ldapSecretRef` as `reva-ldap-bind-password`.
# The user needs to have permission to list users and groups.
bindDN: cn=adc_connect,dc=asvo,dc=aao,dc=gov,dc=au
# -- Signals that the LDAP server has the refint plugin enabled, which makes some actions not needed.
refintEnabled: false
# -- Use the Password Modify Extended Operation for updating user passwords.
passwordModifyExOpEnabled: false
# -- If set to true, rely on the LDAP Server to generate a unique ID for users and groups, like when using 'entryUUID' as the user ID attribute.
useServerUUID: true
user:
schema:
# -- LDAP Attribute to use as the unique id for users. This should be a stable globally unique id like a UUID.
# -- Set this to true if the defined `id` attribute for users is of the `OCTETSTRING` syntax. This is e.g. required when using the `objectGUID` attribute of Active Directory for the user ID`s.
idIsOctetString: true
# -- LDAP Attribute to use for the email address of users.
mail: mail
# -- LDAP Attribute to use for the displayname of users.
displayName: displayname
# -- LDAP Attribute to use for username of users.
userName: sAMAccountName
# -- LDAP Attribute to distinguish between 'Member' and 'Guest' users. Default is 'ownCloudUserType'.
userType: ownCloudUserType
# -- Search base DN for looking up LDAP users.
baseDN: ou=Standard,ou=Accounts,dc=asvo,dc=aao,dc=gov,dc=au
# -- LDAP search scope to use when looking up users. Supported values are `base`, `one` and `sub`.
scope: sub
# -- Type of substring search filter to use for substring searches for users. Possible values: `initial` for doing prefix only searches, `final` for doing suffix only searches or `any` for doing full substring searches
substringFilterType: any
# -- LDAP filter to add to the default filters for user search like `(objectclass=ownCloud)`.
filter:
# -- The object class to use for users in the default user search filter like `inetOrgPerson`.
objectClass: user
group:
schema:
# -- LDAP Attribute to use as the unique ID for groups. This should be a stable globally unique ID like a UUID.
# -- Set this to true if the defined `id` attribute for groups is of the `OCTETSTRING` syntax. This is e.g. required when using the `objectGUID` attribute of Active Directory for the group ID`s.
# -- LDAP Attribute to use for the email address of groups (can be empty).
mail: mail
# -- LDAP Attribute to use for the displayname of groups (often the same as groupname attribute).
displayName: cn
# -- LDAP Attribute to use for the name of groups.
groupName: cn
# -- LDAP Attribute that is used for group members.
member: member
# -- Search base DN for looking up LDAP groups.
baseDN: ou=Groups,ou=Accounts,dc=asvo,dc=aao,dc=gov,dc=au
# -- BaseDN where new groups are created and are considered as editable.
# All existing groups with a DN outside the `features.externalUserManagement.ldap.group.createBaseDN` will be treated as read-only groups.
# Defaults to the value `features.externalUserManagement.ldap.group.baseDN`.
# Only applicable if `features.externalUserManagement.ldap.writeable` is set to `true`
createBaseDN: ""
# -- LDAP search scope to use when looking up groups. Supported values are `base`, `one` and `sub`.
scope: sub
# -- LDAP filter to add to the default filters for group searches.
filter:
# -- The object class to use for groups in the default group search filter like `groupOfNames`.
objectClass: group
# -- When using external user management, users can be set as disabled by either belonging to a group or using an ldap attribute.
disableUsers:
# -- Enables disabling users if configured as "attribute" or "group"
disableMechanism: none
# -- Attribute to use for disabling users.
userEnabledAttribute: ownCloudUserEnabled
# -- Group that a user can be added to and by that being marked as disabled.
disabledUsersGroupDN: "cn=DisabledUsersGroup,ou=groups,o=libregraph-idm"
