- Authentication not possible (message: Wrong user or password)
- Login should work
- use owncloud android app (2.5.0, 2.6.0 or 2.7.0beta)
- enter server https://owncloud.somedomain.com
- message: secure connection established
- enter username / password (working fine connecting using the browser or the ubuntu desktop client or cadaver DAV cli client)
- message: wrong username or password
Environment data
####Mobile client configuration:
Android 4.4.4 or 6.01 (both)
ownCloud Android client: 2.5.0, 2.6.0 or 2.7.0beta
###Server configuration
Apache with PHP CGI/FastCGI
Owncloud 8.2.9 (fresh install)
no entry
Exception: {“Message”:“HTTP/1.1 401 No basic authentication headers were found”,“Exception”:“Sabre\DAV\Exception\NotAuthenticated”,“Code”:0,“Trace”:
Trace on Android client:
PROPFIND /remote.php/webdav/ HTTP/1.1
Depth: 0
Authorization: Basic XXXXXXXX=
User-Agent: Mozilla/5.0 (Android) ownCloud-android/2.7.0-beta.1
Host: owncloud.somedomain.com
Content-Length: 428
Content-Type: text/xml; charset=UTF-8
Date: Sun, 01 Apr 2018 07:27:32 GMT
Server: Apache
X-Powered-By: PHP/5.6.19
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
Content-Security-Policy: default-src ‘self’; script-src ‘self’ ‘unsafe-eval’; style-src ‘self’ ‘unsafe-inline’; frame-src *; img-src * data: blob:; font-src ‘self’ data:; media-src *; connect-src *
X-XSS-Protection: 1; mode=block
X-Content-Type-Options: nosniff
X-Frame-Options: Sameorigin
X-Robots-Tag: none
Vary: Brief,Prefer,Accept-Encoding,User-Agent
DAV: 1, 3, extended-mkcol
Set-Cookie: oc_sessionPassphrase=XXXXXXXX; path=/; secure; httponly
Set-Cookie: XXXXXXXX; path=/; secure; HttpOnly
Strict-Transport-Security: max-age=15768000
Connection: close
Transfer-Encoding: chunked
Content-Type: application/xml; charset=utf-8
340
<?xml version="1.0" encoding="utf-8"?><d:multistatus xmlns:d=“DAV:” xmlns:s=“sabre/dav” xmlns:oc=“http://owncloud.org/ns"><d:response><d:href>/remote.php/webdav/</d:href><d:propstat><d:prop><oc:size>4380635</oc:size><d:resourcetype><d:collection/></d:resourcetype><oc:permissions>RDNVCK</oc:permissions><d:quota-used-bytes>4380635</d:quota-used-bytes><d:getetag>"5abf776734381”</d:getetag><d:getlastmodified>Sat, 31 Mar 2018 11:56:23 GMT</d:getlastmodified>oc:id00000018ocx1h5dyi9en</oc:id><d:quota-available-bytes>852491423744</d:quota-available-bytes></d:prop><d:status>HTTP/1.1 200 OK</d:status></d:propstat><d:propstat><d:prop>oc:privatelink/<d:displayname/><d:creationdate/><d:getcontenttype/><d:getcontentlength/></d:prop><d:status>HTTP/1.1 404 Not Found</d:status></d:propstat></d:response></d:multistatus>
--------then-----------
GET /ocs/v1.php/cloud/user?format=json HTTP/1.1
OCS-APIREQUEST: true
HTTP/1.1 401 Unauthorized
Server: Apache
Pragma: no-cache
X-Robots-Tag: none
WWW-Authenticate: Basic realm=“Authorisation Required”
Set-Cookie: ocx1h5dyi9en=XXXXXXXX; path=/; HttpOnly
Vary: Accept-Encoding,User-Agent
Connection: close
Content-Type: application/json; charset=utf-8
59
{“ocs”:{“meta”:{“status”:“failure”,“statuscode”:997,“message”:“Unauthorised”},“data”:}}
0
