Avoid Subadmin to loads all users at once
  1. Login as Adnin loads 40 Users at once. While Scoling down in user list it loads additional Users
  2. Login as Subadmin loads everytime the full User list at once. Loading time takes up to 3 minutes. Useless for Subadmins
Expecting that Supadmin loads only the first 40 Users, for better user expiriance (short loading time)
Suadmin loads all user at once. CPU usage of Subadmin computer rais up to 130% Spinning weel indicates Loading process and ends after aprox 3 minutes. (Subadmin with 900 Users)
Operating system: Debian 8
Web server: Apache2
Database: Mysql
PHP version: PHP5
ownCloud version (see ownCloud admin page): 9.1.1
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): none
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T21:23:51+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/TEstOrdner 1/s2c.sh): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:23:51+00:00
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T21:23:50+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/TEstOrdner 1/WEPRO AG Server.scpt): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:23:50+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/TEstOrdner 1/TestOrdner 2/wolke.sh): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:23:50+00:00
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T21:18:57+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/MailButler_6648.zip): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:18:57+00:00
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T21:17:58+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/MailButler_6648.zip): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:17:58+00:00
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T21:15:54+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/MailButler_6648.zip): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:15:54+00:00
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T21:14:48+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/MailButler_6648.zip): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:14:48+00:00
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T21:13:48+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/MailButler_6648.zip): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:13:48+00:00
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T21:12:48+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/MailButler_6648.zip): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:12:48+00:00
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T21:12:14+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/MailButler_6648.zip): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:12:14+00:00
Error PHP unlink(): No such file or directory at /var/www/owncloud/lib/private/Preview/MP3.php#45 2017-01-20T21:07:53+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/Test Files/Videos/Demo MP3 - E.J. - Blick Zurück.mp3): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:07:53+00:00
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T21:07:20+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/Test Files/01 Die drei ___ 6 - und der sprechende Totenkopf [1. Justus kauft einen koffer].m4a): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:07:20+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/MailButler_6648.zip): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:07:20+00:00
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T21:06:29+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/Test Files/Test.key): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:06:29+00:00
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T21:06:20+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/Test Files/01 Die drei ___ 6 - und der sprechende Totenkopf [1. Justus kauft einen koffer].m4a): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:06:20+00:00
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T21:06:19+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/MailButler_6648.zip): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:06:19+00:00
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T21:05:20+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/Test Files/01 Die drei ___ 6 - und der sprechende Totenkopf [1. Justus kauft einen koffer].m4a): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:05:20+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/MailButler_6648.zip): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:05:20+00:00
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T21:04:32+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/Test Files/01 Die drei ___ 6 - und der sprechende Totenkopf [1. Justus kauft einen koffer].m4a): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:04:32+00:00
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T21:04:31+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/MailButler_6648.zip): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T21:04:31+00:00
Fatal webdav Exception: {“Message”:“HTTP/1.1 503 Could not open file”,“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Code”:0,“Trace”:“#0 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(83): OCA\DAV\Connector\Sabre\File->get()\n#1 [internal function]: Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#2 /var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:GET’, Array)\n#4 /var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#5 /var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164): require_once(‘/var/www/ownclo…’)\n#7 {main}”,“File”:“/var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php”,“Line”:306,“User”:“michaelfreund”} 2017-01-20T20:56:57+00:00
Error PHP fopen(/var/www/owncloud/data/michaelfreund/files/Private Dokumente/Bildschirmfoto 2016-11-06 um 22.05.31.png): failed to open stream: No such file or directory at /var/www/owncloud/lib/private/Files/Storage/Local.php#278 2017-01-20T20:56:57+00:00
Integrity status for oC9+
Pass
From the issue template you have filled out:
Before posting please snip make sure that you’re running the latest available version for your oC release: Changelog - ownCloud
If that doesn’t bring an improvement for this behavior you need to create a new feature request at GitHub · Where software is built (or search for existing there) as the amount of users to load is not configurable.
Just to give some background info why you always should use the latest available version (currently 9.1.3) instead of staying on an outdated version (your 9.1.1).
The long loading time of the user list with many users was e.g. reported here:
and fixed with 9.1.2:
Hi Guys!
The latest Version of OC has improved user Loading a lot.
From 6min to 3 Sec.
Thanks for your help!!
we can close this ticket
