Begginer issue with first run on iPhone
Hello.
Just insatalled ownCloud on my RaspberryPi and on my iPhone.
Everything ok untill I first ran on iPhone. Can’t get past the name section, once I introduced the webdav adress. Any help?
Thanks in advance…
How does the URL look like? Did you include the remote.php/webdav parts?
Hello.
It looked like this: 192.168.1.72/remote.php/dav/files/danp
And I introduced this value, but in the name section, even if I put the same number, (the ip no.) or my user or the owncloud database name nothing.
So I installed a second app, the owncloud.online one, and for the moment everything ok.
Still I would like to be able to use the first one too, the one with the blue coloured icon. If possible, of course.
Thanks anyway for your help.
P.S: I followed this tutorial in order to install the owncloud on my Raspberry Pi 4, 1 GB: https://computerhoy.com/noticias/tecnologia/haz-raspberry-pi-sea-nube-personal-412645
If it helps…
In the first step, it asks you for the server URL. Please use http://192.168.1.72/ . Because you didn’t setup SSL, you’ll see a warning, so you need to approve, you want to access the ownCloud unencrypted.
