I’m planning to set up OwnCloud for personal use and I’m trying to determine the most recommended installation method. Should I go for the Docker option, use the OwnCloud appliance, or install it directly on my host?
Any advice, pros/cons, or personal experiences would be greatly appreciated!
The best answer for you is going to be completly dependent on your skills and desires. No one but you can answer this question. Do you have specific questions or concerns about any particular method?
I come from a background as a Linux Admin and have even earned RHCSA. While I possess foundational skills and am comfortable navigating the Linux environment, I find myself at a crossroads when it comes to choosing the most suitable method to install OwnCloud.
My primary goal is to deploy a personal cloud solution on my host, but I’m unsure about the trade-offs between the various installation methods available. Given my background and objectives, I’d appreciate any specific recommendations or factors I should consider to make an informed decision.
