Best Practices for performance during Client synchronization
  1. ownCloud Desktop sync on Windows 2008 R2
  2. A Big Folder called “Admin” with 35 directly subfolder, each subfolder with it own structure (subfolder and files…)
  3. I want to know the best practices for configuring the client. What’s the best way?
a) Add just the main folder “Admin” and let the client do the jobs, OR
b) Add each 38 subfolder as a folder connection?
I want to know the best option for performance
My first test, after everything Green (synchronised) I put a single file inside a sub/subfolder on the client and I have 3 minutes when using just option A (only one folder added) and I have 1 minute when using each subfolder… But I really want to hear about your experience.
Client version: 2.2.4
Client operating system: Windows 2008 R2
Folder Size: +/- 400GB
No folder with more than 30.000 files directly
Operating system: CentOS 7 64 bits
rpm -qa|grep http
httpd-tools-2.4.6-40.el7.centos.4.x86_64
httpd24-libnghttp2-1.7.1-1.el7.x86_64
httpd24-httpd-tools-2.4.18-10.el7.x86_64
httpd-2.4.6-40.el7.centos.4.x86_64
httpd24-runtime-1.1-14.el7.x86_64
httpd24-httpd-2.4.18-10.el7.x86_64
rpm -qa|grep -i maria
mariadb-libs-5.5.47-1.el7_2.x86_64
mariadb-server-5.5.47-1.el7_2.x86_64
mariadb-5.5.47-1.el7_2.x86_64
rpm -qa|grep -i php
php55-php-pdo-5.5.21-4.el7.x86_64
php55-php-cli-5.5.21-4.el7.x86_64
php55-php-5.5.21-4.el7.x86_64
php55-php-process-5.5.21-4.el7.x86_64
php55-php-pear-1.9.4-10.el7.noarch
php55-2.0-1.el7.x86_64
php55-runtime-2.0-1.el7.x86_64
php55-php-common-5.5.21-4.el7.x86_64
php55-php-mysqlnd-5.5.21-4.el7.x86_64
php55-php-gd-5.5.21-4.el7.x86_64
sclo-php55-php-pecl-apcu-4.0.10-1.el7.x86_64
php55-php-xml-5.5.21-4.el7.x86_64
php55-php-mbstring-5.5.21-4.el7.x86_64
php55-php-pecl-jsonc-1.3.5-1.el7.x86_64
ownCloud version (see ownCloud admin page): 9.0.4 (stable)
Special configurations (external storage, external authentication, reverse proxy, server-side-encryption): None
ownCloud log (data/owncloud.log) → No error
I don’t really know if there is much difference on the client side after all. But on the server you have quite some potential in optimizing your database settings and php-caching. I run some tests with previous OC versions (I probably should do that again with current versions):
Your result makes sense because currently the client will (on local change detection) traverse all the local files/folders and construct an in-memory sync tree from this.
If it only detects a change in 1 of your 38 configured sync folders, it only has to traverse/construct 1/38th of that amount (why it is still 1min vs 3min can be for other reasons)
