Big filenames / and big folder paths
  1. upload file with big filename
  2. upload folder with big filename
expected to be uploaded
i get a file created Notfound
ubuntu 22 , apache2 , php 7.4
apache2
mariadb 10.6
10.13.2.3
fresh
offical repo
{“reqId”:“oHsprYj1rCDMIaFWQgnZ”,“level”:4,“time”:“2023-11-15T20:38:32+00:00”,“remoteAddr”:“x.x.x.x”,“user”:“username”,“app”:“webdav”,“method”:“PUT”,“url”:“/remote.php/dav/files/username/Kreis%20Paderborn/2019/lfd.%20Nummer/13-2019%20Rahmenkonzept%20Weserlandschaft/Vergabedokumentation%20Weserlandschaft.pdf”,“message”:“Exception: HTTP/1.1 400 expected filesize 791729 got 163840: {"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"expected filesize 791729 got 163840","Code":0,"Trace":"#0 \/var\/www\/owncloud\/apps\/dav\/lib\/Connector\/Sabre\/Directory.php(172): OCA\\DAV\\Connector\\Sabre\\File->put()\n#1 \/var\/www\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(1098): OCA\\DAV\\Connector\\Sabre\\Directory->createFile()\n#2 \/var\/www\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/CorePlugin.php(504): Sabre\\DAV\\Server->createFile()\n#3 \/var\/www\/owncloud\/lib\/composer\/sabre\/event\/lib\/WildcardEmitterTrait.php(89): Sabre\\DAV\\CorePlugin->httpPut()\n#4 \/var\/www\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(472): Sabre\\DAV\\Server->emit()\n#5 \/var\/www\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(253): Sabre\\DAV\\Server->invokeMethod()\n#6 \/var\/www\/owncloud\/apps\/dav\/lib\/Server.php(348): Sabre\\DAV\\Server->start()\n#7 \/var\/www\/owncloud\/apps\/dav\/appinfo\/v2\/remote.php(31): OCA\\DAV\\Server->exec()\n#8 \/var\/www\/owncloud\/remote.php(165): require_once(‘\/var\/www\/ownclo…’)\n#9 {main}","File":"\/var\/www\/owncloud\/apps\/dav\/lib\/Connector\/Sabre\/File.php","Line":231}”}
Filenames are limited to 250 chars / bytes, probably less if ownCloud adds something internally, and 4000 chars / bytes for the whole stored path.
The difference between chars and bytes I think it depends on the DB used. To be on the safe side, I’d recommend a maximum of 200 ascii chars for the filename.
In any case, the error in the logs shows that not the whole file has been uploaded. Check that you have enough free space in the server and in the temporary folder. In addition, you can try to upload the same file with a shorter name.
is there any way to increase the 250 chars limitation ?
It isn’t possible. The limitation is in the DB. Increasing the column length (which you mustn’t do) would just move the goal post without solving the problem.
for this error:
i have also found an existing FAQ entry from an anonymous user here:
