please help me, recently I got pretty big pictures and the OC server is not generating thumbnails and previews. In case of smaller pictures, there is no problem.
Image info (one of many):
root@webhost1:/tmp# identify 20250713-081717-ZD.JPG
20250713-081717-ZD.JPG JPEG 7008x4672 7008x4672+0+0 8-bit sRGB 23.8924MiB 0.030u 0:00.166
I tried to increase config parameters, but still no success:
“enable_previews”: true,
“previewJPEGImageDisplayQuality”: “25”,
“preview_max_x”: “10000”,
“preview_max_y”: “10000”,
“preview_max_filesize_image”: “-1”,
“preview_max_scale_factor”: “10”,
“preview_max_dimensions”: “10000x10000”
Tried to increase the IM policy: /etc/ImageMagick-6/policy.xml
policy domain=“resource” name=“memory” value=“256MiB”
policy domain=“resource” name=“map” value=“512MiB”
policy domain=“resource” name=“area” value=“128MP”
To:
policy domain=“resource” name=“memory” value=“1024MiB”
policy domain=“resource” name=“map” value=“2048MiB”
policy domain=“resource” name=“area” value=“256MP”
Interestingly, the IM CLI convert the image without problem:
convert 20250713-081717-ZD.JPG -quality 60 output2.jpg -verbose
PHP Memory limit is increased also from 256MB to 512MB (its a ~small picture archive server):
memory_limit = 512M
- Upload any picture taken by my friend with his Sony camera.
After upload Thumbnails/previews generated
The upload completes, the files can be downloaded, but the thumbnails are not generated, so only stock image icon is visible.
“Could not generate a preview of this file. Please go to the next slide while we remove this image from the slideshow”
Operating system: Debian GNU/Linux 11 (bullseye)
Web server: apache2 2.4.62-1~deb11u2
root@webhost1:/var/www/owncloud# dpkg -l | grep apache
ii apache2 2.4.62-1~deb11u2 amd64 Apache HTTP Server
root@webhost1:/tmp# dpkg -l | grep mariadb-server
ii mariadb-server 1:10.5.29-0+deb11u1 all MariaDB database server (metapackage depending on the latest version)
root@webhost1:/tmp# dpkg -l | grep php7.4
ii libapache2-mod-php7.4 7.4.33-1+deb11u8 amd64 server-side, HTML-embedded scripting language (Apache 2 module)
ii php7.4 7.4.33-1+deb11u8 all server-side, HTML-embedded scripting language (metapackage)
root@webhost1:/var/www/owncloud# php -v
PHP 7.4.33 (cli) (built: Mar 19 2025 19:57:26) ( NTS )
Copyright (c) The PHP Group
Zend Engine v3.4.0, Copyright (c) Zend Technologies
with Zend OPcache v7.4.33, Copyright (c), by Zend Technologies
Verzió
ownCloud 10.15.2 (stable)
older
The system was installed around ~ 2017.07, it was Debian 9 system in the first place and OC was version 10.0.1 or 10.0.2
root@webhost1:/var/www/owncloud# sudo -u www-data php occ config:list system
“system”: {
“trusted_proxies”: [
“192.168.70.10”
“updatechecker”: false,
“instanceid”: “oc287a8k0f6z”,
“trusted_domains”: [
“192.168.70.4”,
“datadirectory”: “/var/oc_data”,
“overwrite.cli.url”: “http://192.168.70.4/owncloud”,
“dbtype”: “mysql”,
“version”: “10.15.2.0”,
“dbname”: “owncloud_db”,
“dbhost”: “127.0.0.1”,
“dbtableprefix”: “oc_”,
“logtimezone”: “Europe/Berlin”,
“installed”: true,
“maintenance”: false,
“loglevel”: 0,
“theme”: “”,
“files_antivirus.av_cmd_options”: “”,
“files_antivirus.av_path”: “”,
“allow_user_to_change_mail_address”: “”,
“remember_login_cookie_lifetime”: 1296000,
“session_lifetime”: 1200,
“session_keepalive”: true,
“http.cookie.samesite”: “Strict”,
“trashbin_retention_obligation”: “auto”,
“trashbin_purge_limit”: 50,
“operation.mode”: “single-instance”,
“log_type”: “owncloud”,
“logfile”: “/var/oc_data/owncloud.log”,
“syslog_tag”: “ownCloud”,
“log.syslog.format”: “[%reqId%][%remoteAddr%][%user%][%app%][%method%][%url%] %message%”,
“log_rotate_size”: 104857600,
“enabledPreviewProviders”: [
“OC\Preview\SGI”,
“OC\Preview\Heic”,
“OC\Preview\BMP”,
“OC\Preview\GIF”,
“OC\Preview\JPEG”,
“OC\Preview\MarkDown”,
“OC\Preview\MP3”,
“OC\Preview\PNG”,
“OC\Preview\TXT”,
“OC\Preview\XBitmap”
“filelocking.enabled”: true,
“filelocking.ttl”: 3600,
“debug”: true,
root@webhost1.:/var/www/owncloud# sudo -u www-data php occ app:list
Enabled:
- activity:
- Version: 2.7.2
- comments:
- Version: 0.3.0
- configreport:
- Version: 0.3.0
- dav:
- Version: 0.7.0
- diagnostics:
- Version: 0.2.1
- Path: /var/www/owncloud/apps/diagnostics
- federatedfilesharing:
- Version: 0.5.0
- federation:
- Version: 0.1.0
- files:
- Version: 1.6.0
- files_antivirus:
- Version: 1.2.2
- Path: /var/www/owncloud/apps/files_antivirus
- files_pdfviewer:
- Version: 1.0.2
- files_sharing:
- Version: 0.14.0
- files_texteditor:
- Version: 2.6.1
- Path: /var/www/owncloud/apps/files_texteditor
- files_trashbin:
- Version: 0.9.1
- files_versions:
- Version: 1.3.0
- firstrunwizard:
- Version: 1.3.0
- gallery:
- Version: 16.1.2
- Path: /var/www/owncloud/apps/gallery
- market:
- Version: 0.9.0
- notifications:
- Version: 0.6.0
- provisioning_api:
- Version: 0.5.0
- systemtags:
- Version: 0.3.0
- updatenotification:
- Version: 0.2.1
No
Are you using encryption:
No
No.
Firefox 128.13.0esr (64-bit)
Windows 10 Enterprise 22H2
No Error in the logs.
There is no error in the logs.
HTTP/1.1 404 Not Found
Date: Mon, 28 Jul 2025 10:26:15 GMT
Server: Apache/2.4.62 (Debian)
Strict-Transport-Security: max-age=15552000; includeSubDomains
X-Content-Type-Options: nosniff
X-XSS-Protection: 0
X-Robots-Tag: none
X-Frame-Options: SAMEORIGIN
X-Download-Options: noopen
X-Permitted-Cross-Domain-Policies: none
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate
Pragma: no-cache
Set-Cookie: oc_sessionPassphrase=ngMHkoU5XFiF7r75R1%2BMy2ylWd692h01hXyLXdvvKn%2FqZdaIqdro1aHO9xGfOQ5svKb%2FaEmxta183SFV53NeNHQX%2BYmOrIf6Lhk%2FMpzgJTky11Tb%2B82TVnGBdLTe%2BvJ8; expires=Mon, 28-Jul-2025 10:46:15 GMT; Max-Age=1200; path=/; HttpOnly; SameSite=Strict
Content-Security-Policy: default-src ‘self’; img-src ‘self’; style-src ‘self’ ‘unsafe-inline’; font-src ‘self’;
Keep-Alive: timeout=5, max=99
Connection: Keep-Alive
Transfer-Encoding: chunked
What am I missing?
Thanks!
