Hi I am a freshman user and I just installed ownCloud on my Ubuntu 20.04 LAMP server (local dev) My LAMP installation is located at `/var/www/html/owncloud/
Problem: owncloud serves blank white page at https://someothersite.org/
useful info: I already have multiple wordpress installations using an OpenSSL certificate pointing to /var/www/html/ on port 443
I CAN successfully reach https:// someothersite .org/ phpmyinfo.php #your site limits me to 2 urls in a post so I am adding " spaces" for clarity
In my owncloud.conf file I have:
<VirtualHost *:443>
ServerName someothersite.org
ServerAlias www.someothersite.org
# If this is the default configuration file we can use: 'ServerName localhost' or also 'ServerAlias localhost'.
ServerAdmin info@thesolutiontopoverty.org
ErrorLog ${APACHE_LOG_DIR}/someothersite.org.error.log
CustomLog ${APACHE_LOG_DIR}/someothersite.org.access.log combined
DocumentRoot /var/www/html/owncloud/
<Directory /var/www/html/owncloud>
Options None FollowSymLinks
# Enable .htaccess Overrides:
AllowOverride All
Order allow,deny
Allow from all
Require all granted
</Directory>
#My Edit
SSLEngine on
SSLCertificateFile /etc/ssl/certs/apache-selfsigned.crt
SSLCertificateKeyFile /etc/ssl/private/apache-selfsigned.key
</VirtualHost>
In my default-ssl.conf file I have:
ServerAdmin info@someothersite.org ServerName localhost ServerAlias localhostDocumentRoot /var/www/html/ ErrorLog ${APACHE_LOG_DIR}/localhost.error.log CustomLog ${APACHE_LOG_DIR}/localhost.access.log combined SSLEngine on SSLCertificateFile /etc/ssl/certs/ssl-cert-snakeoil.pem SSLCertificateKeyFile /etc/ssl/private/ssl-cert-snakeoil.key <FilesMatch "\.(cgi|shtml|phtml|php)$"> SSLOptions +StdEnvVars </FilesMatch> <Directory /usr/lib/cgi-bin> SSLOptions +StdEnvVars DirectoryIndex index.php AllowOverride All Order allow,deny Allow from all Require all granted </Directory> BrowserMatch "MSIE [2-6]" \ nokeepalive ssl-unclean-shutdown \ downgrade-1.0 force-response-1.0
In my /etc/hosts
file I have:
127.0.0.1 localhost
127.0.0.1 someothersite.org
In my someothersite.org.error.log I have the following error:
[ssl:warn] [pid 32824] AH01906: someothersite.org:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[ssl:warn] [pid 32824] AH01909: someothersite.org:443:0 server certificate does NOT include an ID which matches the server name
Any tips?
- download latest owncloud (wget),
- unzip owncloud,
- change file permissions,
- configure hosts file
- configure apache,
- restart apache && mysql
- visit owncloud home page
Should see ownloud admin login page
blank white page loads at https:// someothersite .org #your site limits me to 2 urls in a post so I am adding " spaces " for clarity
Ubuntu 20.04
Apache2
MySQL
10.6
fresh install
<download.owncloud<.org>/community/owncloud-complete-20201216.zip
