Block automatic login scripts
  1. Open Owncloud log.
from the log, it is apparent that bots are using different methods to break in the server. Fail2Ban is not able to block these IPs, either because it can’t see them from the log, or (most likely) because the same IP stops after 2 attempts, while it is set to block after 4 failed attempts.
Fail2Ban has been tested and working correctly for failed authentications. Is there a way to immediately block any IP using a method that is not POST?
Operating system: Linux Mint 20.1 Mate
Web server: Apache2
Database: mysql
PHP version: 7.4.15
ownCloud version: (see ownCloud admin page) 10.6.0.5
Where did you install ownCloud from: repository
Are you using external storage, if yes which one: smb
Are you using encryption: no
{"reqId":"9r672pDZQwON9xlGCH2i","level":3,"time":"2021-02-26T00:10:47+00:00","remoteAddr":"40.127.160.79","user":"--","app":"PHP","method":"CONNECT","url":null,"message":"Undefined index: path at \/var\/www\/owncloud\/lib\/private\/AppFramework\/Http\/Request.php#620"}
{"reqId":"9r672pDZQwON9xlGCH2i","level":2,"time":"2021-02-26T00:10:47+00:00","remoteAddr":"40.127.160.79","user":"--","app":"core","method":"CONNECT","url":null,"message":"Trusted domain error. \"40.127.160.79\" tried to access using \"ver.movistarplus.es:443\" as host."}
{"reqId":"Y10bDpQkugKytAp41IYi","level":2,"time":"2021-02-26T02:04:01+00:00","remoteAddr":"89.248.168.219","user":"--","app":"core","method":"HEAD","url":"\/","message":"Trusted domain error. \"89.248.168.219\" tried to access using \"127.0.1.1\" as host."}
{"reqId":"zg4yalZnTD7xhH4M2RMx","level":2,"time":"2021-02-26T02:46:19+00:00","remoteAddr":"89.248.168.219","user":"--","app":"core","method":"HEAD","url":"\/","message":"Trusted domain error. \"89.248.168.219\" tried to access using \"127.0.1.1\" as host."}
{"reqId":"5VpsAOH2nuZzCwjajr6j","level":2,"time":"2021-02-26T03:25:47+00:00","remoteAddr":"5.188.210.227","user":"--","app":"core","method":"GET","url":"\/echo.php","message":"Trusted domain error. \"5.188.210.227\" tried to access using \"5.188.210.227\" as host."}
{"reqId":"JRiLviZyLZ3Ph6G7rKN0","level":2,"time":"2021-02-26T09:32:48+00:00","remoteAddr":"89.248.168.219","user":"--","app":"core","method":"HEAD","url":"\/","message":"Trusted domain error. \"89.248.168.219\" tried to access using \"127.0.1.1\" as host."}
{"reqId":"txwYe0SD1iUFfwOhYB9o","level":2,"time":"2021-02-26T20:06:34+00:00","remoteAddr":"178.128.169.213","user":"--","app":"core","method":"GET","url":"\/wp-login.php","message":"Trusted domain error. \"178.128.169.213\" tried to access using \"static-90-255-228-216.vodafonexdsl.co.uk\" as host."}
{"reqId":"oM04BUPzRz9QKhyXmtes","level":2,"time":"2021-02-26T20:40:53+00:00","remoteAddr":"172.105.89.161","user":"--","app":"core","method":"GET","url":"\/0bef","message":"Trusted domain error. \"172.105.89.161\" tried to access using \"127.0.1.1\" as host."}
{"reqId":"8bOLwhCdc4zpTvjhTf9u","level":2,"time":"2021-02-26T20:41:53+00:00","remoteAddr":"222.186.136.150","user":"--","app":"core","method":"GET","url":"\/404\/index.html","message":"Trusted domain error. \"222.186.136.150\" tried to access using \"fuwu.sogou.com\" as host."}
{"reqId":"MEmnU7lLoryjpLt8aIqE","level":2,"time":"2021-02-26T20:41:53+00:00","remoteAddr":"222.186.136.150","user":"--","app":"core","method":"GET","url":"\/404\/index.html","message":"Trusted domain error. \"222.186.136.150\" tried to access using \"fuwu.sogou.com\" as host."}
You will have to build a custom filter and jail action for fail2ban to read the owncloud.log.
There is an extra fail2ban command fail2ban-regex to test regular expressions, that you can use to define filters.
If you can do the start, happy to help if you run into any specific issues.
EDIT: there is also the following app: Marketplace
Not sure if that already covers your use case.
Thank you. I could try Brute-Force, but I do remember using it in the past before setting Fail2Ban, and not working. The best way would be indeed creating a regex as you suggested, but it’s so complicated to me that I wouldn’t even know what to search to start writing one.
Perhaps you can try this as a start:
Not sure if it works, haven’t tested it myself.
