The description of fixes encoding problems
to correct the problem with the coding we need to make changes to the file / var / www / owncloud / lib / private / Streamer.php
Line 66
Original: $this->streamerInstance->addEmptyDir($rootDir);
Change: $this->streamerInstance->addEmptyDir(iconv(“utf-8”, “cp866”, $rootDir));
Line 69
Original: $this->addFileFromStream($fh, $internalDir . $filename, $filesize);
Change: $this->addFileFromStream($fh, iconv(“utf-8”, “cp866”, $internalDir.$filename), $filesize);
downloaded zip files through the web interface with rus cyrillic letters in names of files and folders without coding bugs
downloaded zip files with rus cyrillic letters heve unreadeble names of files and folders
Operating system: Ubuntu 16.04.01 TLS
Web server: apache
Database: mysql
PHP version: 7
ownCloud log (data/owncloud.log, see How to find webserver or OC logfile / enable php logfile): no problems
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): simply config, 50 users, no encryption
Integrity status for oC9+
paste the results here.
