CalDAV Exception in ownCloud X 10.0.3
The logger reports:
A calendar-query REPORT on a calendar with a Depth: 0 is undefined. Set Depth to 1
I am a long-time ownCloud user, and I think this message exists since ever. Is there a way to fix this?
Hi, can you tell us more about your setup and when you encounter this problem?
I have owncloud 10.0.3 installed and it occures every time when CalDav Client connects to owncloud.
Can you provide these informations?
