thanks i got it to sync with my iphone, how fast is the synchronization
If this is a question, a question mark is missing --> ?
If this is a statement, an full stop is missing --> .
If you are happy with the sync speed, you can add a exclamation mark at the end of the sentence --> !
All those little things help other people to understand you better
very odd works on ipad but is not working on ios 12 beta with same settings , am i missing something
I assume, this is not related to the calendar, a connection issue? CORS?
âNot workingâ is unusable as feedback in any way.
what i meant to say i can access calendar from ipad but not from iphone which is running ios 12 beta
i get âaccount verification failedâ
here is log
remoteAddr":â192.168.1.2â,âuserâ:"â",âappâ:âwebdavâ,âmethodâ:âPROPFINDâ,âurlâ:"/remote.php/dav/principals/users/foo/",âmessageâ:"Exception: HTTP/1.1 401 No public access to this resource., No âAuthorization: Basicâ header found. Either the client didnât send one, or the server is misconfigured, No âAuthorization: Basicâ header found. Either the client didnât send one, or the server is misconfigured: {âExceptionâ:âSabre\\DAV\\Exception\\NotAuthenticatedâ,âMessageâ:"No public access to this resource., No âAuthorization: Basicâ
So my suspicion was correct, a connection issue, not calendar related.
but does not make sense because from the same network on my ipad i am able to connect
From the now faulty device, you could connect to the previous version of calendar?
what is strange i tried from old iphone running same beta version ios12 and it works
âreqIdâ:âTqBOhTzFAlhXnyA3xTfFâ,âlevelâ:0,âtimeâ:â2018-09-08T18:51:18+00:00â,âremoteAddrâ:âxxxxxxxxxxxxxâ,âuserâ:âsoydeprâ,âappâ:âOC\Authentication\Token\DefaultTokenProvider::updateTokenâ,âmethodâ:âPROPFINDâ,âurlâ:"/re$
i now can confirm is the latest ios beta issue and not calendar
How did U fix up your problem?
issue is not completly solved
see
