- Install OwnCloud Version 9.1.6
- Install Calendar App 1.4.2
- Import on Client an Calendar (.ics)
Expected behaviourTell us what should happen
Sync the Events to the server
No Event is Sync
Debian 8
Apache
MySQL
9.1.6
fresh install
apt repository
https://gist.github.com/felixbello/71e6b4c82d745876749fceee2b9dbb81
Enabled:
- activity: 2.3.2
- calendar: true
- comments: 0.3.0
- configreport: 0.1.1
- contacts: 1.5.1
- dav: 0.2.7
- federatedfilesharing: 0.3.0
- federation: 0.1.0
- files: 1.5.1
- files_pdfviewer: 0.8.1
- files_sharing: 0.10.0
- files_texteditor: 2.1
- files_trashbin: 0.9.0
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- gallery: 15.0.0
- notifications: 0.3.0
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.1
- updatenotification: 0.2.1
Disabled: - encryption
- external
- files_antivirus
- files_external
- user_external
- user_ldap
to big… but diddn’t see any error
