Caldav won't sync on Thunderbird
  1. Copy CalDav link from calendar app
  2. Paste into thunderbird’s lightning app as caldav link
  3. Cry
The calendar should be found and synchronised. I have this working via the davdroid app on my phone and when I got to the link in my web browser I get the “This is the WebDAV interface. It can only be accessed by WebDAV clients such as the ownCloud desktop sync client.” So the link seems to work fine and davdroid can sync my calendars (and contacts) correctly, but Thunderbird/lightning cannot
Calendar goes “greyed out” with the thunderbird logging saying the following (Main2 is what I called the calendar in thunderbird, mainics is the name assigned by the calendar app)
CalDAV: Retrieving server info from cache for Main2
[calCachedCalendar] Performing playback operation add on 0 items to Main2
[calCachedCalendar] Performing playback operation modify on 0 items to Main2
[calCachedCalendar] Performing playback operation delete on 0 items to Main2
[calCachedCalendar] Doing changelog based sync for calendar https://abc.xyz/remote.php/dav/calendars/user/mainics/
CalDAV: send: <?xml version="1.0" encoding="UTF-8"?>
<D:propfind xmlns:D="DAV:" xmlns:CS="http://calendarserver.org/ns/" xmlns:C="urn:ietf:params:xml:ns:caldav"><D:prop><D:resourcetype/><D:owner/><D:current-user-principal/><D:supported-report-set/><C:supported-calendar-component-set/><CS:getctag/></D:prop></D:propfind>
CalDAV: Status 401 on initial PROPFIND for calendar Main2
Error: [calCachedCalendar] replay action failed: null, uri=https://abc.zyx/remote.php/dav/calendars/user/mainics/, result=2147500037, operation=[xpconnect wrapped calIOperation]
Debian Jessie
Nginx
mysql
5.6.33-0+deb8u1
10.7.2
Fresh install though same nginx config as from 8.2.x
Source
“No errors have been found.”
    "config": {
        "instanceid": "ocgcnc7xim5w",
        "trusted_domains": [
            "cloud.jakecowton.net"
        "datadirectory": "\/srv\/secure\/owncloud\/data",
        "overwrite.cli.url": "https:\/\/cloud.jakecowton.net",
        "dbtype": "mysql",
        "version": "10.0.7.2",
        "dbname": "owncloud",
        "dbhost": "localhost",
        "dbtableprefix": "oc_",
        "logtimezone": "UTC",
        "installed": true
Enabled:
  - calendar: 1.5.7
  - comments: 0.3.0
  - configreport: 0.1.1
  - contacts: 1.5.4
  - dav: 0.3.2
  - encryption: 1.3.1
  - federatedfilesharing: 0.3.1
  - federation: 0.1.0
  - files: 1.5.1
  - files_external: 0.7.1
  - files_sharing: 0.10.1
  - files_texteditor: 2.2.1
  - files_trashbin: 0.9.1
  - files_versions: 1.3.0
  - files_videoplayer: 0.9.8
  - firstrunwizard: 1.1
  - market: 0.2.3
  - notifications: 0.3.2
  - ownbackup: 17.7.0
  - provisioning_api: 0.5.0
  - security: 0.0.2
  - systemtags: 0.3.0
  - tasks: 0.9.6
  - templateeditor: 0.2
  - twofactor_totp: 0.4.4
  - updatenotification: 0.2.1
Disabled:
  - external
  - theme-example
  - user_external
Are you using encryption: yes
Did you try to clear the calendar cache in Thunderbird?
Yes, I’ve tried clearing the cache and same result.
Does it work if you use the direct link to the calendar? (On owncloud click on the “…” Next to the individual calendar and choose link). Copy that link into Thunderbird.
That is how I set up mine.
@Schnabeltier: I may be wrong, but I assume it’s a matter of your setup and/or environment. Code 401 means Unauthorized. And a quick google search with the result code 2147500037 mentions some Windows10 networking issues.
@dbolton yes I’ve tried this and it is immediately greyed out. I’ve tried both the old and new caldav links
@alfredb It very well could be. However, to clarify, this is after “upgrading” a system. I was previously on a much older version so I dropped the DB, upgraded the owncloud files and let it rebuild the DB to essentially create a fresh install. Nothing within nginx or anything else has changed and everything worked perfectly fine previously.
