mirek
1
It is my first post here so I would like to say hallo to everybody.
Unfortunately I have upgraded oc to 10.0.0 via apt-get full-upgrade, next I have upgraded db via occ. I had to disable calendar, contacts, bookmarks and tasks prior to occ upgrade. Re-enabling tasks and bookmarks is not possible now so I have to wait.
Calendar and contacts work via www but synchronisation with desktop/mobile does not work. I have found, that synchronisation does not work because link was changed:
prior 10.0.0 it was:
https://aaaaaaaaaaaaaaaa.com/owncloud/remote.php/**caldav**/calendars/mirek/defaultcalendar
now it is:
https://aaaaaaaaaaaaaaaa.com/owncloud/remote.php/**dav**/calendars/mirek/defaultcalendar/
the same issue with carddav.
Changing it in every desktop and mobile client does not seam to be good idea. Will it be fixed and when?
Is there any workaround?
According to some developers at the bugtracker the old links should still work:
dav was added the old urls are still valid - you can still use caldav.
→ missing databasefield "publicuri" in oc_dav_shares after upgrade to 10.0.0 (stable) from 9.1.5 · Issue #27754 · owncloud/core · GitHub
mirek
3
It should, but it does not. Thunderbird says:
Error: [calCachedCalendar] replay action failed: null, uri=HOAX.COM: unravelling the truth from fiction, past to present..., result=2147500037, op=[xpconnect wrapped calIOperation]
GOT STATUS: 404
I have apache server and rewrite enabled btw.
If it doesn’t then report a new bug to the developers at [1]. This is stuff where most people in here can’t help.
[1] GitHub · Where software is built
mirek
5
Thank you for support, I have sent a bugreport.
here is the fix - please test - thx
