I don’t know how to reproduce it…
Calendar-instances on Android and in webfrontend should be synchronized.
The Calendar in the webfrontend is up-to-date - Android (acalendar / caldav sync) shows no entries on my mobile and wrong entries on another mobile.
Raspbian Wheezy
nginx
sqlite
dpkg:
owncloud: 10.0.0-1.1
owncloud-files: 10.0.4-1.1
updated
cat /etc/apt/sources.list.d/owncloud.list
deb download.owncloud.com /
“system”: {
“instanceid”: “123”,
“passwordsalt”: “456”,
“secret”: “789”,
“trusted_domains”: [
“myaddress.no-ip.org”,
“192.168.xxx.xxx”,
“localhost”
“datadirectory”: “/var/www/owncloud/data”,
“overwrite.cli.url”: “https://myaddress.no-ip.org”,
“dbtype”: “sqlite3”,
“version”: “10.0.4.4”,
“logtimezone”: “Europe/Berlin”,
“installed”: true,
“logfile”: “/var/log/owncloud.log”,
“theme”: “”,
“filesystem_check_changes”: 0,
“maintenance”: false,
“appstore.experimental.enabled”: false,
“loglevel”: 2,
“updatechecker”: false,
“htaccess.RewriteBase”: “/”
Enabled:
- activity: 2.3.6
- calendar: 1.5.4
- comments: 0.3.0
- configreport: 0.1.1
- contacts: 1.5.3
- dav: 0.3.2
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_pdfviewer: 0.8.2
- files_sharing: 0.10.1
- files_texteditor: 2.2.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- gallery: 16.0.2
- market: 0.2.3
- notifications: 0.3.2
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.1
- updatenotification: 0.2.1
no
no
no
Firefox
Mageia 5
The whole log is too big, these are the calendar-related entries since novembre:
{"reqId":"pgp698WbTFQDXasKCKZU","level":2,"time":"2017-12-15T09:33:12+01:00","remoteAddr":"xxx.xxx.xxx.xxx","user":"username","app":"dav","method":"DELETE","url":"\/remote.php\/dav\/calendars\/username\/termine\/20171207T074858Z-e5995213db2745f3.ics","message":"Could not get node for path: \"calendars\/username\/termine\/20171207T074858Z-e5995213db2745f3.ics\" : {$message}"}
{"reqId":"zDxwWPtuHggyD9PIeLgR","level":3,"time":"2017-12-25T22:57:27+01:00","remoteAddr":"78.34.64.67","user":"username","app":"PHP","method":"POST","url":"\/index.php\/apps\/calendar\/v1\/config","message":"Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set 'always_populate_raw_post_data' to '-1' in php.ini and use the php:\/\/input stream instead. at Unknown#0"}
Strict-Transport-Security: Die Verbindung zur Website ist nicht vertrauenswürdig, daher wurde die angegebene Kopfzeile ignoriert.[Weitere Informationen] calendar
Unbekannte Eigenschaft '-moz-box-shadow'. Deklaration ignoriert. multiselect.css:22:16
Fehler beim Verarbeiten des Wertes für 'display'. Deklaration ignoriert. mobile.css:23:10
Unbekannte Pseudoklasse oder Pseudoelement '-webkit-scrollbar'. Regelsatz wegen ungültigem Selektor ignoriert. styles.css:83:2
Unbekannte Pseudoklasse oder Pseudoelement '-webkit-scrollbar-track-piece'. Regelsatz wegen ungültigem Selektor ignoriert. styles.css:86:2
Unbekannte Eigenschaft 'user-select'. Deklaration ignoriert. styles.css:139:12
Unbekannte Eigenschaft 'list-style-indent'. Deklaration ignoriert. styles.css:424:87
'none', URL oder Filterfunktion erwartet, aber 'Alpha(' gefunden. Fehler beim Verarbeiten des Wertes für 'filter'. Deklaration ignoriert. jquery-ui.css:49:8
'Unbekannte Eigenschaft 'appearance'. Deklaration ignoriert. inputs.css:210:11
Fehler beim Verarbeiten des Wertes für 'display'. Deklaration ignoriert. header.css:109:10
Name einer Medienfunktion erwartet, aber '-webkit-max-device-pixel-ratio' gefunden. fonts.css:2:8
Unbekannte Eigenschaft 'user-select'. Deklaration ignoriert. apps.css:30:12
Farbe erwartet, aber 'top' gefunden. Fehler beim Verarbeiten des Wertes für 'background-image'. Deklaration ignoriert. apps.css:152:35
Fehler beim Verarbeiten des Wertes für 'background-image'. Deklaration ignoriert. apps.css:154:19
Fehler beim Verarbeiten des Wertes für 'text-overflow'. Deklaration ignoriert. apps.css:286:17
Unbekannte Eigenschaft '-moz-filter'. Deklaration ignoriert. apps.css:311:12
'none', URL oder Filterfunktion erwartet, aber 'alpha(' gefunden. Fehler beim Verarbeiten des Wertes für 'filter'. Deklaration ignoriert. apps.css:348:9
'Unbekannte Eigenschaft 'line-break'. Deklaration ignoriert. tooltip.css:28:12
'none', URL oder Filterfunktion erwartet, aber 'alpha(' gefunden. Fehler beim Verarbeiten des Wertes für 'filter'. Deklaration ignoriert. tooltip.css:31:10
'none', URL oder Filterfunktion erwartet, aber 'alpha(' gefunden. Fehler beim Verarbeiten des Wertes für 'filter'. Deklaration ignoriert. versions.css:20:9
'none', URL oder Filterfunktion erwartet, aber 'alpha(' gefunden. Fehler beim Verarbeiten des Wertes für 'filter'. Deklaration ignoriert. versions.css:31:9
Unbekannte Eigenschaft 'user-select'. Deklaration ignoriert. style.css:75:4494
Unbekannte Pseudoklasse oder Pseudoelement '-webkit-full-screen'. Regelsatz wegen ungültigem Selektor ignoriert. style.css:75:4793
'none', URL oder Filterfunktion erwartet, aber 'progid' gefunden. Fehler beim Verarbeiten des Wertes für 'filter'. Deklaration ignoriert. style.css:91:9
Fehler beim Verarbeiten des Wertes für 'margin'. Deklaration ignoriert. colorbox.css:10:18
'none', URL oder Filterfunktion erwartet, aber 'alpha(' gefunden. Fehler beim Verarbeiten des Wertes für 'filter'. Deklaration ignoriert. firstrunwizard.css:25:9
Strict-Transport-Security: Die Verbindung zur Website ist nicht vertrauenswürdig, daher wurde die angegebene Kopfzeile ignoriert.[Weitere Informationen] vendor.min.css
Strict-Transport-Security: Die Verbindung zur Website ist nicht vertrauenswürdig, daher wurde die angegebene Kopfzeile ignoriert.[Weitere Informationen] app.min.css
Unbekannte Eigenschaft 'user-select'. Deklaration ignoriert. vendor.min.css:1:1111
Fehler beim Verarbeiten des Wertes für 'background-image'. Deklaration ignoriert. vendor.min.css:1:2514
Unbekannte Eigenschaft 'user-select'. Deklaration ignoriert. vendor.min.css:1:9042
Unbekannte Eigenschaft '-moz-border-radius'. Deklaration ignoriert. app.min.css:1:6455
Unbekannte Eigenschaft '-moz-border-radius'. Deklaration ignoriert. app.min.css:1:18276
Strict-Transport-Security: Die Verbindung zur Website ist nicht vertrauenswürdig, daher wurde die angegebene Kopfzeile ignoriert.[Weitere Informationen] de.js
Strict-Transport-Security: Die Verbindung zur Website ist nicht vertrauenswürdig, daher wurde die angegebene Kopfzeile ignoriert.[Weitere Informationen] vendor.min.js
Strict-Transport-Security: Die Verbindung zur Website ist nicht vertrauenswürdig, daher wurde die angegebene Kopfzeile ignoriert.[Weitere Informationen] app.min.js
Strict-Transport-Security: Die Verbindung zur Website ist nicht vertrauenswürdig, daher wurde die angegebene Kopfzeile ignoriert.[Weitere Informationen] oc.js
JQMIGRATE: Migrate is installed, version 1.4.0 jquery-migrate.min.js:2:542
Strict-Transport-Security: Die Verbindung zur Website ist nicht vertrauenswürdig, daher wurde die angegebene Kopfzeile ignoriert.[Weitere Informationen] notifications
Strict-Transport-Security: Die Verbindung zur Website ist nicht vertrauenswürdig, daher wurde die angegebene Kopfzeile ignoriert.[Weitere Informationen] config
Fehler beim Verarbeiten des Wertes für 'top'. Deklaration ignoriert. calendar
Fehler beim Verarbeiten des Wertes für 'left'. Deklaration ignoriert. calendar
GET
XHR
https://username.no-ip.org/ocs/v2.php/apps/notifications/api/v1/notifications [HTTP/1.1 200 OK 738ms]
